Circa 1955 Phillips Step Through SA Dyno-Three Hubs with Working Lights! PHOTOS HEAVY
#201
Nice work!
The reason the wheel is a 3-cross on the Dyno side is the hub is a little stronger there due to the larger diameter. Since torque is transmitted through the body of the hub, the crossed spokes are there to make things stronger- the concern is failure of the hub body. That's why its a 4-cross on the drive side and that is also why the unit mounts on a 40-hole rim instead of 36. Its all about durability. Sure- the American 3-speeds usually ran 36 hole but they were thinking about it a different way- more as a toy and less as something that was meant to endure for half a century or more.
In practice you can have almost any pattern you want on the non-drive side. I have a radial pattern on my 4-speed on the Dyno side. But on the drive side its a 4-cross.
The 4-speed in this configuration (Dynohub) is rather rare. If you want to talk about something finicky and arcane that's the one...
So, would you keep the lacing the same, for the sake of keeping an old English look?
As an aside, I weighed the steel, old front rim alone and it weighed 885 grams - just over 1.9 lbs!!! Not to mention that the hub on the axle felt like a solid paperweight!
#202
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
I'm impressed at your methodical and fearless approach to new things. The bike looks sweet.
Just a little touch - I think some long leather mudflaps would be nice, and useful. Oregon Leather on 2nd downtown has big bins of scrap leather, all weights and colors.
#204
Quoted: 478 Post(s)
Liked 634 Times
So, Sheldon Brown, as well as Sturmey Archer highly emphasize that before you remove the ball ring (from a SA IG hub) you mark the bike AND the ball ring, because there are 2 notches at 180 degrees from each other. There is a double thread to get the ball ring started so it's important to start it in the correct position. Well.....the first time I disassembled the hub I did mark the bike, but did not mark the ball ring. Neither Sheldon, nor Sturmey Archer go into much detail about what happens if you should accidentally start the ball ring at 180 degree starting point when threading. Well, I found out. I had trued the rear wheel prior to hub work and noticed, after reassembling the hub, that my wheel was miraculously "out of true". I fixed it but could not understand what I had done to make this suddenly happen. After all, I did mark the frame for where the ball ring notch was supposed to start. I figured it out yesterday, that I must have started threading the ball ring at the opposite notch. According to further research, this somehow due to threading, would cause the wheel to be "wobbly". Also wondered if it was contributing to the less than perfect shifting my hub experienced after the first rebuild. I rectified the situation tonight (don't know that I needed to but figured I'd put it back to original position), and of course had to re-true the wheel.
So, before removing the ball ring mark the bike AND the indentation and make sure to align them upon reassembly.
Also, in my limited experience I have substituted entire insides and/or a variety of parts from donor hubs (including changing ball rings) without any noticeable issue, so I am interested you actually experienced a noticeable change by getting the ball ring onto the "wrong" thread. And I can say for certain I have never retrued a wheel because of the disassembly of a hub. Of course I may be a bit of a barbarian!
One of the issues I was worried about for the Humber - if I did that I would need to lose the patina and repaint! All is safe for now - just cleaned up the original rims.....
#205
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
Bob
Bob
#206
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
Nice work!
Re the 4-speed FG dynohub, I have at least two of them hanging around and another three or four FW hubs/wheels. Recently I acquired another FW dated 53 4 with an alloy shell that will be used with on my newest project.
#207
Liked 10 Times
I believe @Salubrious was saying is his rear Sturmey Archer IGH/Dynohub is the FG, a variant of the FW 4 speed hub. The FW is the four speed cousin of the AW. The FG is the 4 speed cousin of the 3 speed AG. Hopefully that all made sense.
#208
Quoted: 7351 Post(s)
Liked 2,478 Times
I don't believe @Salubrious is correct about why Raleigh chose the spoke patterns they did. I suspect it had more to do with economical reasons. More spokes do make a wheel stronger, but 4x is not proven to be stronger than 3x, and Brandt discusses this in his book. When choosing between 4x and 3x, use whatever is more practical, such as whichever lengths are on hand.
4x is not at all more troublesome to lace than 3x. I happen to like the way it looks better, and that's as good a reason as any for me to prefer it, and I don't delude myself into thinking it makes a more durable wheel.
So you might want to replicate the spoke pattern that is original, for sentimentality's sake. I don't expect it to be any trouble. And you might find that both sides use the same length! If so, that might be the reason Raleigh did it that way.
