What are the biggest wastes of money in biking?
#1101
Quoted: 7062 Post(s)
Liked 11,131 Times
By your logic, I should ignore my high cholesterol since my blood pressure is already rather high anyway.
Likes For Koyote:
#1102
climber has-been
Quoted: 3509 Post(s)
Liked 3,652 Times
#1103
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Luck has a lot to do with not getting flats whereas a properly built and stress relieved wheel with quality components should not go out of true unless something catastrophic happens like hitting a pothole that also takes the rider down.
#1104
Quoted: 3980 Post(s)
Liked 7,429 Times
Not the best analogy unless you are comparing fragile tires with inferior components of a wheel build.
#1105
Expired Member
Quoted: 3713 Post(s)
Liked 5,571 Times
#1106
Quoted: 3560 Post(s)
Liked 2,979 Times
What's wrong with having an expensive light weight bike? Do you think a high-end racing bike rides exactly the same as a mid-grade bike? And why stop at mid-grade? Why not buy the cheapest low-end bike you can find, and save even more bucks?
#1107
Habitual User
Quoted: 5037 Post(s)
Liked 8,250 Times
Who carries 8lbs of repair tools/parts?? That's ridiculousness.
#1108
Sock Puppet
Liked 863 Times
He never said that wheels never need trueing. Show me the quote where he said that. He implied, as I said, that a properly built wheel with quality components should not need trueing under normal use.
#1109
Liked 7,429 Times
Likes For tomato coupe:
#1110
Habitual User
Liked 8,250 Times
Which of those things will you not take with you on a ride on a mid-grade bike that you think you need to take on a ride on a high-end/lightweight bike?
#1111
Quoted: 8333 Post(s)
Liked 9,167 Times
So i just had to check
Dynaplug 14g
Tube 105g
multitool 192g
pump 150g
wallet 200g
Phone 163g
water bottle 69g (nice...)
water 950g
Gels 210g
everything together 2053 grams or around 4.4lbs. I counted only one water bottle because I typically only take 2 if I'm doing more than 100km.
That's actually kinda alot. I wonder if I should get a lighter bike to offset that...
Dynaplug 14g
Tube 105g
multitool 192g
pump 150g
wallet 200g
Phone 163g
water 950g
Gels 210g
Seriously, I wouldn't count water as part of a tool kit. I think 2 pounds is plenty of stuff to carry, (pump, tools, tube). Water comes and goes.
#1112
I have to say that I agree with the sentiment that wheels really shouldn't be going out of true. None of the wheels I've built have.
But of course there's the element of specs. In order for a wheel to remain true it needs to be specced correctly for tge rider and use case. You can't put a 16/20 spoke superlight aluminum wheelset on a DH rig for a 120kg rider for a weekend at whistler and expect it to stay true. However give that same rider a 24/28 spoke high profile carbon wheelset for general road riding and chances are that the wheelset will not require truing. If said wheelset has veen built correctly.
There's of course some oversimplification as spoke choice etc. play a role but I thought to keep things simple.
Likes For elcruxio:
#1113
Liked 9,167 Times
I wouldn't say they never need truing but It's not that common. I usually break or wear out the rim before they need truing, although I have had to true a few. Even on the current mtb the rear wheel cracked and had never been trued.
#1114
Liked 7,429 Times
#1116
climber has-been
Liked 3,652 Times
Exception 1: A heavy rider on a light wheel with low spoke count might be able to unload the spokes enough to allow the nipple to unscrew, and that will make a wheel go out of true.
Exception 2: Side impact. That's damage.
#1117
Liked 9,167 Times
The first line was sort of a joke. I don't have a phone, so I wouldn't include it in my thinking about weight. I know, it's unbelievable but I've resisted against all manner of ridicule until friends and family have about given up. Maybe I'll get one and then the cycle will start over. Of course, then I would be expected to answer the damn thing.
#1118
Liked 7,429 Times
1. Properly built wheels never need truing.
2. Any wheel that needs truing was not properly built.
#1119
I can't leave the phone at home because I have something in the range of tens to hundreds of thousands times more chance to have a need to call an ambulance mid ride than your average joe road cyclist. Luckily I haven't needed to yet but can't say I haven't gotten close.
#1120
Liked 9,167 Times
About those wheels that sometimes go out of true: I suggest that it's almost always because they weren't built properly.
I have built my own wheels and I'm not that good at it and I don't like doing it. I prefer to pay someone who knows what they are doing.
#1121
Habitual User
Liked 8,250 Times
#1122
Liked 9,167 Times
#1123
1. A bicycle frame should never need repair by welding
2. Any bicycle frame that needs repair by welding wasn't built properly.
Or maybe it does.
But if a wheel has been built correctly, there really aren't any places where the wheel could go out of adjustment, excepting deformations ie. damage. If the nipples don't unscrew the wheel shouldn't be able to go out of true. And if you hit a pothole that completely unloads spokes, well the properly built wheel has threadlocker for those situations.
#1124
Habitual User
Liked 8,250 Times
We dropped our land line at home a few years ago. My cell phone is my "home" phone now. Zero regrets on that move.
Likes For Eric F:
#1125
climber has-been
Liked 3,652 Times
Wheel building also takes a lot of time. I prefer re-tensioning a factory wheel to building one from scratch. It's quicker.
