Would you consider a Specialized Roubaix Sport to lean towards the endurance end?
Quoted: 12 Post(s)
I wanted to like the Roubaix and was set to buy it, but I couldn't get past the bobbing up and down with each pedal stroke in the short test ride that I took, particularly under acceleration. I'm a big guy with a lot of upper body and I think it was under sprung in the front suspension for my weight. Some models are more adjustable than others. The one I tested had a medium spring it I was told, so try to check out all the options if you can.
Much preferred the Tarmac (SL6 was the one I rode) of the two, much more direct feeling, but the difference in geometry was noticeable.
Quoted: 4415 Post(s)
Liked 4,867 Times
https://cyclingtips.com/2019/04/spec...t-ride-review/
Likes For PeteHski:
Quoted: 12 Post(s)
The higher end Roubaix models have a damper and lockout to solve the bobbing issue. But I haven't ridden one, it's just on my shortlist for an endurance bike. Reviews suggest the damper and lockout are a big improvement when not riding on cobbles all day!
Bikes: Focus Arriba, Specialized Roubaix Expert, Bianchi Impulso Allroad
Quoted: 109 Post(s)
Liked 82 Times
Edit to add: I'm 5' 8.5" and ride a 54cm Roubaix comfortably. (Had a 54cm Izalco, also)
Quoted: 12 Post(s)
I have the previous generation of the Roubaix (2019) and I love the Future Shock. Mine is 1.0 - No Lockout, and I've felt I've never needed it. With my weight of 180lbs, I upgraded to the Heaviest spring included by Spesh, and never looked back. On smooth pavement I don't notice any loss, even while climbing, sprinting out of the saddle, etc. But on rough pavement (most of my area in southern PA) I love the effect of FS to damp the rough patches and still allow great handling. Of course the 28mm tires don't hurt, either. After my ultra-stiff Focus Izalco, the Roubaix was a revelation-- and despite the Roubaix being over a pound heavier, my average speeds are up on all segments except extended climbs. And the comfort difference over extended rides is also huge.
I'm fortunate to have good roads/trails here, but fully acknowledge I might've gotten used to the bounciness or not noticed as much with the stiffest spring installed.
Accept what you want. You have been riding for quite a while it looks. If you think that there is no difference between a bike with race or endurance geometry, I don't know what to tell you...Endurance geometry bikes don't have low stack. It is their main defining trait...That and a steep head tube angle. I suspect you already know this and just want to argue though...
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
I am considering a similar route of going from my Synapse, which I have gotten very used to over 4 years, to a Super Six Evo of the same nominal size.
Likes For SoSmellyAir:
I'm 5'10" with a 30" pants inseam, and my Roubaix Comp rental back in 2019 was a 54 - felt fine. Obviously, one 40 miler afternoon is different from owning the bike, but it didn't feel overly short in either stack or reach.
My Lynskey is an M/L, with a 557mm top tube and 575/382 stack/reach figures. It occasionally feels a bit 'big' in the sense that I run the stem with 5mm of spacers, and could sometimes go lower.
I have a CAAD8 in 54, which feels really small with an 80mm stem (the only one that I have spare at the moment). I've ordered a 120mm stem to match the reach of the Lynskey (which has a 100mm stem). Stack on the two is similar, with the CAAD8 running 20mm of spacers.
One other thing to look out for is that the hoods on hydraulic brake equipped bikes are huge - both in terms of length as well as the 'horn' area at the very front. If you ride on the hoods a lot, and you're coming from a non-hydraulic bike, you may want to take that into consideration.
All this is to say that you will likely have an easier time adjusting a small bike to feel one size bigger, but you're a bit more stuck if you want to make a slightly larger bike feel slightly smaller.
Liked 1,471 Times
Depends - if you're running a 130mm tiller right now, you could go with a 110mm and come pretty close to the same reach (14mm reach + 5-8mm longer hoods). If you're already on an 80mm stem, then I understand how it wouldn't work so well...
Liked 1,471 Times
No, I am on a 100 mm, - 8* stem, and going to a 80 mm stem seems inadvisable.
Pizzaiolo Americano
I'm a fair bit heavier at 230 lbs and most of that is in my long torso. I'm 6'5" and end up with a lot of weight on my hands w/most seat setbacks, so it amplifies the effect.
Likes For Pizzaiolo Americano:
Quoted: 57 Post(s)
Liked 8 Times
If I end up ordering a bike I might spring for the Synapse Carbon (over my wrecked Synapse 105) but gosh to wait a whole year for the bike! I'm 58, a year means a lot more to me than it used to.
