Post Your Bridgestones -- The Unofficial Bridgestone Thread
#326
Quoted: 1623 Post(s)
Liked 2,648 Times
Hey Robbie , better you than me...
#327
aka: Dr. Cannondale
Quoted: 2159 Post(s)
Liked 3,453 Times
Words cannot express my confusion as to what you actually did down there, and not sure I even want to know. But hey, it apparently worked and got you bonus points with the REI folks as well.
So, good on you.
So, good on you.
#329
Quoted: 378 Post(s)
Liked 1,411 Times
curbtender suggested I treat the remaining aluminum dropout like the carbon dropout that fits with replaceable RD hangers, and further suggested the Cannondale "H" hanger, because it formed a sleeve into which the dropout fit into, rather than an inner piece with an outer, bolt-on hanger. He supplied the hanger.
I then set about getting the 10mm wide dropout to fit into the 6mm wide slot in the RD hanger. I actually hacksawed a slice off the best I could, then cut off a piece that prevented the hanger from sliding up to where the axle hole would line up with the Radac's dropout.
The created a problem with that "angle of the dangle," The OEM hanger's RD bolt hole was situated directly below the axle; call it 6 o'clock. The Cannondale hanger was designed to do the same, but there was no way to trim the remaining aluminum on the Radac to match that angle, and still have enough aluminum to drill a hole through for each bolt. As it is, the top mounting bolt is through and through, but the bottom mounting bolt actually sits in a notch on the aluminum dropout; simply not enough aluminum there to make a hole and still line up with the axle.
The new "placement" of the RD bolt hole, with the Cannondale hanger, is about 3:30 relative to the original 6:00. It sits forward of the original position, relative to the cogs, and about 1/2" closer/higher. The only way to mitigate this was to run the adjusting screw on the RD all the way in, which moved the RD angle back, but it's nowhere near vertical from the axle.
The RD has a greater "tilt" counterclockwise than it would normally have, and the upper pulley is biased somewhat up in front of the cogs. It's like looking at it from the side, reaching out and rotating the RD on it's pivot about1/6 of a turn counterclockwise. The 13T being the smallest, this could have been a real issue, but with a new chain, it spins forward and backward just fine with no chain slap or suck.
I'm going to give it a good shakedown, maybe 2x15miles or 1x15 and 1x25, just to make sure. Then I'll probably send Rachel at REI the pics, let her test-ride it, and give her a good rundown on the issue maybe being fine forever, and maybe failing the next time around the block. Best case scenario, she rides it at RAGBRAI. Worst case, she finds another frame and swaps over.
As you can see in the picture, the only way to slide the back wheel out is to remove the skewer end completely.
#330
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Aw, shucks...'tweren't nothin'.
#332
Le savonnier
Bikes: I can count 'em on one hand
Quoted: 729 Post(s)
Liked 602 Times
It's been a great ride, I really like this bike! Not many changes so far: Planet Bike Cascadia fenders and a new Brooks B17 saddle (honey). Still waiting on MKS Sylvan Touring pedals, and new Sugino XD crankset. After that, probably some Tektro CR720 cantilever brakes, and as yet undetermined new shifters, brake levers, derailleurs, and stem. I had thought of changing out the bars and grips, but I actually like both as-is.
Will post new pics soon.
#333
1974 "Submariner" (Not Labeled As Such)
This one has its own free-standing post already, but what the heck. 1974 pre-Kabuki (and pre-Submariner) Submariner. Rare to the point of possibly being unique and in drop-dead gorgeous condition. Was trying to get $160 for it locally because I have no good use for it (too many damned bikes), but no takers so I guess I'll have to keep it in the stable. Boo hoo.
#334
Here’s my MB-5. I bought it and a kayak with insurance money after a hailstorm totaled my car. (Got to keep the car too, which ran fine.)
#335
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 540 Post(s)
Liked 1,034 Times
My brother-in-law drove a dimpled car for several years. I'm not sure if he saw the Myth Busters episode, but he claimed to get better gas mileage.
#338
Quoted: 7 Post(s)
Last year I picked up
The groupset is surprisingly nice to ride and shifts excellently but I love old classic steel bikes with modern groupsets and was able to pick up a nearly complete SRAM Apex (missing brake calipers) for $40 and am thinking of building it up with this set.
What challenges am I looking at to build it up?
This is what I know about:
1. Hope the BB fits (or buy one, what size to get?)
2. Cold set the frame to fit a 130mm rear hub.
I would keep the quill stem, but might get a more modern style ergo drop bar.
- Cold set the frame to fit a 130mm rear hub wheel
- Hope my BB will fit (or find one that will)
#339
tantum vehi
Quoted: 1168 Post(s)
Liked 993 Times
You should definitely go with the SRAM group. To make it worth your while, I'll give you twice what you paid for the SRAM group plus shipping for the Athena group.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#341
tantum vehi
Liked 993 Times
Swap you for a nice set of vintage aero-ish tubulars laced to some sweet tri-color Huns.
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#343
Bikes: 2015 Velo Orange Pass Hunter, 1989 Bridgestone RB-1
Got my shredded dropout fixed and rebuilt my '89 RB-1. Today I took it out for a shakedown ride. I had forgotten how nicely it rides--better than I remembered it.
The biggest difference was swapping out brifters with Shimano Aero levers and Dura Ace 10-speed bar-end shifters. The drivetrain is Ultegra 6600.
Love this bike!
Love this bike!
#344
tantum vehi
Liked 993 Times
^^^Grant would be pleased.
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#347
Bikes: GT Pulse Track, 93 Bridgestone XO-1 & 93 RB-1, Ritchey Swiss Cross, Ritchey Road Logic, Yoshi Konno/3Rensho Specialized Allez, Cannondale Slate, Cannondale SuperSix EVO/Disc and Cannondale Hooligan
Quoted: 43 Post(s)
Liked 149 Times
Thanks Sliverexpress!
VeloCals bicycle decals - Quality, Durable, Ultra-thin
Their decal kit is missing the "CrMo" foil decal for the forks.
Anyone know where I can source it?
#349
Le savonnier
Quoted: 729 Post(s)
Liked 602 Times
