Older Specialized Sequoia -- Interpret age from serial number?
Bikes: 2008 Specialized Roubaix Elite Compact, 2004 Giant Cypress, 1981 Specialized Sequoia
I bought an older Specialized Sequoia today off a Craigslist ad and I'd really like to know how old it is. I bought it as a backup for my main ride, but also to work on and learn from doing that.
Any experts out there at interpreting Specialized serial numbers?
The number on the bottom of the BB tube is M2F00144.
The bike has bar-end shifters and a triple crankset. It's got all the braze-ons for adding touring equipment. The frame is blue and it includes a signature label that says it was designed by Jim somebody, I can't really make out the last name.
Instead of using the serial I'd use the components. Are they Shimano? If they are they will have a two alpha character date stamp somewhere on them. Other components have similar date codes as well. Can look them up here:
https://www.vintage-trek.com/component_dates.htm
That is the serial number used by Merida, though others mey also have used it. We have to assume the decade, but it should be a 1982 frame. A Sequoia from that era should be Suntour/Sugino equipped, typically with Cyclone II derailleurs. Checking the date codes on the components is still a good exercise as a sanity check, but sometimes the dates do not match up exactly with the frame. Often they are up to a year older and sometimes they can be newer. It all depends on how good they were at rotating their stock and whether they were getting shipments on time.
The name on the chainstay may be Jim Merz, who was a designer at SBI during the 1980s. Congratulations on your acquisistion. The Sequoia was a very fine grand touring model during that era.
You guys have been a great help.
I've checked out the components and T-Mar, you were correct on the derailleurs, they say "Suntour Cyclone II" and the rear says "Maeda Inc. Japan XJ." So in checking the vintage Trek link that dwoloz provided, for Suntour it looks like the XJ code translates to October, 1981. That makes T-Mar's info on the frame being 1982 spot-on, I'd say.
As for the other components, I'm not finding anything that looks like date codes:
The bar-end shifters say "Bar Con Accushift"
Brake handles: "Aero Compe" in script
Brakes, which are side-pull: Shimano SL or SLR, can't quite tell which
Front and rear hubs: "Suntour Japan Cyclone Sealed Bearing"
In the "designed by" script on the chain stay I mentioned above, on closer inspection (and with some cleaning) it looks like the signature is Tim Neenan. Googling that name indicates Tim Neenan was a California framebuilder who was credited as the guy who built and designed some of Specialized's most recognized frames, including the Allez and Stumpjumper. He apparently later went on to a company called Lighthouse.
There are labels on the seat tube and fork that say "Special series touring Cr-Mo double butted tubing," so this confirms it's a steel frame, correct?
The rims, I think, are not original, as they look too new. They are labeled "Wolber Super Champion Modele 58 27 inch"
As for the frame size, I haven't found any evidence, but it fits me like it's a 56cm. I'll have to take some measurements on the seat tube, I guess, to confirm. Or should that be the top tube?
The SLR brakes did not come out until 1987, so they are obviously an upgrade. A worthwhile upgrade as the SLR are so much smoother, with better modulation. Without doublechecking, I beleive the original were SunTour Superbe and the rims were Mavic.
Yes, definitely CrMo. SBI were supposedly having the tubes custom drawn for them so a stock OEM decal was not appropriate. beleive thay were using tange at this time.
Ah yes, Tim Neenan. They really should have had the foresight to consider the possibility of us getting Tim & Jim confused when the decals got tattered
So T-Mar, how did you translate that serial number to 1982? Makes sense that it's a Merita frame, as I understand now through some web searching that Merita makes frames for Specialized. But what's the code that says 1982?
Anyone know when Specialized first started making the Sequoia model?
Hi there,
I bought my sequoia in the summer of 1982 and still ride it every day. From your description it pretty much matches mine however I've never noticed a serial number anywhere on or near the bottom bracket. Can you be more specific as to where it's stamped? I recall they brought the model out earlier that year. Dark blue with with Sugino triple crankset and 27in wheels. The Tange labels are long gone but i remember that they had a rainbow color scheme; plus the words "special series touring.." rings a bell.
Hope that helps. Happy riding
Hi there,
Danny
Hi there,
I'll try to post some pics this weekend.
Hi,
I finally took a photo, and I'm guessing this is a later model. Purchased in summer of 82, which must've been after a relaunch as a sport tourer. No serial numbers as far as I can see - only "60" stamped on the BB which I assume is the frame size.
Best regards from summery London,
stringbreaker
Bikes: specialized crossroads hybrid 2006 Raleigh Cadent 2 1971 Schwinn Varsity, 1972 Schwinn Continental, 1977 Schwinn Volare (frame)
Nope mind did the same thing. I think it something to do with the size of the phot
(Life is too short to play crappy guitars) 2006 Raleigh Cadent 3.0, 1977 Schwinn Volare, 2010 Windsor tourist. ( I didn't fall , I attacked the floor)
Hi,
WoodBadge NE-VI-1
Bikes: 1983 Sequoia by Specialized; 1989 Panasonic
WoodBadge NE-VI-1
Looks Like Mine!
The first of three pics looks like mine, 'cept mine is 68.5cm c-c and same color.
Got mine as a frameset plus seat post. Populated a little differently.
My BB looks like this:
Car free since 2018
Bikes: Mostly japanese ones
Sequoias are popular bikes around here, especially the earlier ones. Try posting a picture. If you are using a pc, you might be able to post it using the little picture icon (to the left of the smiley face) in the menu (under the text "Message:") OR the "Manage Attachments" button near the bottom when composing your reply. If you try this, note you have to hit the "upload" button at the upper right of the upload files dialog to complete uploading the picture. I believe this will work even if you don't have 10 posts, but I am not 100% certain. And I don't know if it will work on mobile devices.
Also, there is a seperate appraisals forum here https://www.bikeforums.net/classic-v...th-appraisals/
They will tell you what they think it's worth, which will likely involve, well, pictures, and some information like where are you located.
Good luck
Good luck
Oregoner
Classic & Vintage
12
07-04-18 07:30 PM
wascobi
3
02-13-15 02:40 AM
