Does a more upright position give more power?
#51
Randomhead
Liked 3,699 Times
It's all about what you have trained. In general, you could train yourself to go faster on a drop bar bike than an upright comfort bike. But if all your training to go faster is on an upright comfort bike, you will be faster on that bike.
One time I was about a half mile from home and a guy on a hybrid pulls in front of me and gives me the look. I was tired, but there was no way I was going to ignore that. Well, I never caught him. He sat very upright too, not like when you see mountain bikers pushing hard in a bent over position.
#52
Quoted: 1858 Post(s)
Liked 664 Times
I also think your description of energy versus power is very good - glad to see a good application of basic physics in this.
#53
Liked 664 Times
In my experience added arm force can significantly improve my sense of power. I don't use a power meter so I don't know if I'm really making more watts.
#54
Liked 664 Times
Yes, one guy at least said the body weight is the most you can give. I think you can get a little more if you also pull up or back on the handlebars. Subjectively I think it helps a lot.
#55
Quoted: 967 Post(s)
Liked 1,631 Times
For me when I could negotiate a steep climb I found it better to be over the bars hands on the front of my break levers and tip toes in the pedals. That is where I was stretched and my chest was above the front axil.
(Now days a steep climb is an exercise in futility... Yep)
#56
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
You can also open your hip angle on a road bike by sitting at the tip of the nose (if your saddle allows you to do that without hurting the family jewels) and sitting more upright by holding the ramps or tops of the dropbar. I do that a lot when doing long and steep climbs.
The stronger position for climbing is with your hips pushed back on the saddle, which opens the knee angle and allows more force to be applied to the pedal.
Proper seated climbing form, from us.humankinetics.com
Likes For terrymorse:
#57
climber has-been
Liked 3,567 Times
That position makes climbing less fatiguing.
Leave the sit-on-the-saddle-nose trick to mountain bikers.
One technique that I encourage in my athletes when they are climbing in the saddle is to slide a little farther back on the saddle and drop the heels slightly to better engage the hamstrings. This approach allows the upper legs (femurs) to act even more like a lever to concentrate force on the downward stroke of the crank arm. The result can be a 5- to 10-watt improvement in power output.
-- Cheung & Zabala, Cycling Science
Terry Morse, Heartbreak Hundred (2006-ish)
#58
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
IMO a person that sits pretty much at a level of the crank on a recumbent bike can probably exert more power. Even standing a cyclist can only exert his weight, plus what force he can add by pulling up on the handle bars. On a bent he can apply power greater than his weight by wedging his leg between the pedal and the back of his seat. Pretty much like sitting on the floor and pushing against a refrigerator to move it.
Which is why that's the preferred method of moving refrigerators?!?!?
I produce a lot of power sitting on the seat of my upright bike. You literally have no clue here whatsoever.
#59
Tragically Ignorant
Liked 9,098 Times
Let's keep in mind that as you climb, the front wheel is higher than the rear, so if you're remaining seated, you're essentially "leaning" forward compared to your flatland riding position.
Likes For livedarklions:
#60
climber has-been
Liked 3,567 Times
You've probably seen pro cyclists climbing steep grades, rocking their torsos side to side and downwards on each pedal down stroke. They are using the upper bodies to put as much force into the pedals as they can. They're also using their arms to move their torsos.
Just today, I went up a short but steep grade with a fairly high gear, in the saddle.
With hands in the drops and chest leaning over the bars, I was rocking my shoulders side to side, pulling gently back on the bars on each pedal stroke. It felt powerful, and I made it to the top without dropping my cadence. I couldn't have done that without the use of my torso and arms.
Give Your Legs Help
When the grade gets so steep that you’re sliding into standstill (and topple) territory, tuck your elbows into your sides, dip your torso toward the bars, and gently but firmly pull back on the bars with every downstroke. This lets you transfer power from your upper body through your core and into your legs to assist you in forward progress.-- Tricks to Help You Climb Better on Your Bike, Bicycling, 2021-03-12
Credit: GCN
#61
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
I am not convinced that pulling on the bars in a steep climb is necessarily wasted energy. That pull helps engage your torso over the bars, which allows you to put more downward force into the pedals.
Otto
#62
Tragically Ignorant
Liked 9,098 Times
Watch this cyclist use his upper body to climb a super steep grade:
Credit: GCN
Credit: GCN
I realized today, and I think this video bears me out, that I'm pulling on the bars in part (at least) to counteract the sway in my hips as I climb. Definitely helps generate power.
