Training for sustained climbs?
Old 08-29-20, 12:41 PM
  #101
Asleep at the bars
sfrider's Avatar
Quoted: 234 Post(s)
Liked 203 Times in 135 Posts
Originally Posted by asgelle
Why? The relative position of the bars, saddle, and pedals don't change nor does the angle of resistance from the chain on the chainrings.
The bike is tilted back underneath a rider going uphill.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
sfrider is offline
Old 08-29-20, 12:44 PM
  #102
Quoted: 1035 Post(s)
Liked 456 Times in 268 Posts
Why does that mater if all the relative positions including the resistance vector don't change?
asgelle is offline
Old 08-29-20, 04:05 PM
  #103
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
I believe what we are talking about is ease. It is easier to hold high resistance on a hill than it is the flat. On a climb, gravity limits the effect of momentum on your ability to ride with high resistance. On the flats, it is much harder to limit those same effects.
colnago62 is offline
Old 08-29-20, 04:50 PM
  #104
Dancing Skeleton's Avatar
Quoted: 74 Post(s)
Liked 57 Times in 34 Posts
This ^^^^^^^^^^^
Dancing Skeleton is offline
Old 08-30-20, 01:37 PM
  #105
Asleep at the bars
sfrider's Avatar
Quoted: 234 Post(s)
Gravity hasn't changed and still points down. As a result, to keep your weight over the cranks you need to shift forward. Eventually as the grades pick up you reach a limit where you can't do this further, and you end up with your weight back behind the cranks, and pulling on the bars to hold yourself down. Note that it's the bike that rotates underneath the rider. The rider ideally stays above the cranks. When you rotate the bike underneath the rider, the effect is that the saddle is moved back and down, and tilted up. This makes for a different riding position. When you reach the practical limit of your hip/groin angle, your weight starts shifting back as you can't go too far forward on the saddle without losing too much leg extension. When this happens you pull on the bars to pedal to hold yourself down. When grades get even steeper, maybe around 14-15%, you have to shift your weight forward and smooth out your pedal stroke to avoid lifting the front wheel.
sfrider is offline
Old 08-30-20, 03:13 PM
  #106
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1102 Post(s)
Liked 559 Times in 446 Posts
Can't say that I agree. I've started riding everything Colorado has to offer back in 2003. I've done 14,000 foot Mt Evans six times and I still ride grades of at least 12%. I don't change my position nor do I pull on the bars. One of the keys to success is having the proper gearing to keep your cadence above 70. Just today I cruised up a 10% grade in my 32/32, pedaling at 80 rpm. No need to move forward and I was just resting my hands on the bar with no grip on them.
DaveSSS is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
