Would you ride a triple ring with stripped thread?
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Avocet triple:
Sugino AT triple:
If chasing the threads is enough to allow all the bolts to engage securely, I'd anticipate no problems. Otherwise, a helicoil repair is a likely solution.
Quoted: 1088 Post(s)
Liked 1,205 Times
According to this Park Tool table, I need a tap that's 8mm x 0.75mm. Does that ring true?
https://www.parktool.com/blog/repair...hread-concepts
Old fart
Liked 3,401 Times
OTOH, the aforementioned Avocet triple crank used narrower 6mm x 1mm thread for its inner ring mounting bolts; another strength compromise.
Quoted: 76 Post(s)
Liked 76 Times
also, a proper heli-coil job would replace the trashed aluminum threads with permanent steel threads, making the crank better than new. you wouldn't have to worry about future cross threading or damage to chainring bolts or the existing threads
that said, you could get away with a longer bolt and chasing the remaining threads and if/when that eventually fails the heli-coil solution will still be there as a backup.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
And as long as there is enough "meat" for the slight enlargement of the threaded hole, a simple and reliable fix.
But I still suspect strongly that this crank needs no thread restoration beyond running a longer bolt in and out a few times.
The original bolt does seem to have been aluminum, and the bolt threads do appear to have surrendered to the harder forged alloy of the crankarm.
Likes For dddd:
Quoted: 3241 Post(s)
Liked 2,512 Times
I also just acquired a 110/74 Sugino AT. The info I am reading is for 3 rings, the BB spindle length is 124.5.
Liked 1,205 Times
Just wanted to post a quick update to this thread. I bought a tap (M8 x 0.75) and ran it through the hole. While this “after” pic shows clear thread damage about 3-4 threads down, an undamaged bolt now runs cleanly in and out, and there is plenty of thread engagement to make me confident in its integrity. Thanks for your advice, everyone!
Liked 2,512 Times
Glad it worked out for you.
surreal
Bicycle Mechanics
16
11-15-10 01:14 PM
