Fully loaded carbon ?
#76
Crawler
The weight low down makes the bike turn sluggishly and there's always the issue of balancing the panniers. I like putting the weight under the saddle because for 90% of my riding I don't notice it. Out of the saddle it does make the bike feel a bit top heavy at first, but you quickly get use to it and I find myself climbing out of the saddle a lot. My handlebar bag has more of an effect on handling most of the time, but as you point out the low weight keeps that to a minimum.
If they are the same weight, the top-heavy bike will be much sluggish because you have to transfer your weight one side to the other. More you lean, it's tougher to switch direction due to the weight on top. You may "feel" it's okay, but it's simple physics.
#77
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I disagree. Mass up high close to your body doesn't move much when establishing a lean - the wheels move out (wheel contact patches move left in order to establish lean to the right). Mass close to the rear axle makes turning slower. Mass aft of the rear axle makes things really weird.
#78
As I mentioned when out of the saddle there is an issue, but when in the saddle having the weight as close to the rider as possible has the least effect on bike handling. With the saddlebag tight up against the seat post the rider does not have to fight against front panniers down low when turning or feel the tug of rear panniers. Of course it's critical to have the load well secured to eliminate bag sway as that can be very disruptive. I sometimes see bikepacking saddlebags that are pretty loosely attached and stick out a long way behind the rider and think that it must be hard to ride like that. With the transverse saddlebag tight up against the saddle sway can be eliminated and the mass kept very close the rider's butt. This is indeed all simple physics.
#79
Crawler
Likes For tyrion:
#81
Crawler
I don't know why you are talking about Bikepacking saddlebags. It's not relevant to what we are talking about. The only thing that I was talking about was height of the weight you are carrying. So when you say "This is indeed all simple physics" is not relevant.
I'm pretty blunt with BS. Next time, just put "In my opinion" before.
#82
I brought up bikepacking saddlebags as a point of comparison because they are also mounted to the saddle and might be more familiar to the community.
#83
I'd say that given that most of the riders here have lots of experience riding happily for years with their respective lightweight setups, there certainly is no "right" answer here, so please keep the discussion polite.
Likes For djb:
#84
Crawler
Only considering the height is not enough. Many pannier setups will place the load quite a way from the center line of the bike and a long way from the rider and the ground contact patch and so it's not as easy for the rider to correct unbalanced forces that might occur. Of course the stability and slow response that such a setup produces has long been seen as either an advantage or a necessary evil. With a saddlebag the correction only requires a subtle shift from the rider. Of course if the saddlebag weights 50lbs and the rider is 100lbs the correction would need to be far from subtle. I'm not saying a saddlebag set up is more stable than one using panniers, just that it changes the handling of the bike less.
Stop making excuses. And your false claim with panniers makes things worse than a saddlebag.
#85
Quoted: 18428 Post(s)
Liked 15,582 Times
#86
Riders who currently tour on carbon touring frames love them. Makes perfect sense to me. Many of these riders are using only rear panniers. This doesn't work on a steel bike - they become whippy - but works on carbon because is's stiffer. Be that as it may, some carbon touring frames come with forks with rack fixings, some don't. Here are 45 carbon touring frames to choose from: https://www.cyclingabout.com/carbon-touring-bikes/
More carbon bike porn: https://www.cyclingabout.com/2017-di...-touring-bike/
Carbon touring bike reviews are harder to find:
Carbon fiber makes a horrible touring bike; I love my new carbon fiber touring bike « Ride for Climate
As you can read in the comments in this old thread: https://forums.adventurecycling.org/...p?topic=3623.0
carbon has come a long way in 10 years. Most folks now are still 10 years behind the times.
For many years, I was the old school roadie with my steel frames. I resisted change, but finally changed to an AL/carbon seatstay frame, and later full carbon frames. In terms of road ride quality, there was no comparison. The newer frames were lighter, stiffer, and more comfortable. For the 700x23 roadie, they were simply better. Would this entirely translate into the same winning impression with wider low pressure tires? I don't know, but I'd be willing to find out.
