Issues with disc brake adapter upside down
The inner edge of the rotor isn't a good way to check for alignment.
Shimano makes two types of rotors (narrow and wide) and two types of pads (narrow and wide), they don't recommend using wide type pads on narrow 2 piece rotors, the pads used in the Spyre/Spyke brakes are exactly the same as Shimano wide type pads, the rotor you're using looks to be a Shimano narrow 2 piece like the RT76 / RT81 / RT86 / RT-EM800.
I've seen a few photos of wide pad use on narrow rotors, the pads were overhanging the inner edge of the rotor and wearing on the arms of the rotor.
What you can see from the outside looking in, mightn't show the full story, after a bit of use I'd remove the pads from the caliper to see if there's any unusual wear on them.
Thank you for your help.
Likes For digger:
Bikes: old ones
Quoted: 26460 Post(s)
Liked 10,418 Times
...are you and your wife still resistant to my suggestion we go to throuples therapy ?
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I think (people correct me if I'm wrong) a rear 160mm adapter has the same geometry as a front 180mm adapter (I know Shimano has separate models for 180mm front and 160mm rear), so (I think) you could get a 180mm rotor and turn your current adapter right side up and it would work.
...on the brighter side, this allows you to buy the Titanium brake rotors that you really wanted all along.
Bikes: old ones
Liked 10,418 Times
...if you build it, they will come: Alpha’s Ceramic Rotor RS – superlight Spanish carbon disc brake rotors
Quoted: 184 Post(s)
Liked 67 Times
If it does, it would be an indication that something isn't right with your setup
It would probably work, SRAM doesn't have front and rear specific adapters, they have a 20mm IS adapter that's for front 180mm and rear 160mm
Does the following image shows how the pads are contacting the rotor?
