Weird Headset lockring w/ 3 notches
= cyclist's tan
Bikes: '82 Miyata 310, '87 Scott Boulder, '87 Schwinn Le Tour, '91 Cannondale SM500, '96 Schwinn Clear Creek, '99 Schwinn MesaGS, '05 Rockhopper
I never overhauled my headset because it's never given me any problems, but due to this bike's age I thought I would. Usually you remove the locking top nut, then pull off the keyed washer and unscrew the top cup. Well here is a picture of my '82 Miyata 310 and i'm guessing the headset is Suntour or Shimano -- no visible markings yet revealed.
It has three evenly spaced notches and does not appear to be keyed. When I go to slide it off, it does not budge in any direction. I even gently clamped it with leather jawed channel locks and wiggled it without results.
Any ideas? This design is also missing the wrench flats for the adjusting cup. It has a knurled ring on the cup like some threadless headsets. It also has pointed locking teeth you can see in the first photo, maybe to replace the keyed washer? Has anybody run into this design before?
Extra Medium Member
Bikes: Fezzari Empire; State 6061 Allroad gravel; Scott Spark; Specialized Status 140
This is just an older style headset, that I THINK was made by Tange. That lockring with the three notches is exactly that, a lockring. It's threaded on to the steerer tube, not slid on like a "normal" spacer. The proper tool would most likely be extremely difficult to track down, but you should be able to use a lockring wrench that is made for a BB lockring. Also, be aware that your headset may very well have loose ball bearings rather than ones contained in a cage, thus they will fall out all over the floor when you remove the cups. Be prepared to catch them!!
= cyclist's tan
I've tried my Park HCW-13 BB wrench and its so huge that the tooth disengages before the rounded edge of the tool can even contact the locking. Fudge.
Oh and I always end up bending the bearing retainers somehow when popping out the old bearings and putting in new ones, so I usually use loose bb's anyway.
= cyclist's tan
my BB pin spanner doesn't work either...
Extra Medium Member
well....shoot. I guess you could do a couple of things here. One is buy an new headset and then use a pair of pliers to get the lockring off. If you ruin the headset, at least you'd have a new one to put in. And if the pliers work, just return the headset...although I hate returning stuff..lol. But really, that entire headset is steel, so wrenching on it a bit should'nt hurt too much. Another little trick is to take a large flat screwdriver and gentley tap one of the notches until it is loose enough to turn by hand. I've certainly used this method on a few old BB's with no ill results.
= cyclist's tan
Bike Tools etc has this "Small Hook Spanner." It looks promising. I'll ask the staff.
this looks good too:
https://www.biketoolsetc.com/index.cg...tem_id=HZ-C205
It looks like a copy of a Stronlight P-3. I wouldn't surprise me if it was a Tange. They made copys of High end european headsets. I have one that looks almost exactly like a Stronglight Competition.
Is that a setscrew I'm seeing to the left of the notch in the top picture? If so, you definitely need to loosen it. The ring with the teeth is not threaded and needs to come straight up. Sometimes you can loosen things up by tightening the "adjusting cup" slightly. (I think it's technically a cone.)
Don't reuse retainers. Always use loose balls, especially in used headsets. It changes the spacing of the balls and delays the onset of indexing.
Good luck!
Good luck!
Incredible, just incredible.
I'm marvelling that someone that can have a stable of bikes and claim to love wrenching yet is stymied by a common, conventionally threaded headset design. Then I see that you're twenty one y/o and it falls into place.
Death fork? Naaaah!!
Bikes: Seriously downsizing.
A hammer and a small punch set in one of the notches should tap it loose enough to unscrew.
If you're a barbarian a big pair of channel locks will work, too.
Top
Top
I agree there appears to be a set screw in the notched ring that must be loosened before the ring can be unthreaded. The punch and mallet technique works well for removing notched lockrings if the right spanner isn't available.
JRA...
Bikes: trek 520 & 736, DeRosa Professional, Fuji Professional, Raleigh International 3-speed, Saronni (any info people?), Humber 3-speed, Raleigh Sports, Carlton Grand Prix coming soon!
i've never seen one of these with a set screw.
Originally Posted by HillRider
The headset in question isn't "conventionally threaded". I've worked on a lot of conventional threaded headsets over the past 20+ years and never came across one with a separate lock ring below the top nut so this design is a bit unusual.
Top
There is no set screw. This is not some exotic bit of obscure enginneering. It is a very common and straight forward style of headset. For those youngsters encountering it for the first time just a bare minimum of mechanical aptitude is required to figure it out. The tool needed for a non-cob-job is a basic small hook wrench that belongs in the toolbox of anyone who considers themselves a semi-competent bicycle mechanic.
Spelling Snob
Bikes: Panasonic DX4000, Bianchi Pista
I recently removed a lockring like that. I used my standard lockring wrench, and the biggest flathead screwdriver I could find. The wrench is too big of course- the tooth comes out of the notch before
you can get any leverage on it. What I did was put the side-edge of the screwdriver in one of the other
notches to give the wrench something to push against while the tooth still stayed in.
I know its kind of a rigged way to do it, but it worked for me.
The first rule of flats is You don't talk about flats!
ride, paint, ride
Bikes: Cannondale R300 Caad2
Originally Posted by Moose
Nope, it is definitely threaded.
As to the toothed ring, I have a Tange headset on an late-'80's Trek that has the same toothed ring that engages matching teeth in the top race of the headset just like that shown in the picture above. The ring is not threaded but has an internal tab that goes into the vertical keyway in the fork steerer. The tab keeps it from rotating but it is removed by pulling it straight up.
That's how the older Stronglights work. They have a flat instead of a keyway on French bikes, of course. I like them because the teeth lock in your adjustment. They can't be adjusted as finely as a standard headset, though.
= cyclist's tan
So you looked at my profile to see how old I am? I see you have no personal info posted because you must protect yourself from such attacks. Good job making yourself feel superior to someone who is not afraid to ask questions. Last time I checked thats what Bikeforums was for. You're a big, big man.
As far as I'm concerned you are a 12 year old that talks out of his arse.
So anyway, there is no setscrew. That is an optical illusion.
I'm still waiting on a reply from Bike Tools, then I believe I wil buy the Park spanner.
Bikes: Peugeot Hybrid, Minelli Hybrid
The pointed teeth on the buttom of the spacer allow you to index the headset when you adjust it. The spacer is keyed into the slot at the back of the fork. The hook spanner as shown by rat factory is what you need. If you have a hook spanner that is too big you can insert a spacer like a flat screwdriver blade about half way round the C to get a better purchase on the slot.
Originally Posted by lawkd
No, Dirtdrop is talking about the ring with *teeth* which is just below the notched ring. The ring with 3 notches IS threaded, with no setscrew, and the ring below that has those accordion-shaped teeth which engage the top of the bearing cup race--and THAT ring is NOT threaded, so it lifts straight up, and then the cup race spins off. I have this exact headset on a 1982 Univega Sportour.