My "gravel" bike- a frankenbike steel 26' mtb and 700c wheels has been loyal, but has always suffered, from old worn spare parts "itis", with worn chainrings, sloppy derailleurs, and a pieced together feel. It has beaten me to death on gravel road washboard. I have experimented with softride stems, and hybrid forks, rebuilding some into longer travel magic carpet ride beast, and even larger tires at lower pressures, which still cannot respond to the high frequency of the washboard.
One of these newfangles gismos could address at least some of my concerns- short wheelbase for better climbing, disc, for the steep descents out here (20%+ extended grades which eventually cup out the sides of my rims on my rimbrake bikes), and perhaps... just perhaps.. .a little better dampening from the carbon on the gravel washboards of death.
This leaves me considering a gravel type bike. Even looking at some pricey models $5-6k plus, I'm only semi- impressed. They are expensive, and don't have the gear ranges someone in the mountains (actually loaded and touring) would need. As one goes up in price towards the higher models, the rims become nice lightweight trinkets, great for racing, but not something one would want to seriously tour on loaded (approx 1200-1300 grams for one set?- lighter than my zipp 202's).
Looking recently at the models the bike shops stock, the carbon rack attachments appear to incorporated, some, with more thought than others. A rockymountain fork has attachments, but they point forward at 20 degrees, suitable perhaps for a bottle cage, but not easily mounting a front rack. A niner rdo has rear rack attachments, but they are incorporated into a super slim seatstays, more designed as a flexible CF shock absorber than a rigid mounting point. The Trek bikes list all their AL/and carbon frames weight limits at 275lbs. Since all of their frames have the same spec, it looks like someone picked a number, somehow, but not necessarily by testing a frame loaded with gear.
Fortunately, at this point, as much as I want to bike the bullet and buy something, the sobering reality is that I'd just be tinkering again, swapping stuff out, redoing drivetrains to find lower gear inches, and building new rimsets for specific task.
I think for light/ credit card touring on relatively flat ground the current crop of gravel/adventure bikes potentially could be great. I think a custom carbon frame built up for a specific task could be great, but most of these bikes seemed to be aimed at checking off as many boxes as possible to appeal to the masses. Cyclocross.. Gravel Riders..adventure riders..light tourers..
I think the market needs to sort itself out some more.
For a hardcore tourer? I don't know, maybe, maybe not. I might be buying one as a gravel racing/cyclocross rig, with potentially mounting some extra bottles for longer rides. Keeping it light not to have to mess with gearing. I think in that capacity, it might be great.- and if I do get one, I sure as heck am going to be putting racks on it to experiment!
#87
The exception is when/if you need to carry multiple days of food and water, but that can sometimes be planned around by using food drops/caches or sometimes minimized to just a short section here and there and carried on your back if just for a day or two.
#88
#89
^And I think that is a good point. Some of my best trips were impromptu lightly packed events. I know I've "blown up" the touring section recently with all the pics of my blingy schwinn, with way too much bag potential. It's like a 747 heavy. I could load that bike up, remove half the bags, and it would still be overloaded!
But even lighter/medium loaded, I wonder about the potential of carbon gravel frames/geometry.
There is a 200 mile gravel ride coming up here shortly. A fellow rider wants to hunker down and go heavy, turning it into a 3+ day ride. I want to go light and do it in much less time.
This ride is one of the things that has me looking at a newfangled gravel carbon bike- staying light, fast, and comfortable as possible. Perhaps one bag tops, and pushing hard, strategically getting to hotels and credit carding it. More mileage, better rest, fresh showers, back to work the next morning with a warm fresh meal.
My post was really mentally hashing out (perhaps to myself) how a carbon frame could be used. Would it be a good heavily loaded tourer? Would it stand up? Someone mentioned the shorter wheelbases perhaps causing interference between the shoes and pedalling. I don't know. One of my dream rides would be from Kathmandu to India. Is that something I'd take a carbon frame on?