Liked 1,471 Times
Synapse Carbon 105 | Endurance Bikes | Cannondale
Bianchi Infinito Ultegra 11sp | Bianchi Bicycles
Quoted: 57 Post(s)
Liked 8 Times
Unfortunately I can't pick what I want. I have to choose amongst the LBS meager offerings or order and wait a year. I had considered upgrading the wheels on my Synapse, in light of what happened, glad I didn't. When I looked at wheel upgrades at local LBS, the only ones available that was considered worthy were $750 each. I do still have a bike, my tried and true 20 year old Trek 7500 hubrid.
I am sorry your bike got wrecked; I hope you are OK. I am 5'-10" and my size 54 Synapse Carbon (2016, so prior model) fits me very well, plus I have upgraded the wheels and a few other components, so I am quite partial to it. But a whole year is a long time to wait if you do not have another bike. Perhaps you may also consider a Bianchi Infinito. In size 55, an Infinito has almost the same geometry as a current model Synapse Carbon in size 54. Both reach and stack and within 1mm of each other, and the seat tube angle differs only by 0.4 degree. Plus the Infinito similarly relies on the frame for dampening without any displaceable suspension components.
Quoted: 109 Post(s)
Liked 82 Times
I get their weekly emails and they still and they are adding (sometimes hundreds of bikes!) to their inventory daily. If you want a bike now, I'd suggest you give them a shot.
The Pro's Closet
I like speed
I stuck some S Works Turbo 28's on a pair of Zipp 303's for the the Roubaix and it's like riding a cloud; cracks in the road seemed to disappear.
Likes For oris:
Quoted: 57 Post(s)
Liked 8 Times
Test rode a 54cm Roubaix Sport and a 56cm Roubaix today. I could get used to either size. Bike shop guy said from looking at me, neither looked out of place so depended on my preference. I decided at my age, sitting up a little higher on the 54cm and seeing more of the road in front of me was not such a bad thing. The regular Roubaix comes with Tiagra shifting and it seemed to me, the 105 of the Roubaix sport shifted smoother. I thought both bikes rode smooth and soaked up bumps well - better than my Synapse 105. Not sure if because of the frame geometry or the carbon frame vs Synapse aluminum. I did not find the headset suspension to be too "boingy" and it comes with a set of different thickness replacement springs.
So I put down a deposit on the Roubaix sport. Will pay it off when the insurance money comes up. Hopefully this time, it will be my "last bike ever".
Liked 4,867 Times
Likes For PeteHski:
Quoted: 57 Post(s)
Liked 8 Times
Saddle height was adjusted for leg length on both bikes. My back angle was lower on the 56 cm. Not sure about stem height, I think both were about the same. If I could pick exactly, I think I would pick 55cm.
Quoted: 57 Post(s)
Liked 8 Times
Quick question on frame height rather than start a new thread. My friend let me borrow his 56cm "winter bike". When I straddle the bike directly in front of the seat, while I can put my feet flat on the floor (wearing socks only), the top tube pretty much comes up all the way to my crotch or very close so. When I straddle my old 54cm bike in the same manner, there is a good couple of inches clearance between the top tube and crotch. Which is supposed to be more correct for the proper size?
Once you know you can stand over the bike, the next three things are saddle height (as dictated by how much you can extend your seatpost), reach (horizontal distance to the handlebars), and stack (vertical height of the bars). The different sizes ought to have different baselines for reach and stack - ie, if you put the same stem with no spacers on two bikes in the same line, the smaller bike ought to be a little lower in stack and a little shorter in reach. All that goes out the window when you start comparing bikes across lines with different geometries - race oriented bikes tend to be long and low, endurance oriented bikes tend to be taller and less long - so for those, knowing what your body can work with is most important.
Liked 4,867 Times
There is no right answer here, it's what you feel most comfortable with. Pro racers tend to size down on their frames for a more slammed position and responsive handling, while older/less flexible riders might size up for a more upright position and stable handling, especially if they are looking for an endurance fit. Personally I sit right between a 58 cm and 56 cm frame, but I always size up for a slightly less aggressive position for endurance. But I'm not naturally very flexible and have relatively long legs, so a 58 cm usually fits better.
Liked 1,471 Times
I am 5’ 10” with a long torso and ride a 56cm 2017 Roubaix Sport SL4. It’s a very comfortable bike and for my now 64 year old body I appreciate that. Mine has the 105 drivetrain which works flawlessly.
Of interest, when new it was quite harsh. The carbon frame is stiff and I was inflating the tires to old school pressures of about 110 psi. Once I backed off to 80-85 psi it changed the game. Overall the geometry is comfortable and stable. It doesn’t turn like my old Bianchi Virata but that’s fine.
