Bike Friday Pakit vs Brompton
Bikes: 6 speed brompton with rack, rohloff edition birdy III
Quoted: 802 Post(s)
Liked 249 Times
Its very well built and look beautiful but even at what they call 100%, it seems harder than the current front suspension with the normal spring.
The rear is also harder than the red PU block.
So, it depends of you weight, taste and where you are riding: if you are lightweight, look for a soft suspension or ride often on cobbles, I do not think that these suspensions are for you.
If you are relatively heavy, if performances is more important than comfort or if you ride seldom on cobbles, it is a nice upgrade.
But the price of Bikegang 240GBP + shipment + taxes for the set is pretty high (note that other options like the Color+ are even more expensive and do not have a real damping, just a spring or PU enclosed in a nice cabinet).
If you are interested and do not want to pay the ridiculously high price of Bikegang, contact Multi-S on their facebook page.
Anyway, that you buy from Bikegang or directly from Multi-S, the parcel will be shipped from Taiwan.
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
I currently run Kojaks but I put a Marathon Plus on at one point and found I had to move the caliper brakes to the second slot and it was still really tight. The pakiT is not really designed to be used with wider tires. If you want/need them for additional comfort try a thud buster. If you want/need them for things like gravel and sand....consider a 20" wheel BF or other bike.
Palmer
Quoted: 1671 Post(s)
Liked 1,828 Times
A factory BikeFriday pakiT uses 16", ISO349mm tires, not 16", ISO305mm tires. AFAIK the widest tires available in the ISO349 diameter are nominally* 40mm. (That's 1.57" .)
The Schwalbe Marathon Plus tires linberi said she fitted are nominally 35mm wide.
*Bicycle tires are not necessarily the actual width they say they are. They are usually narrower, but not always. The width as mounted also depends somewhat on the width of the rim they are mounted on.
Quoted: 802 Post(s)
Liked 249 Times
Indeed, ETRTO349 is the Bormpton wheel size and most tires are 35x349 because its what the Brompton was made for.
But, maybe ETRTO355 would also fit since its only 6mm bigger?
There are wider tires available in ETRTO355.
Quoted: 72 Post(s)
Liked 19 Times
I can pick up a 3 speed with belt drive and a rear rack in near mint condition for $1425 including shipping. It would mean having to sell off a Brompton which would pay for the Pakit. The question is if I can't mount larger tires what I'm I improving in changing out bikes. The Bike Fridays that I have rode were 20 inch wheels but seemed not quite as solid as the Brompton. I do like the idea of a belt drive and using a handlebar of my choice but other than that I can't see it.
Quoted: 802 Post(s)
Liked 249 Times
The main advantage is that the PakiT with derailleur will ride better than the Brompton with as drawback that it doesn't fold as easily as the Brompton.
But a 3s internal gear hub PakiT will not have any real advantage vs. a 3s or 6s Brompton.
Liked 374 Times
Perhaps I'm missing something. That said, my rear der pakiT rides great. I didn't go for IGH just because I wanted something I knew how to maintain and offered easy flat changes.
Also I would say the pakiT does fold as "easily" as a brompton (I've done both repeatedly) but it does not fold into as compact (read: square) a shape. It's a narrower rectangle. But I actually find it less time consuming to fold
and a lot less fiddly with many fewer levers/knobs to mess with.
Quoted: 802 Post(s)
Liked 249 Times
What I mean is tat with a 3 speed IGH, first like with any IGH (excepted the Rohloff), the efficiency is lower than with a derailleur and with only 3 speed, its not possible to have the optimal pedaling cadence at all speed in all conditions resulting in a slower bike.
I find it a pity for a lightweight fast bike as the Pakit to use such a poor gearing.
I do not like to have to dismount the possibly dirty front wheel to have a compact fold of the bike. I prefer by far, the folding of the Brompton.
Liked 374 Times
I've got both - in different places - and I'm a bit surprised about some of the views expressed. The Pakit is very light, the ride is great, but the fold is frankly a mess. I wasn't a fan of the spike on the front that you poke through the frame approach - even before the spike broke.
The Brompton fold is great but anyone thinking "superlight" is super light is in for a shock. I'm also surprised about comments on service. Bike Friday repaired my bike out of warranty for nothing - and pretty quickly, too. I can't comment for Brompton. I've had that for 18 years without any major problem.
I took a bit of persuading on both Kojaks and lack of mudguards. I'm a convert to both.
I will admit I hate derailleurs with a passion, so I'm probably not best placed to comment, but, to me, the IGH is fine and the main advantage a Pakit has over a 3sp Brompton is still weight.
I also like the Fnhon Gust: the fold is good, light and a fraction of the cost of either of the other two. If only I could make myself a bit shorter (and get over my dislike of derailleurs), it could even be my favourite.
