For the love of English 3 speeds...
#6002
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 152 Post(s)
Liked 177 Times
@arex - I like your bike! Was it a two phase paint job? Like with one color underneath and a sparkle/shimmer over the top?
#6003
@desconhesido-Fantastic. Thanks! It wouldn't have to be that particular brand. Any brand would be fine - with a vintage look. Just curious. At this point I will use my Niterider MiNewt headlight.
B + M Lumotec IQ Cyo Premium T senso plus front headlamp (black)
I think it's a fine looking light and I think it looks fine on the Sports, but it's not "period" correct for either my 79 or your 55 Philips. But, it makes a lot of light -- about as much as any "street legal" modern alternator powered LED light. It also has a low speed short distance light and a stand light. Retro looking LED lights are available from other makers. Also, very small and inconspicuous and, inmo, nice looking lights like the Supernova E3. But that's about three times as expensive as the B&M that I bought. About the same as the hub, spokes, rim, and light.
Of course, it works better with the Shimano generator hub, but with the dynohub, the short distance lights come on with a pretty slow rotation. A slow rotation which I'm guessing may be 3 to 4 mph lights the lamp with a noticeable flicker. A quick rotation lights it up steady. Flicker could be reduced/eliminated by the application of a rectifier, as discussed earlier.
Been working on the 51 Ladies Sports among a number of other things. Concentrating on cleaning and mechanical issues. Had it on the road for a test yesterday. Put a pair of those Panaracer tires that everybody else in the universe likes -- I'll just say, I don't like them. They're not round and they are labeled as 300,000 pa (N/m**2) or about 45psi max (45 psi!). We'll see what happens with 70 to 80.
Got the front brake working and hooked up for the test and it's pretty sloppy. There is a lot of slack, it doesn't center properly, and it moves a lot when applied. Up and down rotational movement centered somewhere along the through bolt axis. Most of the movement is because of the sloppy fit of the parts. I'm not sure if there is supposed to be some fiber bearing washers in there or not, but among the two 50s Sports, there are four brakes, and none of them has any bearing bushings or washers separating the brake arms or taking up the slack in the "stack." I would like to keep the old steel brakes for the looks, but functionality is what is most important for this bike. I am working on it so that it will be ridden and not by me, so I want it to be functional and safe. I'm not too worried about the steel rims when wet, because it will probably never get wet. I may try the steel brakes from the 74 Sprite or the Weinmanns from the 79 Sprite and see how they work. Then, replace those with the Tecktro 559 long reach brakes. Those wouldn't be too bad on either the 79 or 74, but both the 74 Sprite and 51 Sports need an upside down pull rear brake. The Steel "Bull" brakes on the Sprite and the alloy Weinmanns will do that, but I doubt if the Tektro 559s will. What the heck, it's only money.
We don't normally name our bikes, but when working on the front wheel, I noticed something on the bottom of the down tube.
For some reason, we've started calling this bike the Black Widow.
#6004
multimodal commuter
Quoted: 1908 Post(s)
Liked 575 Times
The above circuit will cause the LED to light up with a more constant light. It does not make a lot of light at any rate, but its better than nothing! Since the pulsing in the LED off state is normally not used, the result of using this circuit will be that the load will be a bit higher, so it will be harder to pedal. But not by much, I suspect.
backstory
I used to commute on a folding bike with 16" wheels, with a dynamo hub in the front wheel. The smaller wheel put out almost double the rated voltage, which literally melted several LEDs off their leads. So I got into the habit of soldering together my own lights.
the learning curve
I messed with halogen bulbs and various pre-made LED lights (such as tail light units made for car trailers). I messed with capacitors and bridge rectifiers and...
eventually
I realized I didn't need any of that stuff. The LED lights on my current folding bike have been in place since I soldered them together in August 2010, and are still going strong 8500 miles later.
And I got to converting old Lucas and Miller headlights to LED as well.
