Bike rack broke rear wiper
Quoted: 1425 Post(s)
Liked 1,946 Times
He is right, if the car isn't designed for one pick a quality place to get one made
But at the same time the response is a bit over the top alarmist. It leaves people with the wrong impression.
They don't make a hitch for my 1970 Datsun 240z either. That is why I will probably weld up one of my own.
But looking at list linked earlier the overwhelming majority of cars on the road today were designed for hitches, and if a kit exists, they are very easy to install. The concerns are not applicable to the majority of people on here. And I would think most people would know to seek another solution if a shop quoted a week's work and $1000+ to install one. You won't make your car unsafe installing a receiver hitch.
BTW I'm shopping for a new car and whether a hitch is available is one of the things I'm looking at. So far, I've yet to come across a model that wasn't designed for one.
had receiver hitches made for a few vehicles - including a Honda Civic and Prelude and an Isuzu Vehicross ... the Vehicross required some careful bumper cover / valance surgery - but when complete the hitch was barely visible
the hitches were installed primarily for plug-in bike rack and cargo carrier use - but I even pulled an 8x10 flat bed trailer with the Prelude - once loaded with a 400 lb snowmobile and another time with a 600 lb tractor
Bikes: nothing to brag about
Quoted: 130 Post(s)
Liked 206 Times
My rack rides very low on the back window, right on the bottom of the wiper. I've got a wrench and a small gear puller for the wiper. If I need the wiper, I don't need the bike.
Quoted: 668 Post(s)
Liked 529 Times
Not shopping for Alfa Giulia, Audi S7, or new Toyota Supra, eh?
It’s not as rare as you think for cars not to be designed for trailer hitches, and while that doesn’t mean one couldn’t be rigged up, msu2001la ’s point to consider the amount of work required to do it is well made. Cutting up valances, disabling park sensors and forgoing cross-traffic alerts and auto-parking are things which should be considered.
My ‘11 Mini Cooper S Clubman with JCW Aero package has none of that whiz-bang stuff, but is definitely not designed to take hitch. Curt would sell me one for an ‘11 Cooper, but it’s designed for the base bumper style and even then requires cutting the bumper cover, but the Clubman JCW is very different and would require relocating the license plate if not rerouting one of the twin exhaust pipes…if it’s even possible.
Yeah, some cars aren't built for it, but for the most part I'm impressed with the number of cars come from the factory with the idea of a receiver hitch in mind. Aftermarket kits wouldn't exist if cars weren't built that way from the get go. Just look to see if a kit exists before one starts worrying about crumple zones and "recalibrating" cameras.
Thread Killer
Quoted: 3195 Post(s)
Liked 1,727 Times
Likes For chaadster:
Unfortunately my rack sits 1/2" above the wiper, which is what broke it. Thanks for your comment about the feasibility of removing the wiper. The new wiper arm arrived today and it came with a nice wrench. To the best of my knowledge, a gear puller isn't needed on my car. I believe the arm just lifts off the motor shaft.
Quoted: 668 Post(s)
Liked 529 Times
The existence of an aftermarket kit does not mean the car was designed and built to accommodate a hitch. Caveat emptor…which is precisely the point msu2001la was making earlier when they said “if your car wasn’t designed to accommodate a hitch from the factory, I’d proceed with caution [emphasis mine] on getting one installed.”
Install one yourself, anyone can do it, and see what I mean.
Thread Killer
Liked 1,727 Times
I completely disagree. The vehicles have square bolt holes build into what amounts to the unibody frame rails. They were also built with an access point for fishing in the bolts. it wouldn't be possible to sell a bolt on kit without that foresight from the manufactures.
SE Wis
Quoted: 2751 Post(s)
Liked 3,408 Times
E-Coat drain holes
Water / road salt drainout
Welding / assembly fixture locating holes
Tie down holes for rail transport
Measuring holes for collision repair
Recommended attach points for tow truck use
Adjustments made late in development program to tweak crash performance
Quoted: 1463 Post(s)
Liked 1,488 Times
I don't really understand why my comment is causing so much grumbling. There isn't a kit available for my car in the link above, but they do make one for older models that looks like it might work. It's nearly $600 (plus tax) and described as 10/10 installation difficulty. Steps required include:
I stand by my original post: If your car isn't designed to accommodate a hitch from the factory, I'd proceed with caution on getting one installed. Just because someone makes a kit or says they can do it doesn't mean it's a good idea. I'm sure on some cars it's no big deal.
