Best multi-tool ..
Quoted: 1514 Post(s)
Liked 735 Times
If I can't take care of it with a basic multi-tool, I'm in deep doo-doo because I didn't do proper maintenance at home. Anything with separate bits is a non-starter because the first time using it on the roadside, it's guaranteed to lose parts into some tall grass or leaf debris that's inevitably there.
Likes For BlazingPedals:
Quoted: 146 Post(s)
Liked 171 Times
I have this: Big Switch Ratchet Multi-Tool | Blackburn (blackburndesign.com)
But I usually do not carry that. Instead, I carry the minimalist SV Pro 5: LEZYNE SV PRO TOOL | STAINLESS STEEL BIKE MULTI TOOL
Just enough to remove the through axles.
Anything could happen on the road ,
It's nice to have something to work with ..
Say something worthwhile or shut the H..up !!
Quoted: 369 Post(s)
Liked 424 Times
What's best totally depends, primarily, on which fasteners and components you have on your bike. For example, if you've a modern bike which only uses Allen and Torx bolts, you don't need a tool with a hex wrench. Similarly, if you have SAE fasteners, a metric spec tool will be pretty useless.
So, what kind of bike do you have?
Habitual User
Quoted: 5039 Post(s)
Liked 8,273 Times
I don't like tools that use small 1/4" drive bits. I tend to fumble and drop things like bits, and losing the bit you need to make a necessary repair could add up to a long walk back to safety - especially in the dirt where little things disappear easily. I prefer a folding multi-tool that includes a chain breaker.
I carry a Crankbrothers M-17 multi-tool in my MTB and gravel bike kits, and a Blackburn Switch 8 set in my road bike kit. I like the Crankbrothers tool better than the Blackburn set. Now that I'm thinking about it, I should probably buy another M-17.
Likes For Eric F:
Habitual User
Liked 8,273 Times
BlazingPedals is spot on, IMO. Tools with small pieces are an open door for losing those pieces when you really need them. I've been there, and done that.
Likes For Eric F:
I ask for what tool "brands" that people actually used and their experiences ..
I didn't ask for how to use them
STOP lecturing me NOR others .. !!
Habitual User
Liked 8,273 Times
Also...
Lighten up, Francis.
IMO, it was helpful information on why someone might select one type of tool or another. If that info wasn't helpful to you, so be it. However, there may be others who read this thread and find that info to be useful for making their own decision.
Also...
Also...
Habitual User
Liked 8,273 Times
Likes For Eric F:
Habitual User
Liked 8,273 Times
Some people gave specific tool recommendations based on their actual experiences. Other people shared their reasons why they made a decision about one type of tool vs. another, based on their actual experiences, which is pretty much spot-on with what you asked for in your OP...
None of that is "smart ass" or ego-driven. It's just sharing knowledge based on experience, which is what discussion forums are about.
Likes For Eric F:
Quoted: 4847 Post(s)
Liked 3,980 Times
I don't see anything about Eric F's post that is a lecture.
Quoted: 7069 Post(s)
Liked 11,144 Times
Likes For Koyote:
I, too, like the Topeak Mini 9, although I don’t really need the 8mm for pedals— mine never have come loose in decades now, even though I change them frequently, moving my power meter pedals between bikes— but I carry it on my gravel bike for the SRAM Force crank fixing bolt, which did come loose on the road once. I’d failed to torque it properly on install, so that was more on me than anything else.
Likes For Turnin_Wrenches:
Habitual User
Liked 8,273 Times
You created the problem you’re complaining about. Maybe discussion forums aren’t the place for you. Good luck.
Likes For Eric F:
Likes For bboy314:
Clark W. Griswold
Quoted: 4435 Post(s)
Liked 4,084 Times
Why the aggressive behavior? I am baffled why someone comes here asks a question gets good answers and then goes off the rails and starts attacking people? It is weird. I certainly have seen where people can be harsher than needed but there wasn't any of that here. Take a nice deep breath, relax and go ride a bike for a while. No need to be so negative especially not over multi tools of which there are a multitude of.
Likes For veganbikes:
Method to My Madness
Quoted: 2025 Post(s)
Liked 1,519 Times
Liked 1,519 Times
Over Thanksgiving, my nephew 3D printed me a bottle cage mount for the Lezyne SV Pro 5, which will be installed in the third bottle cage mounting position under the down tube.
Likes For SoSmellyAir:
Building on Chaadster and Blazing pedals, maintenance can make any multi tool better. Given that they are all less ideal than regular workshop tools, the best multi tool is one you never have to use.
Quoted: 7666 Post(s)
Liked 3,537 Times
I carry links in a separate package ... I know myself, and I know I would pull out the tool, drop the links, and be stuck on the roadside in knee-deep grass looking for them for an hour ... probably at night and in the rain. (A selection from the "Been there, done that" line of uncomfortable cycling experiences. )
