Best Frame Ever
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
If you're counting materials as well something custom Ti or carbon from moots or calfee.
Steel, has to be custom richard sachs. The godfather of custom frames.
What you can't buy is the time you'll be waiting for a frameset from him. That's if you manage to get a spot on his list.
Quoted: 107 Post(s)
Liked 22 Times
There was a very nice used Waterford fixed gear on ebay a few month ago. The price seemed very reasonable - no longer listed so I assume it was sold.
Clark W. Griswold
Quoted: 4434 Post(s)
Liked 4,082 Times
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
How about Firefly?
They do some IGH and eccentric bottom bracket stuff, mostly for utility bikes and not strictly fixed gear road or track bikes but man, those things are beautiful.
-Tim-
-Tim-
Calamari Marionette Ph.D
Half of this lug is a lug, on the down tube, but the other half vanishes into the head tube in a filet. And the fork crown and blades are blended to become one single piece.
Don't need to say much about this puppy...
or this one either....
The folks at Victoire in France would build you a very expensive frame for suuuurre: https://www.victoire-cycles.com/en/o...re-virage.html
Clark W. Griswold
Liked 4,082 Times
I bet the Firefly folks would make a fixed gear road bike. I am so desperate for one of their bikes but alas I want an all-road bike rather than a fixed gear though I would take a fixed gear if possible.
Quoted: 823 Post(s)
Liked 1,396 Times
Why not get an all-road fixed-gear? Around here, at least, the BEST fixed-gear rides are all-road, taking in modern pavement, bumpy chipseal, hardpacked dirt and gravel roads.
Clark W. Griswold
Liked 4,082 Times
I would but I want to do a geared bike with Di2 and more clearance and thru axles and finding fixed hubs that are 142x12 thru axle compatible is tough. I have a Cinelli Mash Work frame that is SS/FG with 700x38 tires that can handle that task.
Quoted: 63 Post(s)
Pardon my lack of knowledge... What separates an all-road fixed gear from the rest of the pack? The riding conditions you mentioned sound like my ideal ride. So I want to make sure I pursue the ideal bike.
Actually, I'm not that big on lugs. Especially the really ornate ones. Just not my bag, too fancy. But I absolutely admire the imagination and originality of his tweaks. And you gotta salute that level of craftsmanship and attention to detail. That seamless fork top is gorgeous.
- Soli Deo Gloria -
Liked 736 Times
You can get into type of brakes and then into how the cables or hoses route and so forth, comfort/endurance vs race geometry and a whole bunch of other details. At the end of the day however, gravel and dirt require tires wider than 28's to be really enjoyable.
-Tim-
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 766 Times
For those of you who may be interested, I’ve uploaded some current pics of my 1983 Mark Nobilette custom road racing frameset with its recently updated cockpit to make it into a comfortable touring bike. The paint was redone by CyclArt of California, and I never bothered to get new decals from Mark.
https://m.imgur.com/a/FSNC5
Quoted: 1332 Post(s)
Liked 398 Times
Quoted: 4847 Post(s)
Liked 3,980 Times
Question - if you are going for an ideal road fix gear, why make flipping wheels harder than it needs to be? Track ends belong on the track. Front and down opening dropouts rule. Anybody not willing to make a road fix gear frame without doesn't get my dollars. I don't care how nice the rest is.
Ben
Ben
Clark W. Griswold
Liked 4,082 Times
Ben
Ben
Quoted: 63 Post(s)
Ben
Ben
And when you say flipping wheels, do you mean using a rear hub that has two different cogs or freewheels, or is there another reason to flip the wheel that I don't know about?
Veteran Racer
Liked 766 Times
I'm still new to bikes in general, and more so to fixed gears. Good thing they are simpler than the AL geared road bike I started on. Much shallower learning curve so far. Still, I have only just recently heard of the "front and down" dropouts. Can you clear this up for me? Certain dropouts, like on a standard new road bike, which I believe are normally called "vertical" aren't suited for fixed gear, right? Or are those the same "front and out" ones you're speaking of?
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
Liked 398 Times
No one ever actually flips their wheel on the road. If you were going to have a dedicated SS road frame custom built, then yeah you'd probably want to get forward facing dropouts. However, no one ever gets custom built dedicated SS road frames built either.
