ISO and for trade thread part 5
#3976
Quoted: 3822 Post(s)
Liked 6,772 Times
ISO: One adjuster barrel from a Raleigh soldered-end brake cable. Or a wrecked cable with one attached.
Apologies to @clubman for lifting his pic.
-Kurt
-Kurt
Likes For nlerner:
#3977
www.theheadbadge.com
Quoted: 2431 Post(s)
Liked 4,437 Times
#3978
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
#3979
Liked 4,437 Times
-Kurt
#3980
Old fart
Quoted: 3615 Post(s)
Liked 3,444 Times
FYI, if you're looking for those particular barrel adjusters, the adjusters from Simplex "Prestige" shift levers will work:
Likes For JohnDThompson:
#3981
Liked 6,772 Times
These were lurking at the bottom of that drawer. The ones on the right are the Raleigh rear brake stops. On the left are Simplex gear stops as JT points out. They fit the brake bridge hole but take some careful trimming of cable housing to get a good fit.
Likes For nlerner:
#3982
The dropped
Liked 1,014 Times
You mean these?
I'm using the Simplex adjuster hack at the moment with a step down ferrule to hold the brake housing. Because I opted for the VO braided cable, it's quite stiff and doesn't adjust easily, though it does work which is what matters?
the biggest complaint is that my fingers aren't dainty enough for that adjuster. The Raleigh adjusters look more useful, are they on offer?
#3984
Liked 6,772 Times
Yeah! Those!
Likes For nlerner:
#3985
Liked 4,437 Times
#3986
Industry guy
ISO Campagnolo Professional tool case liner.
The padded one with Campagnolo logo that fits into the lid of the case.
I know, its a long shot..
I have a case without the liner.
Would also be interested in a handle for same.
rusty
rusty
#3987
Quoted: 476 Post(s)
Liked 1,082 Times
However, it's been quite some time since I exploded a SA IGH.
#3988
Liked 4,437 Times
does it really need to be a cap as shown, or is the cap shape really just to facilitate doing lots of these per day at the SA factory? IOW could you just a properly sized steel washer? IIRC, you need a flat piece at the end of the spring to protect it from the part that bears against it. ID to fit over the axle, OD just right to prevent dragging on anything else. If, fact, when assembled that end of the spring does not ever move does it? The other end does. Hmmmm?
All things considered, I'd rather do it right on this particular project.
-Kurt
#3989
Quoted: 108 Post(s)
Liked 152 Times
ISO Speedplay Frog cleats - new or used
Looking for a pair of Speedplay Frog cleats to get me through to when Wahoo (now owner of Speedplay) has their supply chain sorted out.
My old cleats are worn out and the LBS that sells Speedplay told me it will be several months before replacement cleats are available. They seem to be sold out on-line too. It would be unfortunate if Wahoo stopped offering replacement cleats for the discontinued Speedplay pedals. I can understand discontinuing a product, but discontinuing the consumable required to use the product is absurd. Too many companies talk big about being environmentally friendly and then make decisions that make products obsolete.
Thanks,
James
Thanks,
James
#3990
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,451 Times
I thought about that. I theorize the cup shape of it is to keep it as close to a right angle against the axle as possible, preventing it from binding on the threads. Even the SRF-3 uses this design to this day, so there must be something about it that works
-Kurt
-Kurt
Likes For thumpism:
#3991
Liked 4,437 Times
#3992
Liked 2,451 Times
#3993
Liked 4,437 Times
#3994
Liked 6,772 Times
Likes For nlerner:
#3995
Liked 4,437 Times
#3996
Bikes: 1966 Paramount | 1971 Raleigh International | ca. 1970 Bernard Carre | 1989 Waterford Paramount | 2012 Boulder Brevet | 2019 Specialized Diverge
Quoted: 129 Post(s)
Liked 78 Times
ISO: Lyotard model 460 right hand pedal, French thread or...
I'm rebuilding a Lyotard 460 pedal. The right pedal body needs replaced, but my French thread spindle is good to go. Soooo... I'm in search of a pedal body, or a pedal with French threads. Let me know what you've got.
m
m
#3997
Quoted: 1116 Post(s)
Liked 1,339 Times
#3998
Quoted: 129 Post(s)
Liked 78 Times
#3999
Liked 1,339 Times
As for the Berthet pedals not cracking, yes the bearings are closer together and that helps, but the big difference may be that the body is one-piece (and steel). Their own idiosyncracy is the outer alloy end-plates wear against the threads at the end of the body, and when they've done this enough they start rocking and clicking. Fortunately the alloy is soft and forgiving enough that they can be tightened up with a ball-peen hammer.
#4000
Quoted: 572 Post(s)
Liked 1,064 Times
ISO direct mount short derailleur
Looking for something vintage-y looking. Square-ish, plated are ideal. FWIW it would be going on my ~1960 Legnano that originally had a Campy Sport if that helps you gauge the mojo I’m after. Thx all!
