For the love of English 3 speeds...
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 444 Times
Somewhere online I read an article about the decline and demise of Sturmey Archer (the original UK company). It was written by someone who's a career wrench and bike shop owner, and he thinks it was predominantly Grip Shift, appearing right around the time of this bike--early 80s--that so weakened the demand for IGH bikes that TA or whoever owned SA at the time finally sold off the business.
Whether they're needed or not.
Driverless cars?
Is there actually a demand?
Quoted: 887 Post(s)
Liked 335 Times
I have seen it promoted for truck caravans, but don't we already have a means of moving goods by train?
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
Update on the '52 Sports. WD40 flush of the IGH got things moving again, but I've been unable to hook up and ride, as the front tire has succumbed to dry-rot. Anyone successfully coax a modern 700c wheel with 100mm hub into these forks? I'm not quite strong enough to pry them apart, so I may do a cold set with threaded rod.
Quoted: 1858 Post(s)
Liked 664 Times
[QUOTE=BigChief;20953426]The Super Course was a medium priced model. The important factor is that it has a Reynolds 531 tube frame like the original club bikes. What you're talking about is what we call a scorcher. That is stripping down a regular light roadster like a Sports. I made this one from a 21" 1955 Rudge Sports. I need upright bars, so this has a tall Sunlite touring stem and long seat post so it fits me. It has alloy rims, alloy shell AW hub,a light weight seat, alloy ESGE kickstand, rat trap pedals, Tektro brakes and no mudguards or chainguard. It's pretty sporty. I put a lot of miles on this one. There is a misconception that these frames are "gas pipe" but they are not the same mild steel as the cheapo department store bikes or even electro welded Schwinns. Those are 1010 steel. The Raleigh Sports frames are more like 1018 or 1020, but still not as hard or light as the more exotic alloys like 531. Still, you can have plenty of fun on a scorcher!/QUOTE]
I'm not too clear on scorchers, but I have the 1952 Rudge Aero special frame and the 1973 Super Course frame nearby, both abour 54 or 55 cm seat tube.
Let's compare the geometries:
Seat tube length: Rudge 55 cm, SC 54 cm
Seat tube angle: Rudge 71 deg, SC 73 deg
TT length: Rudge 57 cm, SC 56 cm
Head tube angle: Rudge 73 deg, SC 73 deg
Fork offset: Rudge 63 mm, SC 59 mm
Front Center: Rudge 65 cm (estimated), SC 62 cm
Chain stay length: Rudge: 44.5 cm, SC 45.5 cm.
Wheelbase: Rudge 106 cm, SC 103 cm.
And some of the rest of the specs:
Braze-ons: both have f/r fender mounts, both take caliper brakes with center bolt (Rudge cabled for side pulls, SC cabled for center-pull). Rudge is set up for Sturmey-Archer integrated gear hub, AM, AW, FM, FW. SC set up for 2x5 derailleurs with downtube friction shifting.
My expectation is that both will make excellent descendants of the original British Clubmen, and an excellent tool for as close as I can train up to a (local version of) Lands End to John o Groats, or local long rides or day brevets. With a Carradice or Brooks bag on the rear, either would do well for an inn overnighter. Now, an International, my Woodrup refurbished, or that new Mercian I've envisioned since high school might just surpass a hot-rodded Rudge or a Super Course. But, a Clubman and a Super Course were both the dream bikes of the normal working man. Needless to say, both should be suited to supported multi-day tours.
Both have Reynolds straight gauge main tubes, the Rudge has all its tubes of Reynolds 531. Neither are gas pipe. Both are made in English factories: Rudge at Raleigh/Nottingham, SC in Raleigh-owned Carlton/Worksop. Both used steel cottered cranks. The Rudge used proprietary Raleigh threading BB and headset and will not accept a 68mm BSA BB spec. The SC was in transition from traditional Raleigh to 68 mm BSA specs. The Rudge can of course accept the original 630x32c tires with the grace that suggests the frame was designed for them. The SC is a less tight-fitting frame, but mine might accept 40 mm tires in a 622 rim. I have to do some more measuring and figuring. With the SC you can use a three, four, or five speed Sturmey Archer hub, or cold-set the frame for a Campy index-shifting 8-speed (or any other modern gearing), a full vintage French drivetrain as originally supplied, or what have you. For a dyno, either frame can have a wheel built with a modern SON or Shutter Precision hub, or a Sturmey Archer FG (wide-range four-speed gear hub with generator) or GH (front dyno hub).
