Any other 1x road climbers here?
#77
Habitual User
Quoted: 5023 Post(s)
Liked 8,213 Times
Likes For Eric F:
#78
Bikes: GR300, Grail, Live Wire, 5010
Quoted: 189 Post(s)
Liked 241 Times
Likes For sarhog:
#79
Quoted: 7050 Post(s)
Liked 11,101 Times
I think we're saying the same thing. My road riding is all flat, and I don't need a big range of gears for that. For me, an 11sp 2x drivetrain running a 50/34 with an 11-32 is overkill, and I will have a dozen gear combos on both the high and low ends that I'll never touch. When I had a 2x road bike I almost never used the small ring.
I can run the same narrow range 11-32 cassette with a 44T 1x setup and have gearing that works very well for what I need. There's no compromise at all for flat road riding - the compromises only start when mountain climbing comes into the picture, which is what the OP is talking about. For that, I definitely would want 2x.
#80
Quoted: 1463 Post(s)
Liked 1,487 Times
That's a sweet looking bike. The 10-50 Eagle cassette with a 1x front has a 500% gear range, plus the fancy version is light (around 350g).
This is a bigger range (especially on the low end) than a standard road 2x setup.
For those wondering - it's 10-12-14-16-18-21-24-28-32-36-42-50 so yes... two tooth gaps on the small half. Bigger jumps on the big half. It's not for everyone.
They even make a 10-52 (520%) if you want some extreme climbing gears.
Likes For waters60:
#82
Method to My Madness
Quoted: 1984 Post(s)
Liked 1,501 Times
#83
Quoted: 3251 Post(s)
Liked 2,537 Times
#84
Liked 11,101 Times
When some folks claim that one 1x drivetrains are lighter, I wonder if they’re considering the giant-ass cassettes that some people end up with.
#85
Liked 11,101 Times
#86
Liked 2,537 Times
Through the 7-9 speed era, when Shimano had 2X and 3X systems within the same level, (105/600/Ultegra) I'd weigh each complete system. Everything down to the chainring bolts. If the 2X had to go 30T or bigger on the back to match the 3X range, it would be heavier than the 3X. In fact, a 1X version of the same system wasn't any lighter either. If you increased the range of the 3X by putting a smaller 3rd ring on the front, the weight difference would increase even more.
#87
Most weight weenies make too big a deal about a 100 gram difference in weight. To figure the effect, take 100 and divide by total bike and rider weight, like 80,000. The percentage is 0.13%. how many people weigh themselves in 100 gram or quarter pound increments? How many carry a few thousand grams of excess weight?
I always thought the reason for 1X was to avoid chain drops, but then I was told that I'm wrong. I use a 10-36 12 speed cassette with a 46/30 crank to get a 0.83/1 low gear.for a 552% range, without all the big jumps between sprockets. I use cheap shimano grx-610 cranks that weighs about 100 grams more than the 810 hollowtech version.
#88
Liked 1,487 Times
I ran a 12-23 cassette on my old nine speed bike, and some folks referred to that as a “corn cob.“ And it did not have one tooth steps.
By the time you subtract the FD and one of the chainrings, it's basically a wash or slightly in favor of 1x.
#89
Bikes: 2017 BMC Roadmachine 01 Enve wheels, Sram red etap,Cinelli Vigorelli single speed, 2009 Cannondale Capo, 2016 trek Domane 6.9, disc and Di2, 2016 Scott Scale 710, 27.5 plus tires and boost rims
Quoted: 110 Post(s)
Liked 203 Times
Ok, how about 1 x 1 climbing? Does that count? I am always the last to the top and the last to the bottom but I am usually the only one at least.
For you WNC riders: Highest area, and then just north of the Linn Cove Viaduct, running 38 x 23 gearing, freewheel, no fixie thanks! Descending is just a coasting experience, can't hook up over 10 mph, no issue unless you need to get away from some hunting dogs or the occasional Elk.
I did the climb from the top of Town Mountain road to Craggy Gardens the same week these were taken, lots of fog and lots of climbing for me. Stopping to rest a lot got it done. The Parkway stays about a steady <7% but sometimes just doesn't quit.
"ready to navigate"
"ready to navigate"
#90
Liked 11,101 Times
Some of the cheaper big-range MTB cassettes do get very heavy, but on the high end - the SRAM Eagle XX1 10-50 cassette only weighs 363g. Compare to a high end narrow range 2x road cassette is at least 210g. So, maybe 150g more?
Likes For Koyote:
#91
Habitual User
Liked 8,213 Times
Regarding ranges of 1x vs. 2x, this is a handy calculator that will allow you to compare 2 different drivetrain configurations... Bicycle Gear Calculator
#92
Liked 1,501 Times
Likes For SoSmellyAir:
#93
Liked 11,101 Times
After reading Koyote's post, I was going to chime in with a reference to Eric F's gravel bike from the So Cal forum, because the latter seems to have no problem riding gravel with a regular Ultegra (i.e., not GRX) RD. On the other hand, when I went 1x on my hybrid (which is only ridden on paved roads and MUPs), the chain would occasionally get pulled inwardly off the chain ring when it is on the largest cog, even though I had a chain line that bisects the cassette, so I had to add a chain keeper.
I'll also note that your chain retention problem probably comes from running 1x, which forces you into more extreme chainlines, at least some of the time, than would a 2x drivetrain. When that chain is at a more extreme angle, it seems to me that it's more likely to come off the chainring.
#94
Habitual User
Liked 8,213 Times
I can't bother keeping track of all of the different variants, but my Ultegra 11sp RD has a clutch, which helps greatly with chain retention.
#95
Quoted: 442 Post(s)
Liked 472 Times
bykemike Nice Capo. Now that's a dedicated climber setup. I didn't know they made SS freewheels in 28t (unless that's a road sprocket with spacers on a road wheel).
In my FGSS days 48x16 was a good puncher ratio for the city, while 44x17 got me up most climbs. I am very proud to have been able to slowly grind my way up Hwy 9 from downtown Saratoga to the Gap (for the Bay Area folks) on a 46x16 fixed gear once, 12 years ago. Can't imagine doing that now.
Likes For tFUnK:
#96
Liked 11,101 Times
Yep, I’ve done plenty of rough riding on a 105 setup which has no clutch on the rear derailleur. Can’t recall ever losing a chain on that bike, either. The main benefit of the clutch, from what I can tell, is actually that it prevents the chain from slapping against the chainstay.
#97
Quoted: 110 Post(s)
Liked 203 Times
"ready to navigate"
"ready to navigate"
#98
Liked 1,487 Times
Narrow/wide front rings provide better chain retention than shiftable front rings.
1x systems also allow for larger rear tire clearances, and have less things for mud to get gummed up in.
Shifting a 1x drivetrain is more simple, which is beneficial when navigating difficult terrain.
Of course some people prefer 2x for the tighter spacing and don't experience any of these problems (or don't feel a need to solve any of them, or find the trade off unacceptable). Shimano still makes front derailleurs for their MTB groupsets too and I know some XC MTB racers prefer to run 2x for the reasons you state. There doesn't have to be a one-size-fits-all solution here.
Likes For msu2001la:
#99
Liked 1,487 Times
Switching to 1x11 solved all of that for me.
#100
Quoted: 4481 Post(s)
Liked 4,952 Times
