New Flat Stategery?
Bikes: Trek Domane 4.5, Trek 1500
Quoted: 20 Post(s)
I read a piece recently mocking certain practices amongst cyclists that were judged as just too uncool to consider. One of them was wearing a Camelbak or equivalent. It didn't make much sense to me, and doesn't now. Having two quarts of cool water when the temp is up in the high 90's is really nice. The wife & I did a multi-day tour last summer that had the choice of a 14- or 25-mile "warmup" on Friday night. Because Marcy isn't the avid cyclist I am, we did the 14-miler. Temp was 98 at 6:00, and we both completely drained our 2-quart Camelbaks over that distance. I also found the next day that the Cambelbaks are so well insulated, I could load it up with ice and water, and when the water was gone there was enough ice left that I could transfer the warm water in my water bottles to the Camelbak and still have cool water to drink after 40 miles.
Used to ride MTBs on goat-head infested roads, paths, and mountain trails. During certain times of the year you could ride for "weeks on end" without any GH induced flats. Other times you'd swear that the roads and trails were paved with the darn things.
This quickly taught me to carry several CO2 carts and a spare tube in a small "everyday" tool kit and a pump in a "long distance" luggage rack mounted bag along with another spare tube, etc. Never had a case where I couldn't ride home due to flat tires.
As for the water issue, too much is almost not enough if you ask me.
Bikes: Bicycles
Quoted: 8 Post(s)
Yes indeed. I use baby powder. Back in the day it was called Heat Powder.
I've torn punctured tubes that have been in service for several years because they bond to the tire's innards.
If the tube is a little over-sized, I think it helps it unfold on inflation.
Bikes: 2013 Specialized Seceur Elite, Soma ES custom build
I have a new bike on order, and was planning on doing some practice flat repairs so I can do it quickly when
on the road. I'll dust some powder in the tires when I do that.
Time for a change.
Liked 5 Times
Camelbacks and mountain biking and it was used on every ride. Road bike and two bottles are enough for the local rides except I only have space for one bottle due to the Mini/Road morph taking the place of the other carrier. I would rather go with just one bottle than leave the Morph at home so Use the camelback on the road in the summer.
And on Talc-My spare tubes are in plastic bags that also have talcum powder in them.
Spike Milligan
Spike Milligan
Bikes: Fuji Cross Comp, BMC SR02, Surly Krampas
Quoted: 7 Post(s)
Years ago I had a bike shop lady tell me how to pick out a pump. "You don't have a flat very often but, when you do, you're likely to be aggravated."
"If you're the kind of person who doesn't upset easily, it doesn't matter because you don't flat very often. You can get the smallest most compact pump you can find. It will just take longer."
"If you're prone to anger, you want the biggest, fastest, most convenient pump you can handle on your bike."
Quoted: 7 Post(s)
If you are one of those fortunate people that rarley has a visit from the flat fairy- then you had better make certain you ride with others when she does visit you. That pump that has sat on your frame for the last 18 months may not work when you want it to unless you have checked it out to see that it still works. I do not have that problem and have resorted to buying tubes in bulk.
I still have my Zefal HP frame pump I bought in 1982, and it works beautifully. Use it in my shop for lawnmower tires. I think it may find its way back on my commute bike...
Just a new guy here. Started riding just last year after 40 years. Flat tires, and opinions or comments with those fix a flat type fast on the road again aerosol cans. Thanks much.
Bikes: Bicycles
Quoted: 8 Post(s)
I have found it best to carry a spare tube and patch at home. Presta valves make it easy to suck the tube down to repacking size.
Welcome to 50+ doat.
I always pump up the tires to 95psi front and 105psi rear before heading out for the day.
At home I have a good-sized floor pump w/ built in gauge. For the road, I have the Zefal HP frame pump that I've carried for 35+ years. Actually my third one. The first got bent on a doggie-noggin in '77 on a ride out in the sticks, the second got snagged by a pants cuff and ficked out of the frame, only to be run over by the rear tire in '78. The third one is still going strong.
As with car tires, bike tire inflation is important to performance. Bike-tire engineers look for optimal deflection, or expected flexing, for the best grip, comfort, efficiency and comfort. The most important variable affecting the ideal amount of tire pressure is the load your tires need to carry. For riders who weigh more than 180 lbs., inflate to the maximum pressure indicated on the tire sidewall, recommends Michelin. For riders who weigh less than 110 lbs., inflate to the minimum pressure.
Your weight, along with how your bike distributes weight, may require you to change the air pressure in one or both tires to gain maximum performance. Depending on how your bike distributes weight, you can have between 55 percent and 65 percent of your body weight on the rear tire. If you are heavier, you may need to increase the back-tire PSI until the firmness matches the front tire when sitting on your bike
Scorpion King
Road Cycling
15
03-08-11 02:27 PM
