For the love of English 3 speeds...
Bikes: '72 Peugeot PX-10 '78 Motobecane Le Champion '83 Motobecane Grand Jubile '85 Trek 830 '88 Merckx Team ADR Corsa Extra
Quoted: 472 Post(s)
Liked 1,215 Times
Had a fair number of Raleigh 3 speeds over the years, but never a 5 speed Sprite. I've always liked the chainguard and am intrigued by (and a little skeptical of) Sheldon Brown's claim that the Sprite is a livelier alternative to the the Sports. Might like to try out this Sprite during the winter. Anyway, I'm curious if there's a consensus on the 5 speed drivetrain. Does it work well enough? Any chronic issues?
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 377 Post(s)
Liked 901 Times
The original version of the S5 hub works fine. The problem points to watch are the original, plastic shifters and the original thin metal bell crank. If you get one with the improved bell crank and pushrod, that's a good start. An improved shifter set up would be a friction shifter non-drive and a 3-speed thumb shifter on the drive side. The original S5 is a little trickier to work on than the 3-speed AW, but it's not overly difficult either.
Just comparing the hubs alone, the S5 gives substantially more range than the AW does. But being coupled to a bike that is otherwise the same (apart from the hub, the Sprite is functionally the same as the Sports), that waters down your gains from the hub. The Sprite is a bit livelier, but you're not getting the most out of it on that bike.
Where an S5 would really come into its own would be on something like an old Lenton or Clubman. The lighter bike could really get going with the tall top gear, and could really bite into the hills with the low bottom gear.
They also can do well on a DL-1 where the extra range is appreciated on a heavy bike.
The S5 was a hub that came after its time. Sturmey Archer was faced with cost-cutting and failed projects like the SW and TCW that should have instead been spent bringing the S5 to market. The S5 should have come out right after the FW did, being derived from the FW. A 5-speed hub coming out in the 1940s or early 50s would have been a revelation to riders and a premium component at that time. But hindsight is 20/20.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Quoted: 3819 Post(s)
Liked 6,756 Times
I had one of those 5-speed derailleur equipped Sprites, and the shifting performance from that original Huret mech was consistently awful. It did allow me to recreate the 1970 Raleigh catalog photo shoot, however.
Likes For nlerner:
I think that's what I had on a Schwinn Collegiate from the same era, and I agree on the awfulness. No matter how much it was adjusted, it never had more than four of the five possible gears, and frequently would only have the three middle gears. How could this derailleur could be considered an "improvement" over, or even a substitute for a Sturmey five speed hub (or even three)? They probably used them because people started thinking derailleurs were "better".
Likes For adventurepdx:
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1301 Post(s)
Liked 942 Times
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Likes For 1989Pre:
Quoted: 480 Post(s)
Liked 640 Times
A bit of a wander from 3-speeds, but I had both Svelto and Allvit equipped bikes at the same time and found the shifting of the Allvit to be surprisingly good: I had always eschewed the Allvit as being a low end derailleur. Svelto was also fine but not as good as even a delrin Simplex.
Likes For markk900:
Quoted: 472 Post(s)
Liked 1,215 Times
Thanks for all the responses, everybody. Thought there were some issues with the shifter and RD. Appreciate the suggestions too, Sir Mike. I think I'm gonna check out the bike and give the drive train a full inspection. If I can pick this one up for south of $100, might be fun to tinker with.
Likes For Sedgemop:
Palmer
Quoted: 1685 Post(s)
Liked 1,846 Times
Fun fact: Sturmey-Archer filed their first five-speed patent in 1922!
Likes For tcs:
Quoted: 472 Post(s)
Liked 1,215 Times
I endorse this peak bike nerd activity. Nicely done.
Likes For Sedgemop:
Palmer
Liked 1,846 Times
In America, Varsities came with Allvits, and the derailleur was considered a bottom feeder.
IMO the unique Allvit is really a cool rear derailer. It features:
1. A parallelogram action that moves down as it moves in. This allows the guide pulley to maintain an equal distance from each of the 14-28T cogs for accurate shifting.
2. A guide pulley that is mounted co-axially with the cage pivot. The guide pulley doesn't change its position relative to the freewheel cogs when the front derailleur is shifted. This allows consistent rear shifting even with large size differences in the front chainwheels.
3. A derailer body that forms a protective cover over the working parts.
4. A well-thought-out, highly producible design for manufacture - there is really only one part, the main control arm, that can't be made from sheet metal or on an automatic lathe.
"I was too hard on the Allvit." Frank Berto
“The innovation continued with the 1958 Allvit, which was the first drop-out mounted derailleur that featured a constant chain gap – achieved by suspending the parallelogram from the bottom of a steel arm that mounted to the dropout. A few years later, the Allvit directly inspired SunTour’s slant parallelogram derailleurs.