- Remove the interior side panels of the trunk, remove the rear bumper/facia, both tail lights, both rear wheel well liners and the rear factory reinforcement beam.
- Disconnect and pull the hands-free trunk opening sensor out of the rear facia (it's embedded inside).
- Use a saw to cut out and remove an 11" x 4" section of the rear facia, which is also the location where the hands-free trunk opening sensor is embedded by the factory.
- Re-attach the hands-free trunk sensor to the outside of the facia around the hole using zip ties
- Bolt the hitch kit onto the chassis using the bolt holes for the factory reinforcement beam. The beam gets installed on top of the hitch kit, using longer aftermarket bolts (is this safe?).
- Re-install the tail lights, rear facia/bumper cover, wheel well liners. Hopefully those panel gaps all line up OK. Note says that parking/self driving sensors may need to be recalibrated by a dealer.
Quoted: 1053 Post(s)
Liked 1,312 Times
+1 for Seasucker or a roof rack - if detaching the fuse for just that wiper is easy, do that. Typically fuses will power more than just one thing, so investigate first.
And during the rainy season here, a rear wiper is crucial since the back window of my car is a crud magnet.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2616 Post(s)
Liked 5,740 Times
Get a roof rack instead but hang something on your rear view mirror when you have a bike on top so you don’t forget its there and drive into a garage or other low hanging objects.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Liked 1,488 Times
This might be true for some cars, but not all.
I specifically asked Audi about mounting a Seasucker rack on rear hatch glass, or the panoramic glass roof of my car and they told me that there is no problem with either location. Audi sells SeaSucker racks as a factory direct product.
Likes For msu2001la:
Liked 1,312 Times
Liked 1,312 Times
I stand corrected. Thanks. (I bet the large glass shops have partial ownership of See-sucker.)
Likes For phughes:
Thread Killer
Liked 1,727 Times
The glass is the same. I know Audi sells them, and I know they say it is okay. Of course they sell them, so of course they will say it is okay. The majority of people will have no issues with them, most likely. The glass can still break. I prefer to not use glass to support a load. Use at your own risk, and carefully follow their instructions. They actually modified their instructions a while back since people were having issues with glass breakage.
Thread Killer
Liked 1,727 Times
No, I don’t know what you mean, nor do I believe what you’re talking about. I think you’re just repeating internet blather, and not speaking to the matter with any real substance. I don’t even believe the paradigm you posit, that the rear glass supporting bike weight leads to breakage, first because when the car is in motion, the air pressure is *lifting* the bike off the glass, and second, because what any given rear glass can support depends on the size of the window and where the weight is applied. But you don’t talk about any of that stufff, so yeah, red flag.
Grupetto Bob
Liked 5,740 Times
Oh good, an argument over something trivial.
Likes For rsbob:
Liked 1,312 Times
Not to worry. I said what I was going to say. Evidently I make stuff up. I do know many use the rack and do so successfully, or they wouldn't make it. I simply said I wouldn't use it because of my past experience working in a glass shop. As with anything, follow the directions and know the risks.
Grupetto Bob
Liked 5,740 Times
Thread Killer
Liked 1,727 Times
I think it’s important people understand that context to your comments, because the way you state it, “As someone who worked in a glass shop….just say no to Seasucker,” implies you have some work experience with Seasuckers breaking glass, which you do not.
And you also intend to mislead when you say Seasucker modified their instructions because of glass breakage, but that was not a general revision and was done only for Tesla Model 3 because of what they attributed to rare problems with Teslas roof glass and was actually a recommendation to move the front piece of the Talon rack off the roof and onto to the back glass. Yet, you rail on about Seasuckers and back glass…
