The Component Everyone Loves (Except You)
#76
Quoted: 3015 Post(s)
Liked 3,805 Times
#77
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
FYI. It used to be a fairly commonly held view that galvanized spokes were superior and stainless spokes were for dandies or something. Believe it or not!
There weren't stainless cables in the old days, but the nice thing about galvanized cables it that it was easy to solder the ends. Cleaner look than cable ends.
The early Japanese stainless OEM spokes were often the worst thing imaginable, singlehandedly responsible for countless good Japanese bikes turning up without original wheels on them.
I've got old bikes with galvanized spokes that have serious miles on them with nary a spoke failure. Even some of the rusty-crusty plated spokes survived years of riding without one of them snapping.
#78
Bikes: '68 Masi Special road, Grail bike
Quoted: 108 Post(s)
Liked 70 Times
the 2-bolt seatpost is the BEST. it is the ONLY way to truly be MICRO adjustable.
discard the Campy wrench, the Dia-compe offset brake wrench is 12 point as opposed
to 6. it's also good to have a saddle that you can pull up on the sides. I never really found
that "magic" angle until I went 2-bolt. Avocet and JPR made 2-bolt posts that had bolt heads
that were accessed from below but they're not as strong as Campy
#79
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
Chain lube should have its own section in the Forums so that it can be mostly ignored.
Finally disc brakes...and, for that matter, linear brakes. People have had been complaining about brakes since they were invented. Some are truly bad...spoon brakes, linkage brakes, coaster brakes, etc... but others are only poorly set up and/or people don’t understand how to use their brakes. People think that braking is just pulling a lever but it’s a whole lot more than that. Weight shifts will go a long way towards making brakes more effective.
I have cantilever, dual pivot side pulls, discs, and disc front with linear rear. I frankly don’t notice any difference between any one of them. There isn’t one that works better than the others in my experience. They all stop me when and where I need the to stop whether that is doing 50 mph on a rainy road off the top of the Smokey Mountains with a touring load (cantilever) or dropping 2000 feet over 4 miles on a road that is more rock than road (disc/linear) with a similar touring load.
Stuart Black
Stuart Black
Likes For cyccommute:
#80
only here for the "LIKES"
Quoted: 1644 Post(s)
Liked 2,241 Times
Riser stems
Quill pedals and toe clips
Brooks saddles
Velo Orange anything
Bridgestone xo-1
Barcons.
wow, y'all really know how to stick it to a guy.
Brooks saddles
Bridgestone xo-1
Barcons.
Likes For hazetguy:
#81
Liked 1,296 Times
Looked a little flimsy to my eye, and the brakes often felt flimsy. The freehub of that era often suffered partial failure of the FH body attachment in a non-critical way thankfully (made axle bearing adjustment into a tedious, iterative process involving multiple wheel installations).
But now I kind of like those parts, the crank is lightweight elegance and the rear derailer works ok up to six speeds with say 13-28t ratios. The whole gruppo was commendably light at a cheap enough price to find it's way onto a Ross "Professional" something or other and onto many an SR Semi-Pro. The Semi-Pro in total nearly mimicked a pro bike albeit a 24lb one (can't make myself sell mine).
A set of salmon-and-black Kool-Stop "MTB" pads bring the brakes around and eliminate the squishy feel.
Beware there was an OEM version Arabesque crankset, as shown below, having a swaged spider.
#82
Quoted: 3241 Post(s)
Liked 2,512 Times
Shimano 600 Arabesque. Yeah, it looks pretty with all those squiggly etchings... But the crank, shifters, RD, levers and brakes are poop... none of it really shifts or brakes well. I like the hubs well enough.
KMC Chains- I honestly don't remember what I didn't like- I don't even know if I still have it... but I bought a SRAM to replace it.
Shimano L600 "fingertip control" bar end shifters. Neat concept... but once you use the Suntour versions- they're nicer.
#83
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
As a few others have said, naming something was a bit difficult. I wasn't going list something that I didn't have experience in (like NR/SR shifting/braking, or tubulars), and I didn't want to comment on modern components/trends as this is the C&V section. If I had to say for modern, then yeah, disc brakes as I've had some (Ultegra level, hydraulic) and the front fork feel under braking was unpleasant, the fork was way too stiff (even with 28s), it's a decidedly heavier setup, and the cost vs. convenience ratio was way off. Pads contaminate very quickly and bedding in new pads takes time, in addition to the expense of new pads. Braking was really no better than a good dual-pivot caliper. Finicky and noisy, easily. Kudos to those who have had much better luck/experience with them. Other than running them on a MTB, I will gladly pass on them for road/tour duty.
Likes For RiddleOfSteel:
#84
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 280 Post(s)
Liked 955 Times
(1) Grease both bolts. (2) Leave rear bolt loose; tighten front bolt (with special tool or just fingers) until saddle looks level when you press down on it at the rear. (3) Tighten rear bolt. (4) Repeat 2 and 3 (usually takes two or three tries) until saddle is at correct angle and secure.
I'll take a 2-bolt Campy seatpost over any 1-bolt seatpost I've ever encountered.
The story of my frustrations: I bought a Gitane Grand Tourisme a few weeks ago. This was my first bike with the two bolt post. It was set up a as a "townie" with a big cushy seat. So I threw on an old Titanium Flite road seat I had lying around with very little space under the seat. It was almost impossible to get at the bolts, let alone tighten, I found the Campy seatpost tool on Criag's list and shouted "Eureka - the savior to my problems". Wrong!
