Cygolite POS/Bad Customer Service
Old 03-28-06 | 05:14 PM
Daily Commute's Avatar
Ride the Road
20 Anniversary
Bikes: Surly Cross-Check; hard tail MTB
My Cygolite HID died after les than 18 months of use. I know the battery is charged. When I turn the light on, it fizzles for about a second, then goes out. I called Cygolite. The rep said it would cost $50 to fix. I thought that sounded fair.
Oops. The rep said he had mistook my voice for a dealer. The price went up to $100. Then he said it could be $200 if it also needed the ballast replaced.
I would never pay $200 for a used HID. I'm wondering if I should even pay $100 for a used HID. I'll have to think about that.
Other than do-it-yourself, does anyone have information on what's the most cost-effective (or least cost-ineffective) HID out there? What about do-it-yourself HID lamps that will attach to my perfectly fine 12 volt 4.5AH NiMH Cygolite battery?
This is sad. I really loved the light.
Daily Commute is offline
Reply
Old 03-28-06 | 06:15 PM
caloso's Avatar
20 Anniversary
You might just have a bad switch in the light body and there's no way that should cost more than a couple of bucks.
caloso is offline
Reply
Old 03-28-06 | 07:37 PM
Ride the Road
20 Anniversary
It looks like my only option is to send it to Cygolite and ask for a quote.
Reply
Old 03-28-06 | 07:38 PM
robtown's Avatar
Muscle bike design spec
Bikes: 70 Atala Record Proffesional, 00 Lemond, 08 Kestrel Evoke, 96 Colnago Master Olympic, 01 Colnago Ovalmaster, 76 Raleigh Gran Sport, 03 Fuji World, 86 Paramount, 90 Miyata CF, 09 Ritchey Breakaway CX, Bianchi Trofeo, 12 OutRiderUSA HyperLite
Originally Posted by Daily Commute
Other than do-it-yourself, does anyone have information on what's the most cost-effective (or least cost-ineffective) HID out there? What about do-it-yourself HID lamps that will attach to my perfectly fine 12 volt 4.5AH NiMH Cygolite battery?.
Batteryspace.com has a HID housing and bulb unit for about $110 https://www.batteryspace.com/index.as...OD&ProdID=1393
I cannot speak for the quality.
robtown is offline
Reply
Old 03-29-06 | 03:53 AM
Ride the Road
20 Anniversary
Thanks. My plan is to send it back to Cygolite. If they can fix it for $100 or less, fine. If not, I'll keep an eye on HID prices over the summer. The Batteryspace.com lights look like a good value. You can get a much better light for the same price as the name brand lights, and it looks like replacement parts are cheaper, too.
This wasn't the first time I was disappointed with Cygolite service. A small rubber gasket ripped a few months ago (the one on the light through which the cord from the battery plugs into the light). I called them, they said they's mail me another one. That sounded good. two weeks later, I called back. They had no record of my previous call. I received the gasket about a week later.
Reply
Old 03-29-06 | 07:30 AM
ItsJustMe's Avatar
Seņior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
I can. They are fine. I used mine all winter, every day, in conditions down to -5*F and had no problems. It doesn't flicker noticeably even on washboarded gravel, and has never gone out on me. It's a touch heavy since it's chromed brass, intended for ORV use, but when I say "heavy" I mean it weighs perhaps an ounce more than a plastic enclosure would (but it's probably that much tougher - I think it would probably be OK if it got run over by a car).
It's pretty sad that you can buy the housing, light, and ballast unit for $110 from TrailTech/BatterySpace, but Cygolite charges users $200 to replace just the bulb and ballast. Especially since, as far as I can tell, the bulbs are all made by the same manufacturer, and the ballasts are all very similar if not identical.
ItsJustMe is offline
Reply
Old 03-29-06 | 07:32 AM
ItsJustMe's Avatar
Seņior Member
BTW, here are some pictures of my Trail-Tech HID and the rest of my setup (including BatterySpace 4.5 AH 14.4v NiMH battery)
https://www.hauntedfrog.com/gallery2/...g2_itemId=2701
NOTE: the rather complex bit, the voltage regulator, is only necessary because my battery is 14.4v, which is over spec for the HID. If used with a 12V pack, no regulator would be necessary since such a pack will put out a max of about 13.8V and the HID is rated to 14.8v. My 14.4v puts out nearly 16V for over an hour when freshly charged, so the regulator is necessary.
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
