Better Brake Lever Idea for Trekking Bars
Prairie Path Commuter
Bikes: Marin Palisades Trail
This (scroll down to trekking bar picture) from the Harris Cyclery site may be of interest to those who run or are setting up trekking bars. It looks like they are using road brake levers instead of MTB brake levers. I see two potentially big advantages to this:
1.) It put the brake levers closer to where your hands are most of the time, especially if they were mounted outboard a couple of inches further.
2.) It looks like the hoods provide another position in the all important neutral hand position, the position your wrists are in when you shake hands with someone that puts the least amount of strain on the joint.
Just wondering if anyone has tried this set up.
I was going to post about lever positioning on trekking bars as I am thinking of swapping my drops for them and thought the sides or front may be better but I can't really see any advantage to using drop levers tbh. Perhaps if you were putting trekking bars on a proper road bike with caliper brakes and had no choice but I think most people with trekking bars have v-brakes (one of the reasons I want to change is to get away from drop levers and cantis). I know you can get drop levers for v brakes but why bother on a trekking bar?
btw re the 'neutral' hand position. Loosely hold a pen in your fist and let your hand and arm hang naturally.Then lift it in front of you. The pen will be at about 30-40 degrees not 90 as in shaking hands.
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 118 Post(s)
Liked 209 Times
All those photos look to me like using the brakes would be rather uncomfortable. How does one activate the lever without a major stretch of the hand?
To me... the best bar not called a "trekking bar" is the Nitto Albatross. Use it with TT reverse brake levers in the ends, and some thumbshifters mounted just inside the top curve. I wrap them with a roll of road bar tape on each side. You get over 12" of free bar space for the hands. I used to have all sorts of wrist pains, now zero.
Use a longer than normal stem.
That isn't quite reinventing the wheel but it is close They look very similar to the handlebars on my mum's old raleigh 3 speed she had as a girl in the 50's. Interesting to see some of the old original shapes coming back.
Got an old Peugeot
Bikes: I had a Trek 1200
I have installed a trekking bar on my wife bike to get the bar closer.
Now I played with the breaks leaver, and found that the best place is on the top corners.
The problem is that the leavers don't work properly in every place on the bar, because when you squeeze them, they will touch the bar.
I'm not happy with this settings, and I'm going to add a cross top inline levers that I will chain to the drop bar levers.
Cheers,
Kfir
Quoted: 147 Post(s)
Liked 8 Times
Tektro reverse brake levers fit my Peugeot porteur bike quite nicely and complement the Tektro brake set. They mounted with no problems at the ends of the Nitto Albatross handlebars.
Bikes: Surly LHT
Hi,
Cheers,
Kfir
Cheers,
Kfir
My actual question was "has anyone put inline levers on a trekking bar"? The inline levers I've found spec's for all seem to have a clamp for a road handlebar diameter, rather than the thinner flat/trekking bar diameter. I'd like to have the brake levers up on the front of the trekking handlebar, like the ones at https://sheldonbrown.com/deakins/handlebars.html, but would also like some brakes back on the straight bits of the bars, where most people seem to have the brakes and gear levers.
Broke myself a bit last year, and if I'd had hands on brake levers (rather than on the bar end shifters) I might have come out a bit better, so... I'd like brake levers easily accessible. I commute, "sportily", on this bike.
I don't know how the cable routing would work, but I expect that something could be worked out.
I've searched with google and got nothing so if anyone has suggestions about using inline levers on a trekking bar... Ta!
Cheers, A.
No weenie bikes here!
Bikes: Rans Velocity Squared
I have a set of trekking bars, and could only get the mtb brake levers to fit on the part of the bars that would be closest to you (in the Sheldon Brown pictures). So, this led me to think of using a set of road brake levers which are compatible with V-brakes (Cane Creek, Tektro, and Dia Compe all have some). As mentioned above, the difference in diameter poses a problem.
Wouldn't a shim of some sort work? I know that MTB levers and shifter clamps won't work on road bars, but I don't know why road brakes or shifters wouldn't work on the smaller MTB compatible bars. Isn't it only 1/16" (7/8 vs. 15/16)?? I've seen pictures of aero bars clamped to MTB flat bars, so I'm sure they used a shim of some sort.
That being said, I would attempt to mount them on the outside portion of the bars. That is where I would be holding the bars most of the time. Thus, making the brakes more readily available.
As far as using an inline brake . . . one question: are any of them compatible with V-brakes?? I'm not aware of any, but that doesn't mean that there are none available.
Bikes: Surly LHT
Thanks for your input! Cheers, A.
Bikes: S&S coupled Mercian King, 1970 Gitane Tandem, Yuba Mundo, Surly LHT based 3-speed citybike
I experimented with a four-lever setup on my trekking bars: mountain bike levers on the closer, flat portion of the bar, and old style (non aero) road levers on the front, curved section. The non-aero levers can be set up as inline levers, since cable housing is about the same diameter as the cable end for road brakes, and these older levers point the end of the cable out behind the levers, instead of straight ahead, through the levers.
This made the cable run from the mountain lever, to the top (inboard, in this orientation) of the road lever, then from the bottom (outboard) of the road lever down to the brake.
