Tires: How old is too old?
Quoted: 5227 Post(s)
Liked 3,598 Times
they would probably start giving you some clues before going. like some separation somewhere on the exterior carcass but why wait for that. getting new tires is fun!
Quoted: 1861 Post(s)
Liked 664 Times
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
There are obvious environmental variables that can play havoc on rubber, but I have a spare touring tire that's 8 or 9 years old and it's still good to go for a long time yet, at least another 5 years.
Regardless of what they look like, I replace bike tires when they hit 20 years old.
Quoted: 1372 Post(s)
Liked 1,753 Times
I installed these NOS gumwall Pasela tires on my Jamaica Bianchi a couple of years ago. Though they looked great, much to my dismay, they failed miserably and had to be replaced immediately. Old tires..? I doubt that I will ever trust them again...
Bikes: Colnago Super, Basso Gap, Pogliaghi, Fabio Barecci, Torelli Pista, Miyata 1400A
Quoted: 316 Post(s)
Liked 13 Times
When I bought my 91 Miyata 1400A, it had the original Miyata branded 700x20 tan walls on it. They looked pretty darn fresh and I rode them for a few months, fast and hard with no problems. But I thought I might be pushing my luck so I went ahead and changed them - twice! - with good quality 700x23s, and the bike just felt dead! Neither of the new set of tires performed nearly as well as those old Miyata tires did. Its almost as if the bike was built around those original tires.
I still have those tires hanging up in the garage, and I have been tempted more than once to put them back on!
Liked 1,753 Times
aged to perfection
Quoted: 840 Post(s)
Liked 1,271 Times
think about the tubes too, becoming brittle. A flat is one thing. A blowout on the front "bang !" will take you down. It will hurt. If you are going downhill at speed, it will likely hurt more.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
If anyone has tires more than 70 years old please PM. Better rubber back then. Often rideable. Though that is not the reason for seeking out the old ones.
Quoted: 324 Post(s)
Liked 81 Times
I disagree with older rubber being better stuff, I've been riding mountain roads for over 30 years, as the tires got better year after year handling got better than older tires, newer tires last a lot longer in mileage wear, plus the newer tires are more resistant to flats and cuts, especially this last 5 years or so crop of tires are almost immune to cuts yet handle very well. I'm older guy, I've seen the cycling world change over the years, and some of those changes were not good, yet some of them were like tires. The only thing the older tires have over the newer ones is ride comfort, but that's because the older tires didn't have flat belts, and when they did come out with them they weren't as thick or just one ply of flat belt instead of several plies, that thicker belt or more plies lends to a bit harsher ride I think...unless it's just my age doesn't like the harsher ride like it use to! LOL!!! either way newer tires are definitely way better then they use to be years ago. I think silca being put into tires these days has a lot to do with the gripping performance. If you want to experience the feeling of tires of era gone by simply pick up a pair of Specialized Turbo Cotton belted tires, the rubber tread is much better than it was but the cotton belt is the same, if you really want the best feel of an era gone by find a pair of silk belted tires with no other belts of some other material in the tire; of course these cotton and silk tires are very expensive and they don't last long, but tires in the older days didn't last as long as they do today anyways.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
For what it's worth, in the last few years I can only remember two tires that failed catastrophically. Both were front tires, and both tore at the sidewall-bead interface. Luckily neither one caused a crash, but it's still scary. One was a fairly cheap Michelin, the other a Panaracer Col-de-la-vie 650b. And both were basically new tires, less than a month old, and neither showed any wear or signs of other damage.
The bead under tension is much like a hard edge having a small radius, thus able to concentrate force at a tangent contact area of the bead, thus potentially severing the fibers of the casing, with resulting separation of the casing from the bead under inflation pressure tension.
Even when using a sliding motion with a tire iron along the rim and tire bead, I've seen the cloth chafer strip shear right off, and have seen the rubber peel away on tires that have no cloth chafer strip along the bead edge. An aged tire will be particularly vulnerable to such damage.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
Tubes can last a surprisingly long time. They are protected from UV rays and ozone by the tires, with only the valves exposed. The tubes in my 1960s Armstrong are older than I am and feel just fine.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
That sort of damage, if it is where the plies wrap around the bead, is often caused by the pinching action of tire levers on the casing fabric.
The tires that failed on me, though, were new. In fact I don't think I had ever used a tire iron on either one.
Quoted: 8 Post(s)
new tires are cheaper than dental work. I feel the same about some hardly used road tires for my cross bike. Probably not worth the hassle unless used for a trainer
Quoted: 324 Post(s)
Liked 81 Times
A huge percentage of tires that go flat don't blow suddenly, they gradually leak air out; plus if you don't know how to check out the condition of a used tire then you probably haven't been riding very long which goes back to your fear of busting out teeth in a blowout which would be due to your lack of experience to control a bike.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
A few years ago, I was cleaning out my parents garage. I found a bike tire hanging on the wall. I put it there about 1968. All the oil in the rubber came out and made spots all over it. It was similar in feel to engine oil. I grabbed the tire and the rubber almost fell off the casing like dust. I say that's too old.
gr8fzy1
Recreational & Family
4
10-04-10 03:35 PM
