Hot r Not
Hot r Not
Old 12-26-13, 05:34 AM
  #17326
robbyville's Avatar
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times in 156 Posts
True enough. This is pretty much the saddle position I was put in but I have played with tilt some and I'm sure I've messed up position on rails a trifle. Stem length, spacers, and stem flip is more what I've done
robbyville is offline
Old 12-26-13, 07:59 AM
  #17327
I’m a little Surly
Germany_chris's Avatar
Quoted: 699 Post(s)
Liked 1,294 Times in 647 Posts
Originally Posted by robbyville
Well, I've never posted this bike in here knowing how it would probably fare. But now I think my ego is strong enough, plus I just put these exceedingly hot wheels on (they ride nicely too). I also figure that most of you are fairly liquored up on Egg Nog!
Pics are from just after today's short ride, the joys of the job skiing/boarding in the morning and ride in the afternoon.
Bike fit before carbon wheels..
Not
Germany_chris is offline
Old 12-26-13, 08:07 AM
  #17328
robbyville's Avatar
Quoted: 429 Post(s)
Not
Bike fit has been done (I'm a fit junky), but will need to be tweaked as I get stronger and learn to spend more time in the drops.
Ouch that "not" stings but I know I brought it on myself!
Old 12-26-13, 09:16 AM
  #17329
ravenmore's Avatar
Quoted: 42 Post(s)
Liked 3 Times in 3 Posts
Nice Trek. Seems like everyone and their dog is making carbon wheels these days. Rail? The setback post doesn't bother me too much. If you need it for your fit then so be it.
If you wanted to improve the pic you could use shallow depth of field to blur out the back ground. You'd use a longer lens with wider aperture (which would bump your shutter speed up as well which is generally a good thing too).
ravenmore is offline
Old 12-26-13, 09:29 AM
  #17330
robbyville's Avatar
Quoted: 429 Post(s)
Hey @ravenmore, thanks for the advice! As luck would have it I just bought my wife a nice camera as she's getting into photography, literally unpacked it yesterday so hoping to learn more about the settings, lenses, etc.
Old 12-26-13, 10:01 AM
  #17331
shoota's Avatar
Quoted: 1873 Post(s)
Liked 692 Times in 468 Posts
I like the trek too except for the saddle/seatpost position appearance
2019 Salsa Warbird
shoota is offline
Old 12-26-13, 11:33 AM
  #17332
ravenmore's Avatar
Quoted: 42 Post(s)
Sure no problem. Easiest way to do it would be to use your longest lens and then put the camera in aperture priority automatic mode (its usually marked 'A' on the mode dial). Set it to the widest aperture (lower numbers = wider) and it will automatically pick the corresponding shutter speed for you.
Old 12-26-13, 04:18 PM
  #17333
I’m a little Surly
Quoted: 699 Post(s)
We'll have to agree to disagree
Old 12-26-13, 10:06 PM
  #17334
gc3
Falls Downalot
gc3's Avatar
Bikes: Now I Got Two
Quoted: 5 Post(s)
Bike fit has been done (I'm a fit junky), but will need to be tweaked as I get stronger and learn to spend more time in the drops...
To what end? Acccording to the guy that did my Retul fit....riding in the drops makes you more aero, but doesn't help generate any additional power...
gc3 is offline
Old 12-26-13, 10:23 PM
  #17335
Silvercivic27's Avatar
Bikes: Colnago, Cervelo, Scott
Quoted: 191 Post(s)
I produce less power in the drops, and my heart rate goes up.
Silvercivic27 is offline
Old 12-27-13, 05:46 AM
  #17336
robbyville's Avatar
Quoted: 429 Post(s)
Hmm, well I was planning to race this year and my first ride is a criterium in WV, all the videos I watch seemed like people were in drops for extended periods of time during crits so I thought I'd better be comfortable there for longer than 10 minutes at a time?
Old 12-27-13, 06:57 AM
  #17337
Quoted: 191 Post(s)
People are in the drops for aero and handling, not necessarily to produce more power. Yes, you should try to ride in the drops as much as possible in a criterium (generally speaking).
Old 12-27-13, 07:24 AM
  #17338
Herbie53's Avatar
Quoted: 485 Post(s)
My dial has little pictures on it. I find that flower or green box work ok for bike pics... actually this is a really good thing to know!
Thanks.
Herbie53 is offline
Old 12-27-13, 07:36 AM
  #17339
Herbie53's Avatar
Quoted: 485 Post(s)
+1 to staying in them for crits. You should be able to ride at least an hour in them. Lotsa people don't, but it is better for many reasons, but mostly handling and keeping other bars from mating with yours.
