Help with bike shop or touring drivetrain
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times
Thank you. Good stuff there. What's your opinion on this crankset vs. the IRD. It's a bit cheaper and looks very similar. https://velo-orange.com/collections/...kset-24x34x48t
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
Dunno what you qualify as heavy, but I'm around 215-220# in cycling gear, and haven't had an issue (or been given a reason to assume an issue) with the 10s on the Mazama or the fat bike.
I just brought this up more out of curiosity , I figure that given touring bikes come with ten speed now, the longevity of each speed increase eventually becomes the same or very close as the previous generation. In my case, it seems that there isn't much of a difference between 7 or 9 speed, and I presume 10. The small difference is worth having smaller jumps between shifts.
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,664 Times
Personally i have used a 24 tooth granny for the past couple of years and it makes for a good low gear. This year i bought a used sugino 94/58 bcd crank so that i could have a smaller cassette. Running 12-28 7 speed with 20,32,42 on the crank. With 700x35 tires it gives me 19 to 93 inches.
