Rear brake superfluous ?
Quoted: 8370 Post(s)
Liked 9,222 Times
fwiw, I always wear out the pads on my rear brakes first, both mtb and road. I'm about 200 pounds and use the rear to help control speed on twisty roads. In fact, I almost always use both brakes during normal stopping, even in the city.
On the dirt, the front brake can get you into trouble when things are loose and rocky. Braking early for turns is the key.
Riding motorcycles in the dirt lets you practice sliding the rear wheel around and it works on mountain bikes, too. Obviously, road bikes are not supposed to be drifted into turns but those reactions learned on dirt can help if you do get the rear wheel loose.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
This is why cool kids shouldn't tease the dorks in middle school; it scars them for a lifetime.
In truth, fixed gear riders often go brakeless or front-only simply because their track frames aren't drilled for brakes.
But don't let me interrupt your "I am the real cyclist. All others are posers" mantra.
Likes For Rolla:
Quoted: 1324 Post(s)
Liked 927 Times
One time when I was left hooked by a car I was very glad I had a quality working rear brake. I was able to lean the bicycle a bit and hit that rear brake hard and it caused the rear wheel to slide in a controlled manner and the bicycle did a 90 degree instant turn and was parallel to that vehicle. Had i not had a good working rear brake I would have hit that vehicle.
Cheers
Cheers
Quoted: 3598 Post(s)
Liked 3,016 Times
Not having a rear brake would upset the front/rear balance of the bike.
Quoted: 7087 Post(s)
Liked 11,198 Times
Liked 3,016 Times
Liked 11,198 Times
Habitual User
Quoted: 5047 Post(s)
Liked 8,306 Times
Funny, MTB guys find it useful to be able to lock up the rear wheel. A locked rear wheel is also fairly easy to control, if you've got your weight back, like you should, when you're braking hard.
Riding MTBs and Motos, on loose surfaces, and on the street you can feel the effects of braking one wheel or the other much more distinctly than a rigid road bike. Loose surfaces will show you very quickly, the way braking cuts into the "traction budget" available to your wheels for things like steering and lateral grip.
Motos, with their far higher weight, and suspension, can demonstrate much more clearly how braking one wheel or the other affects the distribution of weight from front to rear that's not as obvious on a rigid road bike.
For example, on a bumpy corner, you want to shift your weight back, and keep your arms loose to lessen the shocks, but that takes away from the weight you need for grip, and keeping the wheel in contact with the road surface. Trailing the rear brake makes the frame rotate around the rear axle, applying force (but not weight) to the front wheel, helping keep it on the road, and adding to the available grip.
Brakes aren't an either / or all-or-nothing proposition either, and I don't know why that trope persists around here that managing two handbrakes is so challenging.
My feeling on this is that unlike MTBs and motorcycles, a road bike (on good pavement) lets you get away with bad habits until a much higher threshold, until it bites you; at which point " Two Handbrakes is too hard!"
Likes For Eric F:
Liked 3,016 Times
Habitual User
Liked 8,306 Times
my own experiences in tight, hilly, wet conditions that lead me to believe that rear brakes are of extremely limited value in downhill turns. I wouldn't want to not have a rear brake, but I don't think there are many circumstances where it will save you instead of contributing to a loss of directional control.
Likes For don compton:
Dirty Heathen
Quoted: 894 Post(s)
Liked 936 Times
Koyote clearly, we are not erudite enough cyclists to understand this sophisticated brand of humor. Yea, our tires are too wide, our bicycles not Italian enough and our sock lines not sharply defined.
Go, now and do your penance: an hour of hill repeats, and 10 Hail Mercxxs. Then maybe we'll understand what he's blathering on about.
Likes For Ironfish653:
Quoted: 4854 Post(s)
Liked 3,994 Times
And an observation from this guy who has ridden a lot of miles fix gear, always with two good brakes. Rear brakes work really well on fix gears; in fact better than on road bikes because you have instant lock-up feedback. A tool I used in snow and ice many, many times in my midwest and northeast commuter days when I rode n everything. This gave me braking in really slippery conditions where touching the front brake was a way to greet the pavement/ice instantly.
Quoted: 1607 Post(s)
Liked 1,798 Times
Years ago when I was learning to ride motorcycles I was told to apply the rear brakes hard first and then follow with the front brakes. The reason is by applying the rear brake hard, you squat the rear end. Now you apply the front also- the whole bike squats down and you have a well controlled two wheel braking. If you apply front brake first the front will squat and the rear will rise, and you are on your way to an endo.
On a bike with no suspension, the effect is far less pronounced, but I still find it beneficial to brake the rear hard first, and then follow a split second later with the front. As Cyccocommute says- it you over-rely on the front, you will find yourself lifting the rear tire.
Liked 3,016 Times
Liked 3,994 Times
Redundancy in key systems is a concept deeply in-bedded in the practices and regulations of the aircraft world, the marine world, the automotive world ... Just one brake and a freewheel between the engine and drive wheel? The designers and regulators of any of those other modes of transit would shudder.
Likes For 79pmooney:
Habitual User
Liked 8,306 Times
Liked 3,994 Times
Quoted: 3998 Post(s)
Liked 7,490 Times
Liked 7,490 Times
A big difference between bicycles and motorcycles is that our body is a much larger percentage of the total weight of the package, and shifting our weight has a larger affect on braking dynamics. Shifting our body rearward as we brake hard keeps the rear wheel firmly planted, and contributing to deceleration.
Quoted: 4554 Post(s)
Liked 1,697 Times
Liked 1,697 Times
That hasn't been my experience. For the most part, I try to do as much of my braking as possible while the bike is still going straight, using both brakes, with the front doing most of the work. Once I'm in the turn, I try to stay off the front brake and let the front tire's work be as dedicated as possible to just traction and direction. Any additional speed control is managed by the rear brake. Understanding how body (COG) position plays a part in cornering dynamics is an important factor in this, too.
Habitual User
Liked 8,306 Times
There are probably some principles that apply to both, but it's not universal, for sure.
