Bike chain grime
Mad bike riding scientist
Quoted: 6269 Post(s)
Liked 4,293 Times
A bit of grime is a given on any wet lubed chain. To minimize grime, wipe your chain often, Wipe it after you lube and frequently thereafter. Wiping reduces the amount of surface oil that picks up the gunk. Wiping will not reduce the amount of lube within the links, i.e. where it counts.
Good luck and welcome to Bike Forums.
Again, I’m not saying one lubricant is far superior in lubrication of another…see my comments above. But there is a distinct advantage in terms of cleaning and cleanliness to wax based lubricants.
Stuart Black
Stuart Black
Likes For cyccommute:
climber has-been
Quoted: 3554 Post(s)
Liked 3,715 Times
But if minimizing friction and preventing wear are the goal, there is probably no worse lubricant than the class of drip-on, wax-based lubes.
Liked 4,293 Times
Since the results are the same, cleanliness becomes a larger factor
Stuart Black
Stuart Black
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2674 Post(s)
Liked 5,899 Times
If I clean the drivetrain once a month I feel like I have OCD.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
climber has-been
Liked 3,715 Times
In a simulated 10,000 km of dry dusty conditions, Zero Friction Cycling measured that the best lube (Silca Hot Melt melted paraffin) would need 0.5 chain replacements, and the worst lube would need 13.5 replacements. White Lightning Epic Ride would need 7.1 replacements.
The problem with certain drip-on wax lubes appears to be their inability to penetrate, and their tendency to get displaced from bearing surfaces.
There are exceptions. Effetto Mariposa Flower Power is drip-on, wax-based, and fairly inexpensive, but its measured resistance to chain wear rivals that of melted paraffin.
Grupetto Bob
Liked 5,899 Times
Not that it matters but I am happy with Silca’s Synergetic Wet Lubes performance. The precision applicator is unique.
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 378 Post(s)
Liked 478 Times
Cyccommute and I referred to White Lightning Clean Ride, not Epic Ride.
Clean is entirely wax-based, while Epic is synthetic/silicone based.
I find that "chain replacements" bit ridiculous. It implies replacing a chain in less than 1k miles with Epic.
From my experience, I replace my chain every 5k miles, whether it needs it or not.
Typically it exhibits minor elongation, but at forty bucks a pop, it's not worth stretching (pun intended) mileage much beyond.
Liked 4,293 Times
Yes. While it is true that the absolute differences in friction between the different chain lubes is small, what is not small is the rate of chain wear.
Stuart Black
Stuart Black
climber has-been
Liked 3,715 Times
After re lube – during the second interval for the (test) block the drive motor was literally unable to maintain a 250w load at rear wheel (Neo is set to 250w resistance). By 2/3rds in, the motor was unable to maintain cadence – once cadence starts to drop smart trainers compensate by increasing resistance – which cascades to slowing the motor further as the torque now required is simply too much for the motor. There had been a notable drop in speed for the ratio both from when it started and compared to other lubricants tested for that ratio (a trend that was becoming apparent in block 2). Once cadence dropped too low everything came to a juddering halt, tripping the fuse on drive motor from the strain and ruining rubber spider coupling insert from too much torque. -- zerofrictioncycling.com, Lubricant On Test: White Lightning Epic Ride
White Lightning Epic Ride Performance Ratings from zerofriction.com:
- Race Day Lubricant Road – 1/10
- Race Day Lubricant - MTB / CX – 0.5/10
- Everyday Lubricant – 1/10
- Harsh Conditions Lubricant – 0/10
- Single Application for Long event – 0/10
climber has-been
Liked 3,715 Times
For example, White Lightning Epic Ride is about 75% heptane, Clean Ride is 60-80% heptane. Really nasty stuff. Flammable, toxic, and a strong greenhouse gas.
Contrast that with Ceramicspeed UFO Drip, which is non-toxic, non-flammable, and bio-degradable. Also, UFO Drip blows away White Lightning on friction and wear prevention.
Grupetto Bob
Liked 5,899 Times
This is a first for an oil based lubricant. Did a 50 miler today and found this. The chain was wiped down well after cleaning and oiling but apparently not good enough. Getting oily stuff thrown on the seat stay, (from the tire?) and chain stay is a new one. Wiped the chain down again and will see if it still happens.
Quoted: 572 Post(s)
Liked 605 Times
↑⇡↑ I have never seen anything near that bad, did you use 0W weight oil?
Liked 4,293 Times
found that prolonged exposure to heptane may also cause a state of intoxication and uncontrolled hilarity in some participants and a stupor lasting for 30 minutes after exposure for others.
Very toxic to aquatic life with long lasting effects.
In terms of wear, the comparison on the Zero Friction is to White Lightning Epic Ride which isn’t that great of a product. Clean Ride is different but there is no comparison of it to the other products on the list. I won’t say where it would fall on the list for wear but it is in the middle of the range for friction and friction is related to wear.
