1986 Custom Fuji Frame or is it?
Location: Milwaukee-Chicago (Last stop on the North Shore Metra Line)
Bikes: 1975 Fuji 'The Finest', 1975 Fuji Super Road Racer S10-S,1980 SR 10-Speed, 1980 Fuji Newest, 1984 Araya 14-Speed, 1985 Bridgestone 500, 1986 Fuji 'Sekkei Series', 1995 Gary Fisher Kaitai MTB
Quoted: 131 Post(s)
Liked 12 Times
Thanks. Yes that's what I noticed when I checked out some Opus III images on the web. In 1986 the Opus was still using the above BB method, while the DS line started at day one with below BB runs. By 87 all the higher end Fuji's went below the BB for their runs, but sadly the Opus III was no more! The DS track bike probably looks more like your Opus, at least underneath.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Quoted: 131 Post(s)
Liked 12 Times
Thanks for sharing the page John amd your probably right they actually used a Tange part.
Quoted: 4722 Post(s)
Liked 3,039 Times
Thanks T-Mar. I have added your graphic to my Ishiwata document for future reference. I totally agree with your assessment of how Fuji chose the part numbers for their tubing by contracting the butted 10th mm digits. However, in this case all the Fuji catalogs indicate the Design Series (DS) used 019E tubing. I have three first hand examples now of the physical decals on DS road bikes and all are labeled Fuji 9658. Wonder why Fuji doesn't agree with your analysis? Seriously, I'm not trying to be cocky as they seem to be breaking their own rules.
It's worth noting that the catalogues specify a 26.8mm seat post on the Design Series . Allowing for the standard 0.2mm clearance in a imperial seat tube, that calculates to 0.8mm wall thickness and further supports the 9858 designation being representative of the wall thickness. They clearly doesn't use a standard 019E seat tube, which would use a 27.0mm post.
BTW, my frame dimensions are very much the same as the DS 52cm version, except my top tube is a wee bit longer at 540mm vs 525mm in their catalog. Which makes my seat-tube angle around 74 degrees vs their 75 degrees. My wheel base might be a little different too, but right now I don't have the fork installed so such measurements would be very inaccurate at this point. Also my frame weight is about 1/3 lb (160 grams) heavier than the catalog DS version, but the fork weights are exactly the same. That could be due to my little longer frame and slightly different front lugs. It does kind of point out that mine was never really a repainted DS version.
Regarding the forks, if you check your charts, I believe you'll find that Ishiwata used the same gauge fork blades and steering columns on all the CrMo road tubesets, so there would be no difference in fork weight, regardless of the actual tubeset.
On the observation you made regarding internal BB mitering. From the Fuji DS catalog page;"Our Fuji Craftsmen hand braze, miter and file each and every frame with uncompromising attention to detail". Another indication mine is probably not a DS model. or as the saying goes 'What goes on inside the bottom bracket, stays inside the bottom bracket"
Fuji's literature implies that the Design Series frames were manufactured in-house and that that they did not contract manufacture any bicycles for other companies, so that would seem to limit the options.
Quoted: 131 Post(s)
Liked 12 Times
Thanks for the very thorough reply TMar. I knew you've been thinking of this stuff for a long time by reading many of your earlier posts on the topic. I guess the bottom line here is if I want to add a tube decal on this old frame I'd best just put on a Fuji 9658 version (after I get Velocal to create one) and call it a day Agreed 019E would make it a 27mm seatpost and there ain't no way on my frame! It's a solid 26.8 with a cleaned-out seat tube and smooth post.
Since it does appear this frame is rather unique with what does appear to be Tange version front lugs. That is unless someone finds a catalog picture showing Ishiwata made the exact same style. Somethings about it may always remain a mystery. I'm sure in the day there was a ledger kept with notes on each of these special serial numbered Fuji's. Most likely that's long gone now or collecting dust on a shelf only known to the books owner.
Oh yeah to address your curiosity on the BB tubes. Both chainstay tubes were straight cut and just set back. The Seat and Down tubes were nicely mitered.
NEW Internal topic: A much belated kudos for the fine Fuji S/N work you did ten years ago. I'm trying to remember did you ever figure out if Fuji's three digit numbered tubing (331/441/661) meant anything? My 1980 Fuji Newest used their 331 tubing (AYK - as did the top half of their bikes in mid-70's through mid-80's). Since that was DB with a 26.6 seatpost I expected it was probably Ishiwata 022. I'm not about to disassemble that bike fully to do some frame weighing I vaguely remember weighing the frame, but can't find any place I recorded it as it was also a frame up build.
Liked 3,039 Times
Not that I want to introduce any more controversy but the mitred main tubes and non-mitred stays suggest the possibility of a tretubi frame. That might account for some of the weight difference.
No, I never did any investigation into the Fuji 3 digit tubesets. However, I don't think there is any logic to the format, other than establishing a phonetic similarity to 531, to trigger subliminal responses with consumers.
A 26.6mm seat post is not what I would expect for an Ishiwata 022 frame. It should be 27.2mm. I believe there is a general consensus that Fuji used Ishiwata as their primary source. A 26.6mm post would suggest a custom 022 tube, with the most likely scenario being a double butted version. However, it is spooky that a 26.6mm post would also correlate to a Tange Champion seat tube. How appropriate, given that to-morrow night is Halloween.
Quoted: 131 Post(s)
Liked 12 Times
I'd think that the "tretubi frame" would be unlikely, but not impossible, as the chainstay tubing has the same shape as what I see on the Design Series frames. I am trying to cross-reference between Fuji tubing and other makers standard product, when it may have been a fully custom build only for Fuji. It would be interesting to find out from the Design Series owners to actually see how their tubes are cut within the BB though. The major difference from a frame standpoint is still the different headtube lugs used on mine vs the Design Series. Heck that could have been a "we have one of these sitting here let's use it" decision. As time goes on we'll gather little bits of info, especially when DS frame users start to chime in as to what they actually see on their physical bikes and the deviations (like the chroming above the brake bridge that you observed).
Half the fun is the investigation.
Additional: After thinking about it, sure the BB would be the highest force/stress point on the frame so that's where the thicker tubing side would be on butted tubes. I need to watch and read more about steel bike frame building.
Quoted: 131 Post(s)
Liked 12 Times
allen254
Road Bike Marketplace
2
03-28-16 05:33 AM
ScottNotBombs
General Cycling Discussion
2
07-20-10 04:26 AM