This has been one of the most fun threads on BF for a long time. I hope you know why. I think you should consider editing all of your posts and making a single blog post of it or maybe even see if you can get it published in a magazine.
Brandt is still alive, last I heard, though he is severely disabled. It's sad to me. He did have a short temper and sometimes insulted those who doubted him. He was kind to me, though I confess I spoke with him very carefully. He was a mechanical engineer, though of course, he had to have a lot of physics background. His book The Bicycle Wheel was the first to debunk a lot of myths that pervaded bike folklore, and we owe him gratitude for that. He was the first, as far as I know, to measure what is actually going on in a wheel. The laws of physics that apply have been known for centuries, of course, but which ones apply was not known. For example people had been saying that longer spokes make a wheel that rides with more flexibility. This is not true, because we don't load the spoke laterally in the way we stand on a diving board.
#209
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
^^ Did Raleigh's designs predate Brant? I bet they did.
I agree that it is not necessary to do a 4-cross; but I'm pretty sure that strength and smoothness of ride are why Raleigh did it, even though neither result was the outcome as history and Brant have shown. But the bikes were fashioned in a very conservative manner!
When I have built wheels for my Rolhoff hubs, the manual is very careful to state that radial patterns will invalidate the warranty. I would imagine the the Sturmey Archer engineers may have had similar concerns way back in the 1930s or earlier...
This has been for me one of the more interesting threads in a while as well. Its really heartening to see someone jump in with both feet and tackle some of the more arcane and advanced procedures you can deal with in a bike. Kudos!
#210
@markk900 - yeah, I'm not 100% convinced that turning the ball ring on at 180 degree difference would have made such a difference. I've noted the spoke tensions on the rear wheel are sort of varied (by feel), so perhaps the moving around of the wheel, hub, etc. loosened some of the spokes and caused the wheel to become "off". I will say that, last night, after reinstalling the ball ring back to its original orientation, my rear wheel was out of true again. Later I will check the tensions on the rear wheel and get a feel for where things are at.
@PastorBobinnh - Oh, OK, I understand what @Salubrious was saying. Thank you for the clarification.
@noglider & @Salubrious - thank you for the compliments on the posts and on this thread, but the "strength of a thread (forum thread) is only as good as its weakest link" And in this situation I am the weakest link. You all have been extremely helpful, supportive, funny, educational, and overall a great group of people to help.
Referring to what @noglider said, I don't blog and not sure what magazine would want anything I've written on here. I do hope that when someone finds an old bike and has the inclination or the curiosity to fix it up, and when they do an online search, this thread will show up and answer some of their questions.
My my next project for the bike will be to re-do using JB Weld to attach a piece of brass tubing on the end of the shift wire so that I can reinstall the original "barrel adjuster" sleeve. I did it, waited 24 hours for it to cure, only to find it was 3/4" too short! I will build a rear wheel and am fairly sure I will keep the spoke pattern original. Don't want to make so many changes as to loose the charm of this old beauty.
The lever on the original Phillips labeled bell broke so I want to fix that - I believe the innards are riveted. Let me guess....learning to rivet is in my near future? Also the chrome rim between the front lens and the light body does in fact have a dent, which causes the lens to sit awkwardly in the lamp. I've been thinking about how to tap out the dent without making it worse. Please offer ideas. The chrome piece is curved in two planes, thinking of a short piece of hard hose to lay in the chrome piece, then gently tap on the hose. Thoughts?
#211
Liked 2,478 Times
Don't be silly. You're far from the weakest link. Your perseverance are impressive. You didn't know everything, and that is your triumph, because you're putting it all together. Look, I've been a mechanic of one sort or another for 40 years, and you're doing some things I've never done, such as using JB Weld. I've also done most of the jobs that you're doing on this bike but never all on one bike.
Remember how you were doubtful as to whether you should even buy this bike? Look how far you've come!
#213
@noglider & @Salubrious - I mean that the reason this is an interesting thread is because of ALL of us - everyone who contributed. It's a group effort. OK, I'm going on a shake out ride.
#214
Liked 2,478 Times
Fair enough. Let us know how it goes!
