"Dear Carleton"
Bikes: Ross Professional Gran Tour (SS Conversion)
What size bowling ball do you prefer?
What color is your refrigerator?
On a scale of 1-10, how uncomfortable would you be if a male nurse gave you a sponge bath?
Not creepin' or anything...>_>
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
These are seven 45lbs plates plus a 25lb plate on each side:
3 sets of 10 during my strength building phase.
Max cadence is like over 220 on the rollers. 160 (depending on gearing) on the track.
But, I'm heavy though. So, it's the whole power/weight ratio that has to be considered, too.
Elitist
Liked 92 Times
- 11
- I've been to Masters Nationals twice (hung out with TT there) and Elite Nationals once (I sucked balls there). I went more for the experience than expecting to do well. I have to work out the kinks of "getting up" for big events. The only way to do that is to go to as many big events as possible and get used to being there. Hopefully one day I'll relax and be awesome. I'm still (hopefully) getting faster. But, we'll see if I actually get faster. I'm OK at Team Sprint.
Fresh Garbage
Will I ever be as good as Indurian or Taylor Phinney? Maybe if I lose 40 lbs and get back to the weights? PLZZZZZ TEL ME
GONE~
Elitist
Liked 92 Times
Yes. But you'll need a time machine...and making that would be the easy part. Picking your parents and getting them to hookup to get the right gene combination and the training would be the harder parts.
モㄥ工匕モ 爪モ爪乃モ尺
Bikes: Custom frame
Dear carleton, Can you tell me who some Time trial bikes are sold with 650c rims, But still are a tall frame?
My name is Alex
Bikes: Mercier Kilo TT Stripper in RAW, Schwinn Madison 2008 Blue, Leader 725tr, Brassknuckle, Leader 722, Traitor Ruben
Dear Carleton,
Is your cousin ever going back to Philly?
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
Not really. Assuming that the leg press machine is on a 45 degree slope, Carleton is pressing about 480 lbs. Even assuming the machine is on a steeper slope, the weight being pressed is less than 600 lbs, which is not that extraordinary for the leg press. When I do 3 x 10 leg presses, I use 420 lbs, and I'm about 100 lbs lighter than Carleton. I'm not saying there is anything substandard about Carleton's workout, just that moving a lot of weight with the strongest muscles in your body looks impressive, but is not the reason why a track sprinter is successful in competition.
Elitist
Liked 92 Times
The press is 45 degrees. Multiply the weight by 0.71 to get the amount you are lifting if it were a vertical press or squat.
Your cog is slipping.