Main point is that if you want to make your own modernized or S/A Clubman, a Raleigh Super Course is a nearly perfect platform. Mine is as I said a 54 centimeter one, 1973, and it is a little banged up needing an amateur alignment.
Quoted: 76 Post(s)
Liked 19 Times
@Road Fan
Thanks for the info. I'm keeping my eyes open. I would absolutely love to run into an Aero Special. More for the fact that most people have never heard of Rudge than anything.
Liked 664 Times
But the off-topic matter is not to be denied, and I have to say I'll only discuss it further in the Safety forum or on PM.
Liked 664 Times
@Road Fan
Actually in the Rudge/SC comparison post, my point was that a Super Course could make a fantastic modern-man's Clubman-clone.
But here we'd likely be straying out of three-speed territory, as well!
Bikes: 1983 Trek 600, 1972 Raleigh Sports Step Thru, 1963 Rudge Sports, 2007 Dahon MuP8, Dahon Speed, Public Mixte 8-speed IGH, mid-70s Peugeot Mixte AW conversion, Riv Platypus
Quoted: 350 Post(s)
Liked 24 Times
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
One issue with many frames intended to be really light is that the frame geometry isn't optimized to also be comfortable. This might be the big difference between a daily rider as opposed to a bike intended for racing. So many bike designs are based on racers, even though most people never race them- they just ride and are uncomfortable
If you're trying to build a scorcher this might be the thing to keep in mind!
There's a bike company called 'Jones' that is a mountain bike that is intended to be comfortable- and has some interesting geometry that many with 3-speeds will find familiar. I have a Jones and the riding position is the same as my three speeds. In both cases this allows me to be on the bike for really long times.
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 360 Post(s)
Liked 471 Times
Still, I eyeball the "barn find" 1950s Raleigh Lentons, Clubman etc. bicycles on ebay more often than I'd like to admit.
Liked 664 Times
But at the same time, the effect of seat tube angle is setback of the seat tube lug from the BB plumbline. That added setback, measured at teh saddle, can be compensated with a seatpost that has a higher setback.
So while you can't duplicate the ST angle, you can achieve similar setback by using a deep-setback seat post such as a Nitto S-84 or one of the lower cost high-setback posts.
Quoted: 350 Post(s)
Liked 24 Times
Not unlike my Peugeot AO8. The frame isn't a DB frame, but it is as quick and enjoyable a ride as any other bike I've owned or ridden, with the possible exception of my DB Voyageur. Thanks to the experience and generosity of members here I'll be fitting a '53 FW to my Pug and creating my own near-Clubman type bike for commutes and day rides. I'm going to build the FW into a Velocity Dyad 700c wheel, and the front will be same but built around a Maillard 700 Professional hub. I considered going out and finding a Reynolds / Tange / Columbus tubeset to build it into, but I like the mid 1970s French bicycle aesthetic and price. Reynolds or DB frames in general are not cheap in my part of the world. Finding a 60 or 62 cm frame makes it even more difficult, so the A08 in 62cm was a great find for this four speed project.
Quoted: 360 Post(s)
Liked 471 Times
I like the blue. I don't like this:
Shipping:
US $124.15 (approx. C $167.84) International Priority Shipping to Canada | See detailsImport chargesUS $40.99 (amount confirmed at checkout) Ebay shipping to Canada prices are intense to say the least. Trouble is, local prices are not much better. People in Toronto, Ottawa, or Montreal think '70s and '80s bicycles (Motobecane, Peugeot, Trek, Gitane, Raleigh, Bianchi or any other marque) are worth way more than I believe to be rational. Even bottom of the rung bikes cost.
