Your Catch of the Day / Saved from the Dump!
Quoted: 25 Post(s)
Good info I had gotten that far just today BUT I can't seem to find any Le Tour's with Suntour equipment AND 15 speed triple gear train. The rest seems true as for now. I have a pair of new Mavic MA-40 36 hole rims to lace onto these high flange hubs and get rid of the steel rims, (Which I don't understand either) and it will be a keeper. Not bad for a $10 thrift store throw away. Thanks for your help.
Quoted: 5888 Post(s)
Liked 3,472 Times
That's my daily rider - although mine is the Canadian made version. Same lugs, same Tange, same dropouts and chrome, same headbadge, but green paint. Converted it to a 2-speed 700c commuter and it clears 35c Pasela's with full fenders. It's such a great commuter because it's a thoroughbred in disguise that owes me nothing. The thinwalled tubing has a great ring to it, too (no cable guides to dull the sound).
Bikes: 2009 Masi, 2014 Specialized Crossroads 1975 Schwinn Unicycle
Quoted: 12 Post(s)
Kind of a low end Schwinn Folsom Jack, to come with a triple crankset. Might have had it's quick release wheels, stolen when it was locked up someplace.
Bikes: 1981 Raleigh GP, 1985 Norco Bush Pilot, . . .
Quoted: 241 Post(s)
Liked 187 Times
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Look up a mid-'80s Schwinn Le Tour Luxe. SunTour stuff with a triple, but probably a 6-speed cluster.
Quoted: 3814 Post(s)
Liked 3,345 Times
C. Itoh was a marketing company that had their bikes made by Bridgestone. Bridgestone bikes had the same "Tested Finest Bicycle..." decal. It is very similar to the BS Kabuki Super Speed that I have.
Here is some info from Sheldon Brown:
"The Kabuki line used some unusual construction techniques, specifically, a system of sticking the frame tubes into a special mold and forming cast aluminum "lugs" in place around the ends of the tubes. The most notable of this line was the "Submariner" which used un-painted stainless steel tubing, and was marketed in seacoast areas for its rust-resistance. Because the cast aluminum lugs were not flexible like steel lugs, these bikes didn't use a conventional seat-post binder. Instead, they used a seat post with an expander wedge like that of a handlebar stem...you had to remove the saddle from the seatpost to adjust the height, then re-install the saddle! Even sillier, many of these frames had what looked like a conventional seatpost bolt mounted in a projection of the rigid lug, simply to provide a place to mount a cable stop for the center-pull caliper brake!"
There were also some C. Itoh bicycles manufactured in Mexico by ACER-MEX circa 1970.
Quoted: 25 Post(s)
Now that makes sense, BUT the cranks are Sugino GT triple chain-ring The rest of the Groupo is Suntour including the stem mounted shifters AND a long cage rear deraileur by Suntour ,all a matching set. Every-thing else is as specked including the original tires on original steel rims. Why would any-one go to all that trouble and expense and not change out the wheel-set. There are NO decals or identification any where except the round Schwinn /Chicago badge.
Quoted: 638 Post(s)
Liked 1,298 Times
Quoted: 25 Post(s)
I switch components between bikes like some people change their socks so that doesn't seem odd at all to me. If you got hold of some of my "creations" you'd REALLY be confused. I'm pretty sure you have Frankenbike kludged together from at least 2 or 3 different bikes but it's a decent enough frame and drivetrain that should work nicely together so make the best of it and enjoy the ride.
Quoted: 638 Post(s)
Liked 1,298 Times
I just don't think so. The groupo is complete and original and who in their right mind would use these shifters ? I have to believe it is all all factory piece lacking all the decal's. The drop-out # is SG 803923 and there has to be a member here who can solve this with data.
Some good info and pics of a '79 here....
LeTour IV Schwinn
Quoted: 25 Post(s)
The '78 frame date code, color, stamped dropouts, high flange hubs in steel rims, bolt on rear wheel, chrome cap and socks on the fork and the braze on cable stop on the down tube for the derailleur cables with stem shifters are consistent with a very early 1979 LeTour IV. The '78 LeTour III and '79 Super LeTour II had clamp on stops for the derailleur cables. That said the crankset and derailleurs would NOT be correct for any LeTour of that vintage. My money says it's an early '79 LeTour IV with a different drivetrain.
https://www.bikeforums.net/classic-vintage/843579-letour-iv-schwinn.html
Since the Suntour Mountec group came out in 1983, I believe you are right!!!! Thanks.
