Cinelli 1a stem handlebar bolt spinning
#51
Quoted: 4533 Post(s)
Liked 6,435 Times
Well, I gave up with this stem, but not in the way you think.
The best thing to do was to remove the bolt, inspect for damage and try to put the bolt back in a way that would hold better the next time around. Using different Allen wrenches, I slowly got the nut to hold to make a tiny bit of progress. Went from a 2mm Allen to a 4.5mm Allen with this grip:
At this point, I wasn't able to pull hard enough to get the nut to "stick" anymore. But what I was able to do was mount some handlebars in it. Initially, these were just supposed to be a passive wedge, as my Allen wrenches marred the stem something awful. But with diminishing returns as they were, I gave up and started cranking down the other way on the bolt.
After a little struggle, I got the nut to stop spinning and cranked down hard. The nut is now embedded much deeper in the stem than before, a good sign that I might have some luck removing it someday.
But that's not my plan. I can hopefully go the rest of my life without ever loosening this bolt now. If the bars go, the stems go, and what I have put together let no man separate.
#52
Liked 6,435 Times
You would probably have to shim it and that will also put pressure on the nut side so it may bind the back side too much.
#53
Quoted: 331 Post(s)
Liked 332 Times
Punch head and drill.
Centre punch the cap end, drill a 2mm hole say 5mm down. Force a allen key into drilled hole and rotate the nut off and grease the nut(not the head) before replacing.
#54
Liked 6,435 Times
#55
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3912 Post(s)
Liked 6,526 Times
Likes For SurferRosa:
Likes For smontanaro:
#57
Edumacator
Quoted: 2489 Post(s)
Liked 3,223 Times
Ahhh! For some reason I was thinking the bar was still in it. That makes perfect sense now...and a solid idea.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
#58
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times
If you spread that bar clamp too far open, the stem is likely to crack and break later.
My C&V Bikes:
1972 Bottecchia Professional, 1972 Legnano Olympiade Record,
1982 Colnago Super, 1987 Bottecchia Team C-Record,
1988 Pinarello Montello, 1990 Masi Nuova Strada Super Record,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron
My C&V Bikes:
#59
Liked 6,435 Times
#61
Bikes: many
Quoted: 1455 Post(s)
Liked 1,405 Times
That's a one-inch stem. In fact, I keep that riser stem with my tools. I use it on occasion to help round out seat tubes which have been ovalized.
#62
Liked 6,435 Times
