[Brompton] Alternative derailleur shifters
Bikes: Brompton, Time, Bianchi, Jan Janssen, Peugeot
Quoted: 598 Post(s)
Liked 5 Times
Um - Brompton is only a bike . No reason to get so worked up about it.
On another topic, I have the components to upgrade my Brompton. Watch this subforum!
I would recommend not coming into a thread with your ALL CAPS and telling people ALL YOUR BIG KNOWLEDGE and if only they would listen they would KNOW ALL THE THINGS.
I am sorry if the modern world is too complex for you. You seem not to be able to draw correct conclusions from a shortened statement and are not willing to read a longer one as well as there are "too many numbers in it". Not able to learn, not able to change your mind if you are in error, just insisting on whatever madness your initial judgement has been like a broken record. A pattern not only in this thread but in many others as well. I can't imagine you have many friends if you behave in real life in the same way you do here...
![Wink](https://www.bikeforums.net/images/smilies/wink.gif)
At least nice of you that you deleted your statement of me being a "thug" from your last post. Maybe there's hope.
Yes, I was trying to be nice to the others on this thread by deleting "thug". You're still a thug, and it's still stupid to tell people it'll work to crowd the old M bars with the new shifters. The old setup works, but mixing old and new won't. Even with my small hands I wouldn't be comfortable with less room in the grip area and that's what I explained. But you decided to join this thread with your ALL CAPS BIG KNOWLEDGE of how you know everything about Bromptons and only you should be listened to.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1111 Post(s)
Liked 2,242 Times
Let’s watch the insults please and respect others opinions. Thanks
Stan
Stan
This time I had a hard time doing so and it clearly went over the top dealing with Joe Remi's attitude. Sorry for that.
Anyone who - for whatever reason - wants the new 2017 shifters on pre 2017 M bars and is in fear of a lack of gripspace may possibly use the M-bars by Joseph Kusoac. I have not seen or used them but they claim to be wider than the orginal while delivering the same height according to the description at SJS:
"Made from 6061 aluminium.
25.4mm clamp.
Ergonomic handlebar with curve in design.
600mm Wide - with cutting markings.
Standard 130mm handlebar grips compatible - Brompton bars use 100mm.
Weight 276g."
Possbily the easiest way if you are in doubt. No guarantee.
Quoted: 381 Post(s)
Liked 107 Times
Once again you quoted something as a fact in one breath and then say it may not be true. I never quote anything unless I have used it myself and know it works. Those handle bars may or may not work but but your saying they might work has no relevance to this in the discussion and is certainly not reliable. Roger
Super Moderator
Quoted: 1175 Post(s)
Liked 938 Times
MOD NOTE To All: The topic of this thread is "Alternative derailleur shifters", NOT arguing with or insulting other members.
Quoted: 585 Post(s)
Liked 119 Times
Some feedback, for science's sake.
Unsurprisingly — since it's a fork remote lockout lever and not a derailleur shifter, after all —, the Suntour shifter failed after barely 2,000km.
I'm now trying DTSwiss's "Remote Lever Single Stage", ref # FWXXXXXSXXX046197S.
Shifting is harder than with the Suntour, and I don't expect it to last either since it's also a fork lockout lever, but it feels stronger than the Suntour. The good news is that the Suntour kit included a barrel nut that I got to re-use.
At worst, I'll go back to the original Brompton shifter: It's less compact, just as hard on the thumb as the DT Swiss shifter after I filed down its trigger to make room… but it's obviously more reliable being actually designed to manage a derailleur.
Stay tuned.
Stay tuned.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 844 Post(s)
Liked 337 Times
Quoted: 585 Post(s)
Liked 119 Times
I was aware that a remote lockout lever wouldn't last as long as the original, but considering the price, I was willing to take the chance.
I'm not sure, but I suspect the original bolts are in steel, which would explain why they last longer. Before shelling out big bucks to buy titanium clamps + bolts from Asia (TWP, NovDesign, Kamoya, etc.), you might want to give SpedDial a try.
Quoted: 844 Post(s)
Liked 337 Times
to an under the bar set of shifters,
as stock , in 2018.
Reportedly they only move 1 gear change at a time, 1>2>3.
where the previously from the Steel trigger S-A, used on the Mk2, AW3 hub
and the easier working plastic one with the BSR,
can go from 1st to 3rd, 3rd to first...
[so functions better with my gear box MD cranks,
as I do a double gear, + crank- range shift between 3rd & 4th]
No experience with the newer versions, but they are supposed to be easier to install.
It does look neater on handlebar. The shifting can be quite precise too.l
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/960x960/12109041_1688018884747288_4581202929614200333_n_9f92b604e0ca1ce7166ba127ec32fc59de4d1e77.jpg)
Quoted: 585 Post(s)
Liked 119 Times
Yes, like I wrote, it's easier on the thumb than the DT Swiss, but the Suntour shifter gave up the ghost after barely 2,000km… which makes sense since they're both remote lockout shifters, not derailleur shifters.
Looks like the original shifter from Brompton is the only realistic solution.
Quoted: 844 Post(s)
Liked 337 Times
In post #37 OP discusses having tried this very shifter, marketed on Ebay by bikegang, and this very shifter broke in practical use.
Likes For 2_i:
Quoted: 844 Post(s)
Liked 337 Times
Grips are narrow on M-bars to start with. Pushing a Gripshift into there leaves intolerably narrow space for hand.
but S bars are also an option many choose.. M bar* you can put thumb shifters
on the vertical part of the bend.
test fitting my Bolt on FD mount kit , thats where it's shift lever fit...
(ended not using it, It's for sale)
*Latest M bar seems a different bend, appears more room, on top..
Schwinnasaur
Quoted: 585 Post(s)
Liked 119 Times
The P handlebar is getting a bit busy*, hence my quest for a slimmer derailleur shifter.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/800x358/brompton_p_handlebar_dtswiss_32dc3514b78660ffb8be507b39a5a22510e89f93.jpg)
* sawed-off bar-ends, double chainring shifter
Mine , M3L , are relatively un cluttered. Schlumpf 2 speed cranks
use the center of the crank arms to shift with your shoe heel.
hub dynamo headlight under the front bag .
hire a fabricator to make you an additional crossbar tube
across the center of your P bar for more space?
.. Have not fitted a bar end shifter in the bar tube open end yet?