Quoted: 350 Post(s)
Liked 24 Times
Shipping:
US $124.15 (approx. C $167.84) International Priority Shipping to Canada | See detailsImport chargesUS $40.99 (amount confirmed at checkout) Ebay shipping to Canada prices are intense to say the least. Trouble is, local prices are not much better. People in Toronto, Ottawa, or Montreal think '70s and '80s bicycles (Motobecane, Peugeot, Trek, Gitane, Raleigh, Bianchi or any other marque) are worth way more than I believe to be rational. Even bottom of the rung bikes cost.Newbie
Quoted: 22 Post(s)
Finally worked on that dented '69 Sports fender.
Did the minimum as I have two nice Sports already and wanted this one as anytime commuter/utility bike.
Banged out fender
Added Schwalbe white walls from '67 Austrian Sears ladies bike I picked up from the co op.
Added 24T cog (for riding over harbor bridge)
Added Plescher rack from 19" Sports I picked up at co op.
Added Kool Stop pads
Added tool bag I picked up at co op
Took one of the Wald rear folding baskets from '74 Sports and installed on '69.
As is from co-op plus 24T cog
Dented fender
Dented fender
Good enough fender repair. Still need to add reflector tape
Picture taken at dusk. Apologies for the poor lighting
Banged out fender
Dented fender
Dented fender
Quoted: 1299 Post(s)
Liked 103 Times
Banged out fender
Dented fender
Dented fender
Banged out fender
Dented fender
Dented fender
Quoted: 22 Post(s)
That being said, the brake lever clamp on the Sears is broken. Any idea if I can find another clamp or how I can replace the whole lever? The bike has nice white vintage cables and I don't want to screw them up.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Two of the six bikes in this ad are pretty interesting.
https://richmond.craigslist.org/bik/...904286855.html
bicycle frame material: steel
bicycle type: cruiser
frame size: several
wheel size: other/unknown
Lot of vintage bicycles. Purchase one or make an offer for them all. Dates of bicycles are estimates based on serial numbers and styles
Call or text Marty @ 804-five-0-2-7-two-85
1967 or late 60s Raleigh superbe - $300/obo
https://www.sheldonbrown.com/retrora...talog-1967.pdf
Late 60’s Raleigh sports ladies bike - $100/obo
Women’s 1980’s Murray 3-Speed Richland Touring Bike $100
Ross Europa 10 Speed from Allentown, PA manufacturing stopped in 1987
late 70s model (rare design) $50
Huffman Huffy 10 speed is a 1974 $20
Free Spirit women bike from Sears. Mid 80’s possibly ’86. $20
vintage bicycles (Moseley)
frame size: several
Liked 444 Times
Thanks! I'm pretty proud of how far I've come mechanically. With the help of this thread and co-op, I feel like I can fix just about anything on these bikes now. I was hoping finally wrapping up my beater/utility bike would ease collector urges, but now I think I will try to fix up for others as I run across them.
This will give you enough slack to get the ball end free of the lever.
Probably best to replace both levers with something similar so they match.
New bare cables are cheap ($2.00-$3.00) but keep the housings and
re assemble with some oil dripped down the housing.
Liked 103 Times
Those higher end 1950s English bikes are just rare here in the US. As a kid, I rarely saw an adult on a bicycle. The English roadsters sold well to older kids because once you rode one, you discovered that they were far superior to the welded up gas pipe, coaster braked clunkers we were all used to. It wasn't just the 3 speeds. The whole design made them easier and more fun to ride. So at least the roadsters are plentiful this side of the Atlantic.
Likes For BigChief:
Quoted: 22 Post(s)
Loosen the lock nut on the caliper in question that holds the brake cable.
Quoted: 350 Post(s)
Liked 24 Times
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Speaking of Scorchers, my Pashley Roadster conversion has become my favorite "Just grab it and go" bike. And not only for trips around the neighborhood, either.
Here she is in Hastings, MN, where we rode several branches of the Vermillion River Trail system. I call her "Pepper", for Pashley Path Racer. We put on over 20 miles last Sunday in the rolling hills west of town. It was a wonderful day out.
3-speed content: Does anyone here have any experience with the modern Sturmey Archer X-RD 3 or 4 drum-brake hubs? I am thinking of mounting one on this bike, so I have more options as to where I can ride it. I haven't had to walk this up a hill yet, but have come very close.
USMC 1981-1991 Semper Fi!
Quoted: 350 Post(s)
Liked 24 Times
Liked 103 Times