I just received an Ideale 90 this week and went out to Home Depot this morning to get the suggested wrench. Worked like a charm. Frustration eliminated.
Now onto French vs. Italian vs. English freewheel challenges.
There is a lot of tricks to learn on vintage bikes. Yet again, I'm learning a lot from the posts here.
Mike
Likes For SwimmerMike:
#85
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
This is why everything is so subjective. If a person likes feedback, they'll like the Suntours..............because they feel like driving an old farm tractor! Noisy, lots of resistance, rachety, etc. The L-600s though, like cruising in a old Caddy or Lincoln. No feedback at all. You have to trust that they work. You think it and it happens. Nothing more. That's what I like. I must be the only one.
I dig the Simplex Retrofrictions- I like that smooth clutched action, and think the L600s are much more brutish in comparison to either the Retrofrictions or any Suntour "Power" ratcheting shifter. Perhaps the L600s were built to a certain standard for derailleurs of the time. I was using it with an M900 XTR- and I just find it has a tendency to go back to it's given starting point.
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
#86
Bikes: many
Quoted: 1448 Post(s)
Liked 1,396 Times
I love my Nitto Noodle bars, Grand Bois Maes Parallel bars and Campy two bolt seatposts. I've got a pair of Monoplaner brakes (and levers with the QR) but have yet to try them. They are hanging off the Serotta I'm building up, so we shall see...
#87
Passista
Quoted: 868 Post(s)
Liked 721 Times
The Campagnolo 2-bolt is a great design IMO. When it came out saddles had more more space for adjusting.
#89
Quoted: 4806 Post(s)
Liked 3,933 Times
Ben
#91
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
I raced and built all my own wheels in the '70s. The popular SS Robegel spokes were beautiful crap. I built one Robergel SS wheel. A spoke head popper. I built alll the rest of my wheels with 15-17 Robergel Sports, the cheap, ugly zinc spokes. Spoke weight roughly that of a DT Revolution wheel and they held up very well (except 3 spokes per set always broke. Replace those three and the spokes outlasted the rims.) I never heard those success stories with SS. Not until Wheelsmith, DT and others came into the picture with far better stainless.
Ben
Ben
I will say I’ve put a lot of miles on those wheels, never broke a spoke and they still spin great. Eventually replaced the Fiamme rims with Mavic via rim transfer. Don’t really ride tubulars on the trails though so I’ve been riding clinchers in recent years.
Otto
#93
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,844 Times
Don't think this has been mentioned
I HATE all those "components" people attach to their handlebars that aren't brake levers.
You know - the bells and whistles and cameras and Garmins and mobile phones and flashy lights and gaudy mirrors.
#94
Quoted: 3811 Post(s)
Liked 6,717 Times
Likes For nlerner:
#95
Liked 3,933 Times
The Component Everyone Loves Except Me
I just realized what that component is. (In terms of this thread - I've known it for decades.)
Shimano brifters. Any model, any year, any number of cogs and chainrings. They will never be on a ride of mine, Not in this lifetime.
Why? Very simple. I realized many years ago riding in the drops that putting my index or middle finger firmly on the brake lever steadied the handlebars and made reaching for shifters and water bottles on poor roads riding low trail, quick steering racing machines a breeze. But doing that and changing gears or chainrings without thinking? Could be really bad!
When I ordered my ti custom, I had it built for DT shifters (though the builder put on threaded stops at the head tube in case I change my mind). I went out and bought 9-speed Campy wheels and cassettes just so if I ever went brifter it would be brifters that couldn't sucker me into a completely preventable crash.
Ben
Ben
#96
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
If it could play an 8-track of Alice's Restaurant on continuous loop, @Wildwood would be all over it.
Likes For SurferRosa:
#97
Liked 2,024 Times
Gonna add another one, as an owner of two pairs of them, who built both of them ("It's not you, baby, it's me...."): H+Son TB14s.
Am I keeping the dark grey anodized ones currently laced to Superbe Pro hubs, fitted with Veloflex Master 23mm tires? YES. They are gorgeous and built well (TB14s do build very well).
The trouble? Really harsh road vibration and impact transfer/feel. 505g a rim--23mm external width (good), sturdy construction (good), confident cornering (good), but characteristics are characteristics, and it takes a 35mm (or larger) tire to quell the harshness and give a more "normal" feel (a la Mavic MA2 or Open Pro, just to name two obvious examples). I had super light Vuelta Corsa Lite wheels that also exhibited this harshness, though not to the degree--likely due to the rims simply weighing less (less mass to calm). The older Vittoria Open Corsa tires also helped. They help everything.
If they don't bother you, or you aren't too worried about road feel for one or numerous reasons (like, you're running huge tires and don't ride crummy roads), please go ahead--there is truly much to like. I just have to (reluctantly) admit I don't like their ride quality give my sensitivities and riding style. Anybody have a spare, polished, 32-hole MA2?
#98
Veteran, Pacifist
Liked 4,844 Times
You just walk right in, it's around the back
just 1/2 a mile from the RR track.
you can get anything you want
at Alice's restaurant
(excepting Alice)
And now In 3 part harmony...
Son, have ya ever been convicted of a crime?
VN veteran, pacifist, resister.
Likes For Wildwood:
#99
señor miembro
Liked 6,491 Times
#100
Liked 2,024 Times
