Ishiwata Trek Fat Tire Project
Quoted: 1858 Post(s)
Liked 664 Times
More progress!
Drilled the front and rear brake bridges to allow recessed nutted brakes. Usual process, no problem with the right tools.
I have had sets of the TRP mid reach brakes in black, but never a pair in silver until today. dang. these are really elegant, nicely finished brakes. big fan!
Liked 664 Times
More progress!
Lost
Drilled from the seat tube side. I used a right angle or "close quarters" drill and I cut the drill bit down to be very short, about an inch sticking out of the drill chuck. Just enough clearance to get the job done.
https://less-than-epic.blogspot.com/
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
Isn’t it an even cheaper solution to cut a pair of brake cable outer housings (or just one if you only really need to guide the FD?), hold it under the BB shell, thread in the FD or RD cable, and attach the cable and adjust it? You’ll still need a bottom cable housing stop at the end of the DS chainstay. But if you kept scraps of outer brake cable and bought the lined stuff, like Jagwire, that part of the project should be essentially free
Anybody care to give firsthand reports if you've done just that?
I would be a little more confident that you could get away with the "unsecured" housing for the FD cable IF you used a FD with built-in housing stop, such as the old Sun Tour the OP has shown. At least that's going to anchor the housing a little bit on one end.
Quoted: 2364 Post(s)
Liked 1,751 Times
I'm still confused whether there's even an issue. As said in post # 7, the original FD is bottom-pull, using the existing DT-mounted housing stop (it's actually a stop for the FD and a guide for the RD), and a housing stop on the FD itself. Why will that not work? You seem to conflate bottom-pull with under-BB routing, and the two have nothing to do with one another. The entry- and mid-level Treks up to about '82 had bottom-pull above-the-BB cabling, as did many others of that period.
Lost
drill baby drill!
2nd bottle cage successfully installed! A little unnerving to take a centering punch and drill to a bike frame, but progress and all.
Likes For AngryScientist:
Lost
Lost
The shifty bits are sorted!
>Big barrel DT shifters
>XTR RD loaded with upsized Hope jockey wheels
>Suntour FD
This brings the tally of holes drilled in the frame up to 6
1+2) ST bottle cage mounts
3) Fork crown
4) Rear brake bridge
5) Drilled and tapped hole for under BB cable guide
6) Drain hole for BB
Next up: Brake levers and cable routing once parts arrive.
Getting close to the road!
>Suntour FD
3) Fork crown
Lost
And this one is done. Came out pretty well I would have to say. Just under 20# complete.
