Sram eTap
pan y agua
Quoted: 1461 Post(s)
Liked 738 Times
pan y agua
Liked 738 Times
You charge your Garmin every week, you charge your headlight and tail light also. So what's the problem every few weeks to charge the derailleur batteries?
Spare batteries are under $50 and weigh very little if you want to carry a spare. And they take about 5 seconds to change.
Garmin, electronic shifting, power meter, lights (as an option) all run off of one battery.
I think Shimano is missing an opportunity not putting out a fully integrated set up, with computer, power meter, shifting all rolled into one.
Typical Di2 setup has the junction box under the stem. Just make the junction box the mount for the GPS, and you're not even adding a wire, and now you've got one battery for the whole friggin bike to charge, instead of two shifter batteries, two derailleur batteries, power meter battery, garmin battery to charge.
I'd definitely put up with a couple of wires in exchange for one battery for the whole bike.
You could get lost and die.
You could hit a tree and die.
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
On Your Left
Liked 2,434 Times
Personally, I think we should be going the opposite direction. Everything wired into one unit.
Typical Di2 setup has the junction box under the stem. Just make the junction box, the mount for the GPS, and you're not even adding a wire, and now you've got one battery for the whole friggin bike to charge, instead of shifter batteries, two derailleur batteries, power meter battery, garmin battery to charge.
Shifter batteries are good for a year, actually I spoke to the Sram rep and he said the real life is much longer than advertised. So just add it to your winter maint along with new chain, new brake pads and new cleats.
Derailleur batteries are interchangeable so if for some reason you forget for a month to recharge them you can always move the front to the rear since the front is used so much less.
pan y agua
Liked 738 Times
Single point of failure, if it goes, you're almost walking home.
And seriously, if you did have to ride without GPS or power data that is almost walking?
If you forget to charge it, Di2 already accomplishes by software, what the 2 separate batteries do with SRAM. As the battery runs down, you lose front shifting first, but you still can shift the rear.
So functionally, you'd be in the same place you would be with SRAM.
Quoted: 1186 Post(s)
Liked 289 Times
They can only give you a rough estimate, not a precise number. Distance or ride time are both reasonable metrics as most people track or have a feel for how far or how long they ride. I know how far I ride in a month but have no idea how many shifts I make per hour or km.
pan y agua
Liked 738 Times
And does anyone else think the battery on the SRAM RD is friggin ugly? Particularly compared to a seatpost battery for Di2.
On Your Left
Liked 2,434 Times
Are Di2 batteries failing often?
On Your Left
Liked 2,434 Times
don't try this at home.
Quoted: 986 Post(s)
Liked 526 Times
I like the interchangeable battery design. And the battery latch looks sturdy and easy to use.
Battery capacity
1000 km / 600 miles is about half of the usual Di2 mileage per charge reports from users.
But I shift my Di2 all the time, and typically only get about 600 miles from a charge. (After a series of rides on very hilly rolling terrain, I needed a recharge after 400 miles.) And now I'm charging without waiting long in the "blinking green" status of 25-50% charge, after I ran out of charge on a ride. I like being able to see the green battery status light on the junction box while I'm riding.
Electronic shifting is so fast and easy. I shift way more often than on my older bike, often shifting the rear for just a couple of pedal strokes before shifting again, and shifting the front ring on quite small hills.
So the Sram riders would probably just recharge once a week or every two weeks, instead of watching the battery status. And they have to press a button on the derailleur to see the light.
Front derailleur
After the last Sram electronic thread, I was paying attention to my front shifting. Maybe once every other ride, I shift the front chainring, but it's already in that ring, and nothing happens. I just lose track of which ring I'm in occasionally. I think it's in cross-chained situations, where it's not obvious from the bike's mph speed.
But the Sram method would change it to the other, wrong, ring. Well, the rider could just shift it back again. It'll be interesting to see how often this happens in real life.
Battery capacity
Front derailleur
Quoted: 6556 Post(s)
Liked 58 Times
Not so. SRAM will give you choice. You could at any time switch the batteries to put the good one in the front and get on the ring you want. With DI2 when it's gone, it's gone. And what if you don't like where you are in front when that happens?
I have a Di2 bike and like electric shifting a lot.
I'm going to keep an eye on the eTap stuff. It would be a good way to convert a mechanical bike to electrics without that taping the wires to the down tube scheme that Shimano has.
J.
J.
pan y agua
Liked 738 Times
I like that SRAM is thinking outside of a cable based paradigm in designing its electronic shifters.
I'm not sold on wireless, and multiple batteries.
pan y agua
Liked 738 Times
I ran the battery down once to where the front stopped shifting. (when first put it on, and apparently it wasn't fully charged out of the box) Did a 40 mile group ride after that with no indication that it was going to stop shifting on the rear anytime soon.
There's just no real worry, you won't be able to shift with Di2, hence no real advantage of being able to swap batteries with Sram.
Vain, But Lacking Talent
Man, I can just feel myself turning into a retrogrouch. I'm scared of what my cycling future looks like in about 10 years...
But yeah, if I were going to go electric right now, I'm pretty sure I would go Shimano. While I do see eTap as a unique innovation, I can't understand the compromise of fiddling with 4 separate batteries just because I don't like wires. Most bikes can take a really, really clean install of Di2 with minimal wires showing. And it's a one time install. From then on out, it's one battery to charge/mess with. Plus, as has been noted, you get early warnings that the battery is low whereas the eTap requires you to make a point to check it out or suddenly find out that one of your two derailleurs aren't shifting.
But hey, this is a free market. People will like what people like. For some, the additional battery maintenance might be worth it simply for the way the paddle shifting works. For some, it will simply come down to SRAM vs. Shimano. I'm certainly interested to see how it goes in the real world once it hits the market.
Bikes: 2013 Synapse 4
Quoted: 70 Post(s)
one of the things that wireless shifting opens up to is being able to connect to a head unit (like garmin) and use cadence, speed, gear selection, power, etc and will be able to automatically be able to shift to keep you in your cadence without having to think about it.... this is definitely out of the box thinking and if SRAM can integrate with Garmin (i've read they are working on it) it will be an interesting advance in cycling. you'll never be in the 'wrong' gear based on your desired settings/limits....
Kit doesn't match
You're probably posing this because you imagine it to be nearly zero. The Peleton article reports "...can save up to 100 grams." Yes, that seems like a lot to me too, but there you have it.
pan y agua
Liked 738 Times
Bikes: Steel 1x's
Quoted: 632 Post(s)
I wonder how cold affects all the batteries. I ride down into the mid 30's and at that point I find all of my battery operated devices suddenly have a much shorter functional cycle at those temps. I've had my power meter drop out on me, various lights cut out in the middle of a ride, speed sensors, cadence sensors as well.
None of that really makes a substantial impact on my ride, but if my shifting suddenly stopped on a 35 degree ride, that could be a real problem.
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
I don't "imagine" it to be nearly zero, but as a person that works with CF, building and repairing bicycle frames, I can tell you it's far less than 100 grams.
Li-ion is pretty much fine until you go a lot colder and is actually the near the best of the readily available rechargeable battery chemistries for cold performance. NiMH is much more cold sensitive.
I'm up here in MN and I routinely ride my Di2 bike in the cold. Every ride last week was at night and the temps where hitting down to 35F give or take a few degrees. I didn't notice any difference in battery capacity at all. I pretty much wind up charging my Di2 battery about every 1000 miles or so regardless. Even then, I've not seen it get lower than 40%. I would say it is has not been an issue for me.
J.
Quoted: 99 Post(s)
Bikes: Steel 1x's
Quoted: 632 Post(s)