#215
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
The SW was a good idea that didn't quite translate into a good product. It has a slightly wider range than the AW and theoretically better load handling. Fewer parts and no pawl springs make it easy to overhaul. But those springless pawls didn't catch reliably, and the colder the temperature, the less reliable they became. I rode one for a while but had to switch back to an AW when the temperature got below about 40°F.
#216
Liked 10 Times
#217
Quoted: 887 Post(s)
Liked 335 Times
VelociVixen - what noglider said above. You have done an amazing job.
#218
Old fart
Liked 3,401 Times
Yeah, that's my "spare wheel" now. When I get a flat and don't feel like fixing it right away, I just stick that wheel on the bike -- provided the air temperature is warm enough.
#219
A couple things happen with the old English configuration. It turns out that the length of spoke needed for 32 spoke wheels with small flange hubs and 3X is very close to the same length as 40 spoke wheels with medium to large flange hubs and 4X. The other thing is that with 40 spokes and moderate flange size and 4X, the spokes end up very close to tangential and differences in spoke circle diameter and flange width have only a minor affect on spoke length. Very minor. You can see this either by looking at the equations in the Brandt book or playing around with the spocalc spreadsheet (which appears to use Brandt's equations).
So, why 3X on the dyno side of the hub? Well, the dyno side is really honking big. According to the database in spocalc, the three speed side is 65mm diameter and the dyno side is 101 mm dia. You probably can't build that size flange in a 650A (578 mm erd) wheel 4X without going beyond tangent with the spoke line, which would be undesirable, and having spokes interfere with adjacent spoke heads.
So, the old English configuration meant that the wheel builders only had to deal with one spoke length for both front and rear wheels and moderate variations in rear hub dimensions didn't change the necessary spoke length. With the exception of the dynohubs, all the 650A wheels required the same spokes.
#220
My my next project for the bike will be to re-do using JB Weld to attach a piece of brass tubing on the end of the shift wire so that I can reinstall the original "barrel adjuster" sleeve. I did it, waited 24 hours for it to cure, only to find it was 3/4" too short! [...]
#221
The ride quality was nice - cushy like a Cadillac. Reminded me of riding my1974 Motobecane Grand Jubile, only felt more "grounded" - maybe the weight. Still nimble though. Was able to remove my hands from the handlebars & pedal and the bike tracked well. The tires are inexpensive Kenda K40, so they're not the cause of the cushy ride. Maybe the curve of the fork helps absorb the road bumps. I adjusted the saddle a little, and loosened the shift cable a tiny bit. Other than that it rides nicely. The saddle is great but not the right shape for me. I do better with saddles shaped like a B17 vs the saddle which is wide & my upper hamstrings rub the saddle edge as I pedal - like it's too wide. I also really enjoy the 22T cog. Good advice on that. Here are a couple of photos of my 6 mile journey.
Last edited by Velocivixen; 01-27-15 at 10:52 PM. Reason: spelling correction & added photos
#222
Are you kidding me?! I didn't think of that. I tried moving the shifter closer to the stem but it didn't really help. So you're saying all I had to do is move the fulcrum clip? OMG I wish I would have been able to understand that. I ended up taking it all apart & installing a new shift cable, new heat shrink tubing, the whole set up. Oh well.
I know you understand all this and I apologize if I'm taking too many words to explain the obvious. It's not my intention.
#223
Quoted: 359 Post(s)
Liked 265 Times
You might consider a Brooks B-66L or B-66S. The 'L' is no longer made- obviously the ladie's version; it is replaced by the S. I find the leather saddles to look classier (and of course arriving in style is a big deal) and usually more comfortable than the more pedestrian style on the bike right now. But before that, make sure you have exhausted all the seat positioning issues.
You can also move the pulley on the seat tube to get a little more cable length- or shorten it.
The bike looks really nice!
#224
Thanks! Too bad the paint is faded mostly. The parts which were really caked in dirt are not so faded. Oh well.
I'm expecting some new (for me) handlebars for it as well as an English frame pump. Very excited about those. The chrome on the new bars is nice too.
#225
Quoted: 359 Post(s)
Liked 265 Times
Don't worry about the fading! Just do your best to take care of it. They are only original once. My Humber Sports is pretty faded too, with scratches. I thought about repainting and new decals, but the decals on the bike are different from the re-pops. Which might mean its a more interesting example... so its staying original. In your case, the bike is certainly rare and from a nice period- the 50s- and before Phillips got bought out. That makes it interesting!