I'm now doing the wiring like this:
I wire one of the electrical terminals on the hub directly to the hub axle. From the other terminal, I run a wire to the positive terminal on a white LED for the headlight, and a wire to the negative terminal on a red LED for the taillight. I wire the other terminals on the LEDs directly to the light housing. The result is that the current from the dynohub goes alternately to the headlight and to the taillight. It's awesomely simple.
Now, anyone who knows anything about electronics will say "but only a caveman would do it that way!"
Okay, guilty as charged.
Does it flash? Yep. But only at low speeds. When I get up to speed, it evens out nicely.
Does the flashing drive me crazy? Well, I suppose that would explain a lot.
www.rhmsaddles.com.
www.rhmsaddles.com.
#6005
Quoted: 7396 Post(s)
Liked 2,564 Times
If she lost her husband, it's entirely fitting.
@Velocivixen, if you think you'll truly need a proper headlight while riding the 3-speed, I would advise doing as @desconhecido did and using a modern headlight. It's good to know that the old dynohub is up to the task of powering a modern light. Modern lights are spec'd to require a 3w hub, but it's not surprising that they work OK with whatever the old SA hub puts out, nominally 1.8w (I think).
#6006
Liked 2,564 Times
@rhm's lighting system is brilliant but takes a lot of work. I've really enjoyed installing B&M and Philips headlights. On some bikes, I have used antique dynamos (bottle or under-BB) and on some, I've used Sanyo hubs.
#6007
multimodal commuter
Liked 575 Times
@rhm's lighting system ... takes a lot of work. ....
Alternately you can just replace the bulbs in your existing Sturmey Archer lamps with these:
https://www.superbrightleds.com/more...fiURoCGGjw_wcB
But note, it requires DC current, so you still have to wire it more or less according to my wiring diagram. One lamp has to be center positive, the other center negative; otherwise reverse voltage will destroy the LEDs.
www.rhmsaddles.com.
www.rhmsaddles.com.
#6008
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 360 Post(s)
Liked 278 Times
^^ the reverse voltage should not do it any harm. When 'reverse biased' it simply won't conduct.
#6009
@desconhecido- Thank you for testing that out for me. Maybe down the line if I'm riding this bike a lot, I will spring for a modern Dynamo headlight. For now I will clamp on my battery operated one. Your copper Raleigh (Sprite?) is gorgeous. That is my second favorite color for old Raleighs.
You folks are all pretty electronics savvy. A good skill set to have for sure, and with your inventive and creative minds I can see how you come up with some nice solutions.
#6010
Quoted: 360 Post(s)
Liked 278 Times
I've been thinking that one of these could be adapted to a British machine. It looks the part but is likely brighter, and its cheap; at least it might do until the original is sorted out:
Retro Bicycle Bike Accessory Front Light Bracket Vintage 3LED Headlight Lovely | eBay
#6011
I'm using standard screw in 6v flashlight bulbs. They work but are very dim, should I use something else or are these lights just not made to be very bright?
Semper fi
Semper fi
#6012
Abuse Magnet
Quoted: 152 Post(s)
Liked 177 Times
#6013
Here's the bike shortly after I purchased and rehabbed it back in 2010, probably May. Since then I've installed the cork grips, which I like a lot, an aluminum rack which is not period appropriate, and recently the dynohub and B&M light. The rims and tires in the background are the ones that were on it when I bought the bike for $30. That's an expensive $30 bike. At the time, Colorado Cyclist was about as reasonable as anybody for spokes and I bought the 14 gauge DT spokes from them for $.50 each including the nipples. Got more in spokes than in the bike. You no doubt understand just how expensive a "cheap" bike can be.
#6014
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 16 Times
I have no idea what you are all talking about, therefore I am impressed. So would my dynohub power new, modern lights? Like if I removed the current ones & put some Busch & Muller Dynamo lights on? Could I just hook them up and off I go?
My Raleigh Twenty has modern LED lights on it. I use a B&M Lumotec Classic on the front. It is a smaller than the original but still looks okay. For the rear I went with a fender mount B&M Four D-Lite No special wiring, just had to watch which way I wired it up so they would work. The B&M lights use a two wire system. I can get pics later.
