Flat Bar Shifters
Bikes: Specialized, Schwinn
Flat Bar Shifters
Has anyone ever used Campy flat bar shifters? I'd like to convert a drop bar bike to flat bar. Rather than replace group with a new one I'm thinking about the Campy flat bar shifters. Problem is nobody stocks them. Even my LBS said they're virtually impossilbe to get, he tried. I was thinking about using Shimano with a Shiftmate. Problem is Shimano uses an indexed ft shifter. Campy's actuation ratio on their front derailleurs isn't compatible with Shimano and JTEK doesn't make a front shiftmate. I could change front derailleurs but then where does is end?
Can't remember the company,but someone out there makes high end thumbies. You could always just get a set of them and use them in friction mode.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Brompton S6L/S2E-X/M6L-X/S12 T Line
I Love My Dream
I'm using barcons now so, moustache bars work nicely. I was trying to keep it with a set of riser or flat bars. It's more of an experiment than anything else. Though the Paul thumbies, mentioned above, would work also.
Bikes: ICE Adventure 26FS, Surly Long Haul Trucker, Giant Cypress DX
In March I replaced the drop bar on a Surly LHT with a flat bar, installed MTB brake levers, and moved the barcon shifters to Paul thumbies. The Paul thumbies+barcons are a great setup.
Bikes: Xstream, Terratrike Rambler, Framed fatbike
I converted my Specialized Sequoia to flat bar. I run Duraace barend shifters mounted in my barends. I just love friction shifting. No muss no fuss and easy to adjust.
