garage sale finds, and help ID old trek
Bikes: '80 Motobecane '86 Eddy Merckx '88 Miyata
I got some old bikes from the original owner, a Peugeot Course a Panasonic Villager III, and an old Trek that his son had debadged, all the bikes are the same as they were new but with rust and grime, even original tires, the only bike that was ridden enough to have any wear on the tires is the trek, I was suprised when I got home that they all had the tires pumped up,
the peugeot is 28lbs with a 59.5cm c-c seat tube and a 60cm c-c TT and 103 tubing and like my motobecane that is very close in size has a long wheelbase of 107cm, it has narrow alloy 27" rims, haven't gotten a chance to ride it yet, but look forward to setting it up and putting on some miles.
the panasonic weighs 35lbs measures 56x56 and since the owner was about my size/a bit taller is set up fine, it has a longish WB of 103cm thanks to a long chainstay, it's got the trick shimano FFS front freewheel system so you can shift w/o pedaling, I rode it a couple miles and it rides pretty well and is comfortable, the wheels are steel and so is the groupset combined with a Hi-Ten frame makes for a heavy bike but hopefully it will prove to be durable as it is now my new beater bike.
the trek as I said is debadged and the kid painted his name with house paint on the TT, the SN0888** means it's an 87 acording to vintage trek and it's a midrange model because of the 501 tubing, the seat post measures 51.5cm c-c and 53cm c-top I don't know how they sized their bikes, the TT is 52cm and the chainstay length is 43cm from the BB center to the rear axle with a 100cm wb if that is any indicator of what model it may be, it's got suntour parts and is pretty good shape, too bad it is too small,
The vintage trek website was a wealth of info for me when I'd found my 460 ('85) at a garage sale in excellent condition. The documentation on these bikes is quite extensive. You should be able to ID that thing right down to the spokes
Olds
Olds
Bikes: 2006 Orbea Volata, 84 Trek 760, 83 Trek 720,
I would say with that s/n it's probably a '83 instead of '87. That year the S/N started at 04**** and ended at 113*** My '86 Trek 520 has a S/N starting at 22****. Nice find.
"Steel is Real"
Vello Kombi, baby
Bikes: 1973 Eisentraut; 1970s Richard Sachs; 1978 Alfio Bonnano; 1967 Peugeot PX10
The Course is a UO10, an upgraded version of the venerable UO8.
"It's always darkest right before it goes completely black"
Waste your money! Buy my comic book!
juneeaa memba!
Bikes: Crap. The box is not big enough...
Ya. '83. That is an early imron color - look at the catalogs at vintage-trek.com.
model size serial range date
720 21 88005 88029 83
720 22 88030 88129 83
720 22 88130 88179 83
760 55 88180 88204 83
760 58 88205 88229 83
850 18 88230 88264 83
850 19 88265 88364 83
850 19 88365 88464 83
850 19 88465 88539 83
850 22 88540 88639 83
850 22 88640 88729 83
850 24 88730 88754 83
850 24 88755 88779 83
520 21 88780 88879 83
640 22 88880 88929 83
520 24 88930 89079 83
so...which model is it?
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
it's an 1983 520, 21inch frame Reynolds 501 tubing.
colour is correct too, even if it has no decals.
Marty
Marty
Sono pił lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
thanks for the info on the bikes, I've been trying to find the info on the peugeot but didn't find much, also you can subtract the weight of the bike lock from that one
havent' been able to find out much about the villager III except for a cache of one on craigslist for $150!!! as villager 3 racing bike, the front freewheel is pretty wacky it would be cool if it wasn't so loud and I can feel the ratcheting through the pedals, but it's got a nice feel with all that road hugging weight,
I don't know why I typed 87 for the trek, the correct year was the only thing I found first time I searched, good to know everyones paying attention.
where was the "model size serial range date" info?
I looked at the 83 catalog and found the info for the equipment lists, my bike has a mixture of the 500 and 520, but no triple, and the geometry only listed the 22.5" and both models had the same dimensions, although it doesn't matter much since I don't know what I'll be doing with it, the old treck decals were either really crappy or the kid knew what he was doing and had a heat gun since you can't tell that there was one. the bike is pretty clean except for grime and oxidation also the brake hoods look like they are melting? must be the rubber.
juneeaa memba!
The serial number lists at vintage-trek.com. I'm intimately familiar with them since my wife and I built the list from the original factory records, for Skip.
Vello Kombi, baby
The UO10 is an upgraded version of the UO8. Introduced in the mid/late seventies, the bike had alloy rims (upgraded from steel) and cotterless Stronglight cranks, usually badged Peugeot (and take a standard 22mm crank remover). A downside is the obnoxiously small seatpost-- the ones I have seen measure 24.4, making replacement not very easy. I've found the ride to be not as nice as earlier UO8s. As an upside, the simplex derailleurs on this model were not made of derlin plastic, and thus not prone to breakage.
There were at least two other models Peugeot labeled as "Course". One of them, the PFN10E, was one of the nicer entry level racers made at the time, with Vitus double butted tubing.
range that yours falls into it links to a very
detailed list of serial number ranges that specify
model, size etc.
Marty