#63
Quoted: 3352 Post(s)
Liked 1,056 Times
There are thousands of post on pedaling in circles. Yet the more or less horizontal position I have on my trike seems to end up in pretty much a push pull situation.
I have no proof but it seems to me that this push pull actions allows me to put out a lot more power that I did on an upright position on a DF bike. It could also be acquiring "recumbent legs" after all these years on bents. It has been 16 years on bents.
#64
Tragically Ignorant
Liked 9,098 Times
Really a different question than the op because, as you point out, it's not the same pedalling motion. You're right that you can produce more power in the flat than you would on a dd frame bike, but you can't "recruit" gravity by standing on the pedals which is really the only power advantage a dd frame has. You're also developing muscles somewhat differently than you would on a dd bike.
#65
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
So part of it is that you're already in a far superior hip angle situation one way or another. As stated before, often a primary reason folks make a lot less power on their TT bike than their road bike. And a primary driver of UCI rules against TT bikes.....prevent TT bike riders from adopting a prone-recumbent position. Folks who "get" that tend to understand TT bike fit and do well with it as you understand that if there's rules against it, that's what your ultimate goal in that fit is..........get as close within the rules as you can to a prone recumbent position.
#66
Quoted: 18424 Post(s)
Liked 15,572 Times
FIFY
#67
Quoted: 4260 Post(s)
Liked 1,364 Times
Everytime his body drops, there's less pulling on the bars and less weight for him to pedal against.
You can add more pedal force by pulling on the handlebar.
Rocking torsos side-to-side is a means of moving the body weight over the pedals. Or a result of using the bike as a lever (or blending both things).
At a low cadence, one can use the bike as a lever by pulling fairly forcefully on the opposite side across the bike.
#68
climber has-been
Liked 3,567 Times
Originally Posted by indyfabz;22075111, [u
arm warmers 2/3 of the way down, morning paper sticking way up from jersey pocket, mini frame pump, dirty, mismatched water bottles and different length valves with different color caps[/u].
But you forgot to mention "stem not flipped".
BTW not the morning paper. The course route sheet.
The mini-pump came in handy. I flatted twice in that King of the Mountains series.
#69
climber has-been
Liked 3,567 Times
Yes, it absolutely is. It's putting more force into the pedals at the top of the pedal stroke, right where he needs it the most to keep from stalling out.
Sit on the edge of a chair with your feet on a bathroom scale, leaning forwards. Note the reading on the scale.
Now rock your torso forward and back. Notice the scale reading rises substantially.
#70
Liked 1,364 Times
If he's pulling his body down with his arms, then that force isn't available for the feet to push against the pedal.
He might get a small advantage when the upper body bottoms out.
But it's much less effective than pulling on the bars and keeping is weight stable and over the pedals.
"Rocking" seems to be moving side-to-side (which isn't the same). The person in the video isn't moving much side-to-side. He's bobbing (quickly bowing), breaking at the hip.
The bobbing feels like one is doing something but it isn't making the climb easier.
#71
climber has-been
Liked 3,567 Times
Small advantage? You wouldn't say this if you've climbed a very steep grade in the saddle, where it's a full out effort just to keep the pedals turning.
A bobbing upper torso can make the difference between turning pedals and stalling out. Anyone put in that situation adopts the behavior naturally.
#72
Liked 1,364 Times
A bobbing upper torso can make the difference between completing the climb and stalling out. Anyone put in that situation adopts the behavior naturally.
It might be the only thing you have left. But that doesn't mean it's a good technique.
If the bobbing thing was such a great technique, it would be recommended in things written about climbing technique.
Facebook Post
" data-width="500" data-show-text="true" data-lazy="true">
Facebook Post " class="fb-xfbml-parse-ignore">Facebook Post
#73
climber has-been
Liked 3,567 Times
It depends on the situation, of course.
When the choice is pedaling or walking up a super steep grade, bobbing--which help keep the pedals turning--is a "good" technique.
In other situations, bobbing may indicate that the rider's quads are fatigued. They are engaging their core muscles to spare the quads. Some refer to this as "pedaling squares".
#74
Liked 1,364 Times
If it was ever a good technique in any reasonably common situations. it would be recommended more generally.
No, they are just wasting energy.
Likes For njkayaker:
#75
climber has-been
Liked 3,567 Times
Some guys on bikes said it doesn't look "pro". Well, that's the last word on that, isn't it?
"Wasting energy" -- stated as fact without supporting evidence.
At any rate, how high on the importance scale does "wasting energy" sit when your quads are fatigued or you can't make the pedals go round?
Bobbing engages core muscles to help put more force into the pedals. That's about all.
