Anyone Use A Suspension Seatpost?
Old 01-25-19, 01:53 AM
Quoted: 343 Post(s)
Liked 31 Times in 24 Posts
The redshift suspension seat post is delayed until June. Initially it was supposed to roll out this month. The date was pushed back to "early 2019." Now to mid 2019. I'd rather see them get it right rather than rush it's release.
https://redshiftsports.com/shockstop...nsion-seatpost
Also, the Chinese Ergon knockoffs seem to have disappeared from eBay.
The eesilk looks good. No reviews of this product.
For whatever reason, suspension seat posts aren't especially popular.
radroad is offline
Old 01-25-19, 08:59 AM
Bikes: 8
Quoted: 7607 Post(s)
get off the saddle
Or necessary...
fietsbob is offline
Old 01-25-19, 01:37 PM
Quoted: 1218 Post(s)
Liked 6 Times in 5 Posts
I have one of these on my road S-Works, and one on my gravel bike.
I went with this which Canyon uses on their upper end bikes since the Ergon is no longer available but quite a few copies are out there with good results from what I heard:
Ergon CF3 Pro Carbon Setback Seat Post 330mm / 27.2mm
Slick Madone is offline
Old 01-25-19, 01:52 PM
I am using a cancreek seat post on my ebike. It works very well, but its not a must have anyways.
Freerideking is offline
Old 01-25-19, 03:57 PM
Quoted: 343 Post(s)
Originally Posted by Convivial Panda
Reasons:
Constantly changing saddle-to-pedal distance
Constantly changing fore-aft saddle position
Weight
Rudimentary suspension action (no damping)
Folks have HTFU so they are unneeded
I share some of your concerns. That's why I ditched the LT thud buster. That thing was awful. Even maxing out preload it just felt inefficient pedaling. The constantly changing seat position was a complete deal breaker as well.
The redshift looks a lot better though. Who knows, maybe there's another delay in production and the thing doesn't debut until 2020?
I'm very interested in the Roubaix: futureshock and the lowered seat post clamp+ elastomer seem to be very effective. I'm hoping one of these seat post designs will be enough to prevent me from going all in on a $3.5K+ purchase!
radroad is offline
Old 01-25-19, 04:02 PM
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times in 1,164 Posts
The delays are disheartening, but I would rather they get it right the first time than be stuck with an obsolete prototype.
Cyclist0108 is offline
Old 01-25-19, 04:06 PM
Bikes: 8
I dont get it
Originally Posted by radroad
Yeah, I put in 1 class higher (stiffer) elastomers than recommended for my weight and nearly maxed out preload. The saddle tilts and arcs backward; that's what bothered me. It felt like I was constantly sliding off the back of the saddle. It's a very unnatural feeling and very inefficient for pedaling.
its a parallelogram so it may move back slightly , but still stay level..
Mine was when they color-coded density .. black for my 220 pounds purple was denser yet.. blue , for lighter
being round cylinders, you can stiffen them by not letting them get wider .. adding a hose clamp or some metal tubing around them
(Hose /Jubilee ..clamp a Brompton suspension block stiffening trick..
ST there is a bold dial ..arrow indicating 1,3,5,7,9, 9 the densest, 1 the softest.. I barely notice it moving using the 7 ( have the other 3...)
fietsbob is offline
Old 01-26-19, 09:54 PM
Quoted: 70 Post(s)
I use a Roubaix with FS, an Ergon CF3 knockoff, and 32mm tires. Very plush on rough roads. Great for century rides.
pdoege is offline
Old 01-28-19, 01:18 PM
Alligator's Avatar
Bikes: Too many. I’m constantly selling and buying new bikes.
Quoted: 90 Post(s)
Liked 36 Times in 24 Posts
I use Bodyfloat on all my bikes. Works very well and I wouldn’t ride without one except on my road bike. Definitely takes all the bumps out and makes for a much better ride. A lot less jarring.
Alligator is offline
Old 01-28-19, 08:24 PM
bogydave's Avatar
Bikes: /Skye/ Torker mt, Sirrus flat bar
Quoted: 188 Post(s)
Liked 24 Times in 10 Posts
Thudbuster on bike in Alaska, Kona rove
, mix of road/gravel riding
... But...
been getting beat up on the SoCal roads this year,
gonna bring it to SoCal next time. Test on
roads here, they are rough & cracked ( every crack
is a mini speed bump ... & there’s
many many cracks ) :-(
bogydave is offline
Old 01-28-19, 08:32 PM
Quoted: 343 Post(s)
Nice. What bikes? Do you feel as if these seat posts reduce pedaling efficiency?
​​​​​​​Awesome. :-) That's the nice thing about disc brakes: you can run a wider tire.
radroad is offline
Old 01-29-19, 05:15 AM
Alligator's Avatar
Quoted: 90 Post(s)
For the Bodyfloat, I use them on a hybrid and on an ebike. I don't feel they reduce efficiency at all, or even if they do, I can't tell. You can get them to move if you bounce on them, but mainly they just soak up the bumps and make things a lot softer.
stewclark
Tandem Cycling
36
06-29-20 07:30 AM
Paul Barnard
Mountain Biking
8
02-18-19 08:13 PM
milesofsmiles
Fitting Your Bike
9
08-25-13 12:54 PM
mtalinm
12
03-14-12 06:30 AM
GLA
Tandem Cycling
31
05-26-10 11:31 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
