Quality seatpost binder bolt source
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Quoted: 415 Post(s)
Liked 954 Times
I tossed the chewed-up one, and ordered one from Framebuilder's supply. It looks like the Problem Solvers ones are sold to bike stores and not on the web, so I'll check when I'm in Santa Fe next. The $39 one looks good, alright, but is too much $ unless nothing else works, thanks.
Quoted: 4477 Post(s)
Liked 1,621 Times
I tossed the chewed-up one, and ordered one from Frameebuilder's supply. It looks like the Problem Solvers ones are sold to bike stores and not on the web, so I'll check when I'm in Santa Fe next. The $39 one looks good, alright, but is too much $ unless nothing else works, thanks.
Likes For Kontact:
Two options if you’re interested…
https://richardsachs.com/product/ric...-survival-kit/
or
https://richardsachs.com/product/rs-...-nut-assembly/
or
Atmo bis
Atmo bis
Quoted: 3560 Post(s)
Liked 2,978 Times
or
or
Likes For e-RICHIE:
Liked 2,978 Times
Buy what you want or need. But remember - just like a head tube (for headsets) and bb shells (for axle assemblies) the seat lug AND the seat tube should be prepped for accepting a seatpost. These are not holes you shove things in willy nilly. Make sure the i.d. of the seat tube isn’t warped or similarly distorted or gouged. Make sure the frame slot is parallel and not mangled from previous installations. Most importantly is the lug dimensions. Not all bolts play well with all seat lugs. It’s imperative that the 8mm hole is counterbored on both sides. That way, the machined surfaces are your correct contact points RATHER THAN the ear exteriors.
My bolts and kits come with an instruction sheet that walks you through the assembly tasks.
Too many people think a seat binder bolt is some aftermarket thingy that comes poly bagged from QBP and should cost less than its cost to ship somewhere. Mine are not designed for that mindset.
Atmo bis
Atmo bis
Likes For e-RICHIE:
Liked 2,978 Times
Sorry, I edited after you posted. The Cinelli Supercorsa seat bolt is unique (proprietary?) and tends to be a bit brittle. Would be nice to have one of higher quality.
Likes For smd4:
aged to perfection
Quoted: 851 Post(s)
Liked 1,278 Times
Jim Merz Portlandjim can make one for you in stainless or titanium.
Jim's bolt is turned, not rolled threads like Richard's pinch bolt, but very very nice. comparison with the original item on the right.
Remember there are several different iterations of these depending on your Cinelli's vintage.
/markp
/markp
Likes For mpetry912:
Liked 2,978 Times
It looks like this:
aged to perfection
Quoted: 851 Post(s)
Liked 1,278 Times
that's a bolt from a late model bike. The one I posted is from a 1970 Cinelli
/markp
/markp
Liked 2,978 Times