Herbie53 is offline
Old 12-27-13, 08:33 AM
  #17340
robbyville's Avatar
Quoted: 429 Post(s)
yeah, it's different for me, I'm not particularly flexible and I'm a good slogger for long periods of time, so getting in the drops without losing power and keeping my body still has been good practice.
Old 12-27-13, 08:52 AM
  #17341
Quoted: 191 Post(s)
You're not comparing power curves to determine who wins races. It's whomever crosses the line first. You will be slower and less stable through the turns if you're on the tops or the hoods. You will be slower, especially with your nose in the wind if you're on the tops or the hoods. Even though you may be producing more power up on the tops or the hoods, it is less efficient, and you will be going slower. As someone else already said, you will also be more stable and less likely to tangle bars when you bump and grind in the drops.
Old 12-27-13, 10:40 AM
  #17342
SpeshulEd's Avatar
Quoted: 686 Post(s)
Liked 5 Times in 5 Posts
Not sure if serious or not?
Rail = the new November line of wheels.
Hey guys, lets go play bikes! Strava
SpeshulEd is offline
Old 12-27-13, 10:46 AM
  #17343
Con forza e velocitŕ
Forza's Avatar
Bikes: Spesh S-Works - Tarmac SL4, Spesh S-Works Venge, BMC Team Machine SLR01, Spesh Allez - FrankenForza
No garage door, sorry, was out riding.
Team bike for 2014.
Forza is offline
Old 12-27-13, 11:10 AM
  #17344
LAJ
So it is
LAJ's Avatar
Quoted: 11405 Post(s)
Liked 4,761 Times in 2,770 Posts
You always have bad-ass bikes, Forza. Nice. How do you like those handlebars?
LAJ is offline
Old 12-27-13, 04:39 PM
  #17345
robbyville's Avatar
Quoted: 429 Post(s)
Team bike for 2014.
yeah that's pretty darn hot. I also want to know how the handlebars are, do you ever ride the tops with those?
I especially like that it comes with the DA 9000 brakes, whereas some of the DA equipped specialized bikes don't, drives me crazy that a bike in that price point would skimp on brakes (I fully know how this is normal, but again in this price point I would think it would be better to simply have the right brakes and increase price a bit). At any rate that's a beaut!
Old 12-27-13, 04:48 PM
  #17346
sbxx1985's Avatar
Quoted: 1934 Post(s)
Liked 282 Times in 158 Posts
Specialized made a Vuka Sprint.
sbxx1985 is offline
Old 12-27-13, 06:59 PM
  #17347
Forza's Avatar
limited time on them. I like them, but i've always preferred "ergo" shapes. I was iffy on the naked approach, so far no issues...comfortable to me, more than I expected. I'm sure I'll have more of an opinion come the summer months, as I am a no gloves rider and I do ride the tops on climbs.
As far as performance, they are stiffer than I expected and that's a good thing for me.
Thanks, I'm pretty lucky in that we are sponsored by Specialized, Shimano, Michelin, Garmin (amongst others), etc..and we get our stuff from them and we don't buy the bike configurations offered, come race season I'll be running Dura-Ace c50 tubulars. The wheels on there right now are de-badged Enve 45s. I need to get rid of the Zipp cages.
Your point is spot on too though, if I (or anyone) were shelling out $$$$$ for the standard configs, it's nice to get the group throughout.
Forza is offline
Old 12-27-13, 08:12 PM
  #17348
pcaldwell's Avatar
My Velocite Selene racer
Velocite Frame
Velocite Forks
Pro 7 Stem and Bars
SRAM Red Shifters
SRAM Rival F.Derailleur
SRAM Rival R.Derailleur
TRP 920 Brakes
Thomson Elite Seatpost
Boyd 30mm Rouleur Wheels
Selle Italia SLR Saddle
LOOK Keo Pedals
File Type: jpg
pcaldwell is offline
Old 12-27-13, 08:21 PM
  #17349
Bikes: Super Cheap gc3 approved Bike
Quoted: 572 Post(s)
Liked 52 Times in 30 Posts
@pcaldwell how do you like that frame? I'm thinking of buying it.
zymphad is offline
Old 12-27-13, 08:53 PM
  #17350
pcaldwell's Avatar
I love it. Nice and stiff. Pretty light too, in fact I sold my carbon frame/bike to purchase this bike. I'd say go for it, especially since it's only $299 for the frame. The finish looks even better in person.