Oh, and it’s 9 out of 10 are wax based lubricants with 6 of the 9 being drip waxes. How does that fit with the statement
Stuart Black
Stuart Black
Grupetto Bob
Liked 5,899 Times
climber has-been
Liked 3,715 Times
Check the UFO Drip SDS. The main solvent is n-hexane (60 - 100%) and pentane (10 - 30%).
It is most definitely not bio-degradable. Nor non-toxic. Nor non-flammable. I’m not saying that White Lightning products are green but neither is UFO Drip.
The chain coating is developed to support all disciplines and is based on a non-toxic, non-flammable and bio-degradable formula.
The SDS for the new UFO Drip formulation.
I dont think that is accurate. Not even according to zerofriction, that you are referencing. On the contrary most of the best performing lubes on test was in fact wax based. It is also true that some of the tested wax lubes have performed worse than expected. Most notably forum-darling Squirt, and the tester surmised that the poor performance was related to poor penetration. However, was that the reason? He never proved the point by taking a Squirt lubed chain apart. The poor penetration conclusion seem derived from endless theorizing and conjecture, rather that just taking a look.
From my, limited, experience with Squirt it seem perfectly capable of draining in to the chain. However tenacity seem lacking. In less than 100km the chain becomes notably chatty (no squeaking tho) and there are dry / shiny spots on chainring teeth indicating all the lube is pushed away. I'm not too impressed, but will use up my two bottles, as I do like the reduced mess. The other wax lubes that tested better seem way to overprized to pay for them selves. Even Squirt seem a bit on the high side, considering two little bottles are as much as I usually pay for a new chain, and the low mileage pr lube.
From the previous REALLY vague and simple questions you've asked before this and if I didn't know any better, you sound like a scammer trying to up their post count and legitimize themselves a little before attempting to scam someone... "How do I keep these tires from blowing?" "What chain oil do you use?... The last two scammers I seen here did the same exact thing.
To answer his question - take care of your bike and it will take care of you - clean your chain.
climber has-been
Liked 3,715 Times
Tests show that some drip-on, wax-based lubes perform very well. Others horribly. Why the difference?
One thing horrible lubes have in common: they contain mostly very low viscosity carrier/solvent, with little lubricant.
Liked 4,293 Times
I believe the UFO Drip SDS you referred to is for their old, non-green formulation. Their new formulation is described on the company's product page:
Granted Ceramic Speed changed the formulation and SDS in 2020. Maybe their new formula may be all the things they say it is but the new SDS is rather sparse in details…only one ingredient of less than 1% is listed…which makes it difficult to judge their claims. The 2017 SDS lists wax as one of the ingredients in the safety sheet as having an exposure limit. It’s not listed in the new SDS but it obviously has to be there.
Finally, I’ll remind you again that you said that drip waxes as a class are bad lubricants. Having 9 out of 10 of the top ten lubricants on the Zero Friction list does not support that argument.
Stuart Black
Stuart Black
climber has-been
Liked 3,715 Times
Zero Friction Cycling has tested the new formulation: Lubricant On Test : Ceramic Speed UFO Drip v2
TL;DR -- Second lowest block 1 (no contaminants) wear ever tested.
Fair enough, my initial statement was overly general. Performance of commercially available drip-on, wax-based lubes is highly variable, ranging from superior to horrible.
Liked 4,293 Times
Stuart Black
Stuart Black
Grupetto Bob
Liked 5,899 Times
(just so we're all on the same page here - I HATE scammers and everything about them), but maybe this guy is in the same boat that I am. I have a few questions on a Trek I recently purchased and want to make a thread to show it and get some advice, but sometimes forums can make it difficult to even get the ball rolling. When I first tried to make a thread, I couldn't - I was told I have to have at least 10 posts. When I tried getting my posts up, I couldn't - I was told I can't make more than 5 in a day. On the second day, I tried making 5 more posts, I couldn't. Even though it was after 24 hours, it said I needed to wait 24 hours. When I tried replying with a quote that included an image, I couldn't - I needed to get back to my 10 word-only replies. If this guys really a scammer, have at em'! If he's dealing with what I've been dealing with - give him a break.
Likes For rsbob:
Liked 4,293 Times
Oil based lubes have similar variable results. Wax has the advantage of not needing constant cleaning.
Stuart Black
Stuart Black
climber has-been
Liked 3,715 Times
My observation that horrible lubes are low viscosity and have little lubricant is based on published test data. The worst performing lubes in the Velonews tests were reported to be "thin". Notice the clustering of "thin" lubes at the bad end of the graph:
However, one can't conclude that all thin lubricants are poor performers. The tests also found some low viscosity formulations that perform well, like the Rock n Roll products. At least they perform well on the Velonews test. Rock-n-Roll Gold didn't do so well on the Zero Friction wear tests.
Given that low viscosity has been correlated to poor performance, but it's not universal, how does a consumer know what they're getting? Review test results, I guess.
