Ultegra shifter REPAIRED???
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
I'd expect to pay $190 tops for a single brifter from the LBS since the MSRP is $364.99 for the set
$250 for a single lever is price gouging, aka, profiteering. Unless that includes the other lever.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Señor Member
MOST places will tell you that these can't be fixed, probably because it is difficult and time-consuming, but replacement parts are available from Shimano. The mechanic at my LBS will repair damaged Shimano shifters.
100% USDA certified
Liked 6 Times
check your cable housing. your parts could be fine, but worn out housing or the housing ends getting ground down can definitely affect shift performance.
as for STI servicing - your best bet is usually to pull back the lever, take a spray can of lube and really douse the **** of out the inside. believe it or not, it works (or at least improves performance).
that bike nut
Bikes: 2010 Motobecane Immortal Force 90' Trek 1400; 90' Trek 850; 06' Trek 520; 01 Iron Horse Victory
Quoted: 25 Post(s)
I remember hearing about someone having success by taking it to a place with a sonic parts cleaner. Try WD40 or some other penetrating oil then lube with triflow.
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
I'm glad you can get parts. Shops I've been at could get the plastic base, hood, faceplate, external spring, and the main lever/shifter assembly. However, not any of the parts within the lever/shifter assembly individually.
Who is Austin Dunbar?
Good luck finding a frame these days that has down tube shifter bosses installed. Most new frames have cabel stops upt by the head tube but no real bosses designed to take shift levers. I have a touring frame that has them so I put down tube shifters on it. It made sense on my touring bike because there is a lot less to break out on tour with down tube shifters.