Most of the carbon frame loaded pics I see are frame packs and stuff suspended magically off the back of the seatpost. I do know in the mountains, with loaded panniers, I am running 20-34 happily. 32-34 is fine unloaded. A lot of these bikes are 1:1 or 32-34 lowest, great for unloaded.
Just thinking out loud.
.ps- I was also looking at the diverge recently. The front suspension reminds me somewhat of the softride.
#90
Water can be the biggest issue. I've carried mutliple extra bottles using the longflap on my saddlebag, jersey pockets, and handlebar bag. I also have an ultralight nylon back pack that I mostly use for days off the bike, but in an emergency it can be worn on the bike too.
#91
My post was really mentally hashing out (perhaps to myself) how a carbon frame could be used. Would it be a good heavily loaded tourer? Would it stand up? Someone mentioned the shorter wheelbases perhaps causing interference between the shoes and pedalling. I don't know. Most of the carbon frame loaded pics I see are frame packs and stuff suspended magically off the back of the seatpost. I do know in the mountains, with panniers, I am running 20-34 happily. 32-34 is fine unloaded. A lot of these bikes are 1:1 or 32-34 lowest, great for unloaded.
#92
I imagine that geometry and the mounting of racks to take heavy loads is going to be an issue on most gravel bikes, but they are great for rackless bags and long tours. I've been touring on a Carbon Cervelo RS with an endurance type geometry for a few years now and it's only drawback is the tire clearance, but it was great on the gravel of the Erie Canal and I only had two punctures on the entire Northern Tier. I run 34/36 as my lowest gear and find that with a fairly light load I don't need anything lower.
#93
Since this thread is about "Fully Loaded carbon frames"-
My only thought I had while riding some of the unmaintained gravel roads, was- "Gee, a 1200-1500 gram carbon frame would be taking a real beating right now." - but when compared to 30+ year old well used steel frame, who knows what would snap first!
Also- the long wheelbase of the older bike was nice on the descents. So stable, even with an incorrect fork rake, I could do it loaded with no hands. (don't tell anyone though)
Gratuitous pic of the schwinn up on skyline today. I should have taken some pics of the fireroad getting there. I do like the idea of the carbon gravel bike/ lightly loaded carbon gravel bike/ perhaps with frame packs/ etc as mentioned. I need to approach wife carefully regarding this matter :
#95
Sure, in principal on paper it will make a itsy bitsy teeny weeny polka dot bikini difference, but at the speeds we corner, and the downhill series of corners that we exceedingly rarely encounter, the diff in real life is meh.
anything more than that is simply internet "I'm right and you are wrong" territory.
#96
LOL! I was feeling that way today. I took my steel Schwinn up into the mountains to see how it did moderately loaded. In the winter, the heavy bags are quite nice, keeping my speeds low and my face from freezing.
Also here's my gratuitous steel picture from today. It's very trendy as I have a 1x setup...but the rear is a 6 speed free wheel so really it's very retro. My trip was far more urban that yours and there was very little climbing, but it was also pretty cold.
Likes For nun:
#97
Quoted: 671 Post(s)
Liked 49 Times
I haven't had any heel-pannier or toe-front wheel issues with the EXP & as a light rider the light rims work fine. Gravel bikes are often shown with bike-packing gear but those with rack mounts seem capable of toting 50 lbs luggage in panniers. If I toured in India with a carbon bike, airline damage would be my main worry, not ride reliability.
Likes For DropBarFan:
#98
Heel-pannier clearance issues can generally be mitigated with mounting position assuming a suitable bag choice (one that is a shape and size that doesn't make the problem worse than necessary).
Toe overlap issues are something that I always found that I quickly adjusted to on any bike that had them. I'd notice the problem for the first few short rides or maybe for the first few very slow speed turns or stops while turning on the first ride then subconsciously adjust to it and never give it a thought after that. I guess that doesn't work for everyone.
Likes For staehpj1:
Aquakitty
Touring
63
07-30-10 10:37 AM