It spools up just fine and provides plenty of light for riding. FWIW my Raleigh Twenty has an AG hub on it, like your Phillips.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
#6015
@wahoonc - great to know. If you've got some time I would like to see your setup. My current lens is both plastic and has some degraded area on the inner surface. I hesitate to try to buff it out, as I don't want to make it worse. Also as either you or @Salubrious suggested my chrome piece around the lens does have a dent - not an indentation produced at the factory, like I first thought. This causes the lens to not fit tightly.
As an aside, I found the SA exploded diagram with parts #'s for my rear "rocket ship" tail light. It works fine, but nice to see what's involved.
#6016
Abuse Magnet
Quoted: 152 Post(s)
Liked 177 Times
Just pinstriped the lugs on my frame. I can now see why some people don't recommend paint pens...started out good, but the tip went mooshy quicker than I expected. I don't think I was abusing it, either. Next time, I'll use a brush.
#6017
Bikes: Too many to list in this particular space...
Next Project- '78 Raleigh Sprite 25" frame 3-speed
Well, I thought it was a 1977 from reading somewhere that Raleigh only made the 27" 3-speed Sprite variant for 1977. But looking at catalogs, I saw that the "Coffee" 3-speed was only offered in 1978, and I doubt this is a "Carmine" color. Until I get it apart and can easily check the s/n, I'll go with '78. This one was from a Raleigh twofer deal back before Thanksgiving. When I got it the PO had removed the crank and back wheel, fortunately saving all the parts except some of the axle washers from the SA hub. It also has no rack- otherwise it's all there. It looks like will clean up nicer than it looks- the garage rash was found to be negligible and the "rust" so far has come off with bit of spit on the finger. In the next week or two, I'll start disassembling and clean up the chrome. I'll take the frame down south to my sister's for a good wash and wax and see how it cleans up. The black headtube with the coffee lugs is a really nice detail. While the decals are in fine shape, I'd like to know what the sticker on the seat tube might have been. in the catalogs I saw one on the upper tube, but not sure about the bottom. Whatever they were, they weren't decals- looks like time has left glue residue.
#6018
Well, I thought it was a 1977 from reading somewhere that Raleigh only made the 27" 3-speed Sprite variant for 1977. But looking at catalogs, I saw that the "Coffee" 3-speed was only offered in 1978, and I doubt this is a "Carmine" color. Until I get it apart and can easily check the s/n, I'll go with '78. [...]
It looks to me like your bike has the steel brake calipers and the "self adjusting" levers. I think that by 77, they were using Weinmann alloy calipers and had abandoned the self adjusters (which are, as far as I know, universally disliked). That would suggest to me that it's likely 73 through 75, but one thing we Raleigh lovers know is that there's no telling.
About those levers -- other levers, imo, are better, but they work ok and are still on our bike. I offered to replace them with something else but the offer was declined.
#6019
Quoted: 3837 Post(s)
Liked 6,876 Times
Here's the '78 catalog page for the Sprite:
#6020
Bikes: 1969 schwinn sting ray 3 speed stick ...1974 raleigh sports
thats where my 74 sports dealer sticker is . look at the metal flake in the original "coffee " paint .
#6021
Abuse Magnet
Quoted: 152 Post(s)
Liked 177 Times
#6022
this is more the color .. in macro mode the camera and flash makes it look sunset ..suprising with their tea thing and all , calling it coffee
#6024
The SN is the way to tell. Probably it's on the seat tube and easily visible, It is on our 74 Sprite step through.
Maybe it's like this because its a Raleigh?
I would suppose the top sticker on the seat tube would have to with frame material? I see something on the top of the seat tube in the catalog pictures, but nothing on the bottom of said tube.
One thing that's interesting is the tall Record-based frame- seems unique for an English 3-speed.
#6025
Abuse Magnet
Quoted: 152 Post(s)
Liked 177 Times