“During this time, Huret’s derailleurs were considered the best-shifting and most durable derailleurs for the wide gear ranges. Both René Herse and Alex Singer equipped most of their bikes with the Allvit, Luxe and super light Jubilee derailleurs that remained in the program for 35 years.” - Jan Heine
On the road
Quoted: 377 Post(s)
Liked 901 Times
I guess this is a 5-speed derailleur Sprite rather than the S5 Sprite. I'm not sure why the pictures of the bike won't show up on my computer, but my fault if I've got the wrong Sprite.
On the 5-speed hub, yes- they had a concept down early on. I first learned that when I got Tony Hadland's excellent Sturmey Archer book and read through it. I was surprised that they were so far advanced in those post-WW1 years. It would have been a huge leap forward in 1922. Even had the S5 come out 30 years later, in 1952, as a follow-on to the FW, that still would have been good progress. By bringing the S5 out so late (along with those fragile plastic shifters and the sheetmetal bell crank), it sort of became a footnote rather than a key piece of what Sturmey was offering and selling.
Likes For SirMike1983:
Quoted: 472 Post(s)
Liked 1,215 Times
Likes For Sedgemop:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,448 Times
Rode my Sports for the first time in months today. The Brooks B15 from an old project Raleigh Competition hurts my out-of-condition butt, the stem reach is too short, the grips bug my hands and when braking the rim irregularities bother me. I really should make the time to correct all these things and ride it more. It used to be my school commuter. I'm also going to ride the Marin dropbar conversion tomorrow. These two were the easiest to get to and all they needed was to be aired up. I'm also trying to declutter the garage.
Likes For thumpism:
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
Standard Member
Liked 942 Times
My newest acquisition, a '65 Hercules, was abandoned. It needs a new rear tire and tube, and some tuning of the shifter/cable, but after that, it will be offered for sale as a pair with a ladies '55 Elswick. The bars are narrower (49cm) on the Hercules than they are on my Rudge Sports. Maybe the bike is a juvenile model.
The fan is two years newer than the bike.
Likes For 1989Pre:
SE Wis
Quoted: 2751 Post(s)
Liked 3,409 Times
The original version of the S5 hub works fine. The problem points to watch are the original, plastic shifters and the original thin metal bell crank. If you get one with the improved bell crank and pushrod, that's a good start. An improved shifter set up would be a friction shifter non-drive and a 3-speed thumb shifter on the drive side. The original S5 is a little trickier to work on than the 3-speed AW, but it's not overly difficult either..
Likes For dedhed:
Count Orlok Member
Palmer
Liked 1,846 Times
Clocking in at the Sturmey-Archer factory in 1980: 6-minute film.
https://www.macearchive.org/films/ra...3srenG6fT1UhdY
Bikes: Several
Quoted: 74 Post(s)
Liked 168 Times
Hi tcs.
Thanks for the link to the video.
It fairly highlights conditions in a typical component factory of the time.
Frustrated workers on piece work, trying their best operating antiquated and worn out machinery.
I'm amazed the management allowed the film company onto the shop floor.
It's much the same now at the Brooks saddle factory; an outfit sadly reduced in size, getting by with antediluvian equipment, trading as a premium equipment supplier, portraying their products being made by craftsmen and women, which tells the lie of under investment.
From what I can see, it won't be long before they go to the wall too.
Grab 'em while you can.
Just finished reading a fascinating book published in 1975, 'The Story of the Raleigh Cycle', by Gregory Houston Bowen.
As the title implies it gives a (rosy) commentary of the companies development up to their 'hay-day' of the mid 70's.
The last chapters cover the authors tour of 'a thriving' factory, describing manufacturing practices at that time.
An example is Raleigh's chroming methods, which was a 4 part process, which confirms why their brightwork stands the test of time. Also their paint processes, including the 'mystical' 'Bonderising' rust prevention undercoat.
Of paramount interest to you in Canada and USA is a thorough description of how Raleigh established themselves there; alluding to what was done where and when.
Also describes the reasons for selling the 'Shop' brands and marketing of the 'lesser' marques, such as Philips and Hercules etc.
This is as near as the horses mouth as you're likely to get and certainly clears up many of the myths prevalent on this excellent and enthusiastic forum.
As I mentioned, the book gives a very positive take on what was after all, the worlds largest cycle manufacturer, with 'a bright future ahead'.
In retrospect; true irony.
Well worth hunting down a copy..
On the road
Quoted: 377 Post(s)
Liked 901 Times
Cleaned and refurbished this 1957 Schwinn Traveler 3 speed recently. It's a nice companion to the 1959 Traveler I rebuilt back in the summer. I might get a shakedown ride or two on it, but serious riding probably waits until next season.
Liked 2,448 Times
I just bought one also. What are you going to do with it.
Palmer
Liked 1,846 Times
The weight is unfortunate, but even after 40 years, the folded size is competitive. Alloy rims, upgraded pedals, brakes. Fresh lubrication in the AW. Here we are in Old Town Crumbnik, Lower Slobovia:
The desirable models are the ones with stainless steel frames. These SS ones even have some collector value.
Likes For tcs:
Liked 2,448 Times
Likes For thumpism:
