How to cope with frayed or unraveled cable ends?
Hi all,
This seems simple but it's got me stumped. I pulled everything off my frame and did a detailed cleanup and rebuild - looks gorgeous now. However, in the process I had to remove cable ends and pull the cables out of some housings. Now I need to thread them back through, but one of the tips is a bit frayed and won't allow me to get it started.
I tried solder but it won't flow into the strands at all, not even using a torch to make the tip red hot and using flux. Is there a special solder that does work? I just grabbed the roll I used for sweating copper pipe joints.
Other solutions? Cheap as they are I'd hate to just toss the cable, it's pretty new.
Thanks,
Don
Thanks,
Don
Specialized Allez Pro '06
Specialized Sirrus Elite '05
Bikes: Naked Custom, Marinoni Special, Specialized Team Issue Acqua Sappone, Iglehart Super Gold
The cable might be stainless steel, in which case the solder won't stick. You might want to try a dab of superglue.
I use heat shrink on the cable ends instead of those crimped ends. Minimal damge if any, to the cable.
Cheers
Dave
Cheers
Dave
Quoted: 118 Post(s)
Liked 50 Times
Replacing worn or frayed inner cables is pretty cheap, and you may have to do one or two. When they are new I cut to length and put a drop of super glue on the end. Then I put a 1/2 inch piece of heat shrink tubing on an shrink it. Later, if I need to remove the cable, I can remove the heat shrink, and the glue will keep the cable from fraying.
Try it. bk
Try it. bk
Yet another vegan biker
Bikes: Sakae Prism, Vintage Fuji bike(S), too many bikes, one from scratch bike.
Regular cables are dirt cheap. If yours is unraveling I'd forego trying to rescue it and slide in a new cable.
Yours must be stainless because solder usually works well. Any solder will generally work. I use silver solder because I like how it looks and , well, I'm a silversmith.
New Orleans
Quoted: 157 Post(s)
If worse comes to worse-you can use the long rear cables for the front brake and derailleur.This way you only have to replace 2 cables-not all four(guess you already know this).
I usually leave my cables a bit long-with maybe 2-3" extra-so I can cut and trim the ends a couple of times if I have to pull them.Luck,Charlie
Thanks all for the quick replies. I guess I'll just have to finish the rebuild after I can make a trip to the shop for a new cable. But now I'm armed with good advice and will saturate the clean cut tip with superglue this time. Great idea!
Regards,
Don
Regards,
Don
That nipple idea seems worthy, too. And I definitely second the cutting-them-long theory of cable snipping.
Originally Posted by zip22
followup question: the end of the cable when it was uncut was soldered, (same situation as above - solder wont stick). is there a special type of solder that does work with stainless cables?
Guest
Posts: n/a
Quoted: Post(s)
F1junkie suggests, "dab of superglue". I use a variation on that theme, JB Weld. It cures to a color quite compatible with the cable. Caveat. . .just make sure it doesn't touch anything whilst it cures.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
Originally Posted by phantomcow2
I use aluminum nipples as a cable crimp
I find it's best to trim new cable to length and solder before ever inserting it through the housing. Once it picks up any grease or oil of any kind, it's impossible to get solder to stick. Although I did manage to clean the used ends once really well with acetone in an ultrasonic cleaner. Then dipped in battery-acid to etch for a minute or two. Then the solder stuck, but it was a lot of work to get a clean cable-end...
BTW - the plumbing-solder has way too much lead to stick well. You'd want an electronics-grade solder made primarily with tin & silver.
Bikes: Litespeed Firenze / GT Avalanche
The best way to cope with frayed cable ends is to seek professional counsiling for the emotional distress that it causes. After this you should, in true American fashion, be able to place the blame squarely on someone else. After hiring a good lawyer you should sue the bike company, cable manufacturer, bike shop, cutting tool mfgr, cable nipple mfgr, CEOs / owners of all the above, and your Mother. Write a book, and then go on Oprah.
It's the only way to cope.........................
I really bored at work today. Can you tell?
Lost in the Black Hills
Cheers
Dave
Cheers
Dave
Tomac Mountain Bikes | Light-Bikes l Magura USA | Industry Nine | Schwalbe Tires | Caffélatex
if its that bad, i'de probably replace the cables.
Unique Vintage Steel
Really like your peaches
Quoted: 303 Post(s)
Liked 136 Times
Electronics solder is either 60/40 or 63/37 tin-lead and rosin core, it does not need silver and silver actually raises the MP a bit. Silver solder is nice but requires a lot more heat and special fluxes for best results. Lead based solder will probably get very scarce in a few years with all the emphasis on getting rid of lead and requirements that all electronics gear sold to real people have no lead in it in the next 2-3yrs. Satellite people are alarmed because tin based lead free solder grows whiskers over a few yrs and some satellite failures have been attributed to this. Like tharold soldering before cutting was very nice when cables were galvanized. Most cables I use won't solder with electronics solder.
Steve
Steve
Thanks again all, the LBS gave me a new cable and about 10 caps (whatever fell out of the bottle when he shook it) for $5.00 today. I'm trying the JBWeld idea on the ends - only problem with it so far is that it's slow to setup. Superglue may be better in that regard but I wondered about long term durability. Heck, should have done one of each as an experiment. Oh well, next time.
All this for my old bike that I'm probably just going to sell once my heart hardens enough. For now it's getting TLC while I ride the new one.
-Don
Bikes: doesnt matter. just ride.
you need to replace cables when they begin to fray. a frayed cable loses much of its power when it begins to unravel. for better performance, replace em. theyre like two bucks
Bikes: 2007 Jamis Aurora
So, what do y'all use to cut the cable to length so it doesn't fray?
The most effective method I've found is hitting a wire cutter with a hammer: Hold the cutter's jaws on a strong surface - a bench vise or similar indestructible surface - and place the wire at the back of the wire cutter's jaw. Then strike hard with a hammer. It cuts very cleanly and no need to wiggle the cable back and forth to break that last strand, which usually leads to some other strands unraveling...