The setup worked fine, but I didn't like the ergonomics, because both of those positions were too much like a flat bar, which tend to hurt my wrists. The position given by the hoods was too narrow for me. I've since switched to Albatross bars, with the same mountain levers. I considered using inverse (TT) levers, but heard that the ring and pinky fingers, while lacking the dexterity of your other fingers, have the strongest grip, and so should be given the most leverage for maximum braking force.
EDIT: the clamps on road levers are much less finicky about bar diameter than most mountain levers, so I didn't have a problem clamping them to the 22.2mm bar. Most inline levers, however, won't get that small without a shim.
I started commuting on a mountain bike, and added the trekking bars to get a more stretched out feel. This meant that I needed the levers out at the front. I was able to get a regular set of alivio trigger shifters/brake levers around the corners by using lots of grease and some effort. Some paint came off the bars (it was apparent in the grease), but the bars were not scratched - it didn't rub through the paint in any places. Just remember when you start to put them on backward, so they are oriented correctly when you get to the front. Also, you can cut the ends off of mtb grips and slide them to the front for a nice cushioned grip. I tried mounting them where I could reach them on the sides (neutral hand position), but I didn't like it much.
I think where you mount the levers depends on where you spend most of the time. I was trying to stretch out for some commuting speed, and so it was more important to have the levers where you can reach them at speed. I used the closer portions of the bars much like the top bars of a road bike, when going slow uphill or for whatever reason, and you have plenty of time to get to the brakes.
Sorry no pics anymore.
Touring - loving it!!!
Bikes: Thorn Raven Nomad, Mongoose Crossway 250, Ricardo, Revlin, Avanti
Some links for cross/interrupter levers that might be useful:
Sheldon Brown
Paul Cross Lever (V-brake or Road)
Tektro V-brake levers - Rivendell
Interrupter levers (Road) - Rivendell
Salsa Cross Lever (Road)
Sheldon Brown
I use mountain bike levers mounted on the forward portion of the trekking bars. I also mount my bar end shifters there with a set of Paul's Thumbies. I'm very happy with the setup. Reaching slightly forward to access the brakes is very natural and easy to modulate.
Ceci n'est pas un vélo.
Bikes: Trek 7.2 FX, Canondale Six Carbon 3
Ok out of curiosity, do you actually use the Aerobars? Do you use them for extra hand positions or do you actually get into the aero postion? How do you do that with the handle bar bag?
I purposely didn't mount the forearm rests for the aero bars. The flat portion Ergon grips are in the exact position I need to support my forearms when I'm on the aero bars. The bag is triangular and my arms run right along the sides. It doesn't get in the way at all.
Even though I don't use the aero bars much for a hand position, I'm keeping them anyway. It's a killer place to mount my bike computer and my map holder (velcro straps).
Bikes: Surly LHT
Aggri1,
Regarding the questions you wrote in response to my post above: Yes, I was afraid that I would not be able to get my current set of brifters around that first bend. There was another member, in another thread, who had gotten a couple of bar ends up to those top corners in order to attach mirrors to them, so I tried it. I had a dickens of a time getting those around the bends. Getting my brake/lever set was going to be even more trouble, I'm sure. So, yes, I figured that using road levers around the bends would be easier. I never tried it, but that was where I was going if I continued with those bars.
If you took a look at the article on the Harris Cyclery site with deals with setting up touring bars, you'll see that they have some road levers on the top portion of the trekking bars. So, from this, I was assuming that there is a way to attach road levers to a 22.2 bar.
xyzzy834,
How did you attach those aero bars to the trekking bars???? Curious minds want to know.
AND, how did you get those MTB brake levers around the bends????
Last edited by Bob_in_Midland; 09-16-09 at 08:50 PM. Reason: added second question
The brake lever clamps are just aluminum. I put a very large screwdriver in the gap (with the bolt removed) and spread them to be much larger. After I snaked them around the bends, I used a large set of pliers with padded teeth to squeeze them back together enough to get the bolt started.
Quoted: 44 Post(s)
Hi,
Cheers,
Kfir
Cheers,
Kfir
Quoted: 44 Post(s)
I think this is exactly what I want to do, that is if I understand it right? This is a really old post so I am not sure if you (Josef Taylor) are still around or not but maybe someone else can help me out if he is gone?
I believe what he is saying is that he took an old set of cantilever brake levers and turned them into inline levers with a cable that continued on to older road bike levers at the front of the butterfly bars. The thing is I can't quite picture or figure out how to transform the old canti levers into an inline lever. Anyone out there a lot sharper then me that can somehow explain this to me?
My better brake levers on my trekking bike and its bars are Magura's HS 33 hydraulic rim brakes..
the brake caliper fits on V/Cantilever brazed on posts..
[FWIW, closed hydraulic system means that .. a bleed screw can have a supply hose attached to it, so you could use 2 levers on one brake just like the brake has 2 pistons squeezing the brake pads to the rim at the far end.]
In the past there was the Scott Super Brake, they used a reversed cable with the housing and the cable end ball reversed, into the top.
so using the same scheme as top mount brakes with the lever spreading the housing sections would function fine..