Quoted: 638 Post(s)
Liked 1,298 Times
Glad I could help, it was a great buy, just the crankset alone was worth a lot more than $10. Should make a pretty nice riding bike when you're done. That's one of my favorite Schwinn colors.
Quoted: 241 Post(s)
Liked 187 Times
@Murray_Missle, nice detective work on the Le Tour.
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 599 Times
Saved these two bikes from an unknown fate. They were given to me by the older original owners and both had been converted to fixed gear. The larger one is a Dilecta Le Blanc touring frame (60's) the smaller 49cm a Gianella by Gianella Cycles Montreal. Equipped with Super Champion rims and Campy and Pelissier hubs. I hate the idea of spending so much time and money to re-dish the rear wheels and add all the stuff required to shift. Maybe their fate truly is unknown?
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Quoted: 638 Post(s)
Liked 1,298 Times
1) My mom's Alpa/Special from 1956. She wanted to throw it away. Since i learned to ride on that thing i thought i might try to restore it because emotional value and stuff. It was my first restoration project and i learned a lot thanks to it.
Upper pic is how i found it, lower pic is how it looks now. Funny thing is that i didn't touch the Sturmey hub and i'm pretty sure no one did since 1956. It still shifts like a charm and coasts like forever.
Still some work to do. Just recently i found the original kind of lights it had. Have to fit them.
Likes For Kovkov:
2) Tigra Sprint Super Leger from 1967
Reynolds 531 frame. Bought it for 20 swiss franks from a guy who restores and sells old bikes for a hobby. He amassed a whole garage full of bikes and was about to throw the ones in the worst shape away:
Bikes: 90's Trek 850, 05 Giant Yukon, and many others that pass through my hands between the junk yard and a new owner
Raleigh Cycle Company of America
Picked up this mixte frame 10 speed at the junk yard last week. What do you know about Raleigh Cycle company of America? It was owned by Huffy, but this bike seems to be far beyond the quality I'd expect from Huffy: adjustable drop-outs, all alloy bars, stem, crank, seat post and wheels. It's marked Grand Prix. I'd certainly appreciate a little info. Thanks so much.
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times
Liked 936 Times
Sempiternal Newb
Bikes: '92 Trek 750, '85 Univega Gran Turismo, '95 Stumpjumper,
Quoted: 232 Post(s)
Liked 15 Times
Turns out there’s a bicycle junkyard here in town. It was a dangerous discovery. Mostly Huffys and American Flyers, but there are some gems in there in varying states of decay.
First haul: 1989 Cannondale SR400, 1979 Miyata Lemans Course, and a Schwinn Mesa Runner. The Miyata is neat, as far as I can tell it’s from Japan, made for the Japanese market.
Quoted: 1143 Post(s)
Liked 1,757 Times
Here is a custom built racer frame that needs attention in a bad way.
Obrien columbus
Obrien columbus
Quoted: 293 Post(s)
Liked 218 Times
Bikes: Trek 400 Elance, Losa Winner, 1994 Schwinn Paramount, Specialized Tarmac Pro, Miele SLX, Ibis Ripley, Colnago Oval CX, 84 Masi GC, 1986 Schwinn Voyageur, 1988 Schwinn Tempo, 1998 Schwinn Peloton, 1991 Paramount Ser3
Quoted: 150 Post(s)
Liked 90 Times
Here's a 1980 Voyageur I picked up. Saw it on Facebook Saturday night and emailed. It was 150 miles away, but there is a very highly rated MTB trail system right there, so I thought, 'I'll pick it up and go ride the trails!" Bad communication, really too late for original plan, the seller finally said, 'come on.' Sat down to say, 'Sorry, it's too late in the day' and all, and 'I'll leave now' came out instead. Weird. It was worth it though. The thing is in stellar cond. and I took a short ride when I got home. It's feels fantastic. Why in 'saved from the dump?' If the singer/actor Jerry Reed had a crazy, fume huffing look-alike brother who sold bikes on FB and came to the door with his pants falling down, that's the guy! I couldn't stick 95.00 in a guy's hands and grab a bike any faster!
https://scontent-dft4-3.xx.fbcdn.net...32&oe=5A8B9EE2
