Toronto Fixed Part 2
#1851
It is nice to be able to go fast again in the last couple of days but the cars must feel the same way as I had a lot of close calls today. One guy must have been going at least 80 on Richmond. I pulled over because I could hear the roar of his motor a block away...******.
#1856
Dances With Cars
Bikes: TBL Onyx Pro(ss converted), Pake SS (starting to look kinda pimped)
32Flavours ....!?! Holy Crap!!!!!
#1857
Live without dead time
Shiftless bum
For any scotch drinkers, Aberlour's A' Bunadh is back in vintages. A nice cask strength Speyside single malt finished in sherry casks. Nice butter and caramel on the nose and palate. Very yummy.
Originally Posted by operator
truneo that tuned park internal nipple wrench work ??
#1861
Bicylisk
My trainer doesn't really sway or shift back and forth. I have the the connections to my rear wheel on tight. The other thing to note about is that you want to make sure there is a really tight connection with your QR. I have Bontrager on there normally which are flat, but I put on round ones for the trainer. They fit in to the trainer better so it's more secure.
#1862
Balls
it may work with your bolt-ons but it was designed to work with the quick release skewer supplied with it, so some knocking back and forth is inevitable, it'll be hard to get a connection that matches the quick release
it won't really matter how tight you get it vertically because the ends aren't the exact same size as the bolts anyways, so there will be horizontal play
you should be able to get it to the point where it's safe to use though, i used to use my cyclops trainer with my track bike and it wasn't as secure as my road bike but it was good enough
#1863
Bikes: 1994 Proctor Townsend Reynolds 753, TT S3 True North, Kona Major Jake, Kona Honky Tonk, Marinoni Puima, Cannondale BBU
Wow. I need to not let my bikes get so disgusting that cleaning becomes a physically demanding job. 2+ hours later, my Major Jake and Marinoni are in presentable condition again. Phew.
#1867
If any of you guys were on the old tofixd board (or even if not) I've set up a new temporary/permanent home here:
Yyzfixed.dailyforum.net
#1868
Non-drive shot, sorry. The long wheel-base takes some getting used to but I like having fender tabs; it is a solid ride so far. I swapped over all the parts from my Colnago Sport single-speed and now I think I will turn that bike into a CX bike.
#1869
I scored a used but perfectly fine Ultegra 9-speed group (minus wheels and brakes) for $75 today. I think everything will find its way onto my Battaglin since I already have some nice-ish Ultegra hubs laced to Mavix CXP30s just sitting in teh closet.
#1870
Wow, that's a good price!
#1871
track-fall
Has everyone just abandoned ship here to join TOfixed? The thread does not grow as fast as I remember it used to.
#1872
Yup, especially now that the weather has gotten icky. My road bike (built on that tiny Gardin frame I picked up from you all those years ago) probably got more miles this summer though.
FWIW, there's a lot of us on both boards, no reason to be an either/or thing
#1875
Did everyone know about Charlie's Freewheel program? I was listening to theCBC this morning and was surprised it was dedicated to Charlie from the bike forums.
https://charliesfreewheels.ca/
