My contribution to the world of cycling
half man - half sheep
From: Big Mineral arm - Lake Texoma (Pottsboro, Tx)
Earth shattering; ground breaking: spray a little WD-40 in your air pump chuck and it will come off the *#$!%# valve without breaking the needle. I've broken two presta valves trying to work the chuck off in the last two months. I'm sure there's a good reason why I shouldn't be spraying a lubricant down into my inflation unit but I'm not interested in listening to sound reason at this point. Oh, and if you get some on your tread...get it off with a good coating of armorall <snicker><snicker>
I'll go back under my rock now.
34x25 FTW!
Bikes: Kona Jake, Scott CR1, Dahon SpeedPro
I'm thinking of the responses you'd get posting in various sub-forums here:
A&S: WD-40 is not VC, you dumb no0b!
Mechanics: WD-40 is not lube, you dumb no0b!
Road: WD-40 is not OCP, turn up the power meter to 400W next time first, you dumb no0b!
Others?
Seriously... sounds clever to me, but what do I know?
Others?
Overacting because I can
Bikes: Merlin Agilis, Trek 1500
I'd be worried that WD40 might degrade the rubber in the chuck. Does WD40 have any warnings re exposure to rubber, like gaskets, etc.?
“Courage is going from failure to failure without losing enthusiasm." (Churchill)
"I am a courageous cyclist." (SpongeDad)
....gets the cheese
Bikes: Cannondale Synapse, Cannondale Caad 8, Wilier Triestina Jareen
Originally Posted by Doggus
.....I'm sure there's a good reason why I shouldn't be spraying a lubricant down into my inflation unit....
Cheers.
Originally Posted by DocRay
I have no idea what your talking about, if you can't get something as simple as a presta valve to work for you, there may be other issues.
What did people do before WD40?
Have you ever noticed this forum has a lot of cyclists with reading comprehension problems? I have.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Originally Posted by The Fixer
......very smooth, firm insertion & extraction...
Today, I believe my jurisdiction ends here...
Behind EVERYone!!!
Bikes: 2010 Specialized Tricross Comp 105 Double
How about screw on presta/schraeder valva adaptors? I am a klutz and they save me alot of aggravation.
Just a thought.
Cheers,
Brian
Just a thought.
Cheers,
Brian
“A good teacher protects his pupils from his own influence. ”
― Bruce Lee
― Bruce Lee
Bikes: Trek 7000 and a Trek 1200
I think having problems with presta valve is related to what type of floor pump you have, I put a Topeak smart head on my pump and it made all the difference in the world.
Originally Posted by Surferbruce
spit works just as well,and you always have it you. mine doesn't smell as good as wd40 though...
