For the love of English 3 speeds...
Quoted: 346 Post(s)
Liked 643 Times
My new Raleigh 3 speed
I just pulled a Raleigh 3 speed from the trash pile and am not sure what to do with it.
I looked up the serial no. and it is a Nottingham 1978 model . The only decals say Raleigh on each side of the down tube, 20 / 30 Steel, and a decal on the top of the top tube that says made in England
I stripped it down yesterday. I was surprised to find that both the seat post and stem were easy to get out. Also the non drive (left) side crank cotter came right out. Must have been changed at some point and never tightened. I took the frame to the bike shop where we have a cotter press and the drive side cotter came out with no drama either. I will be reusing both unless I change the crank to square tapered. The brakes are side pull Weinman 730 front and 810 rear.
So now I need to decide what to do with it.
As found it was very rusty but not structurally unsound. I have cleaned off a lot of rust from the frame using navel jelly , sand paper, steel wool, Brasso , and tinfoil. The original silver paint is basically poor to dismal but the Raleigh Decals are still good as is the Green at the head and seat tubes The frame tubes are now grey semi metallic, with rust staining coming through the paint but I have succeeded in getting rid of about 75% of the original rust.
As for the wheels, both black wall tires look new or very little use with no cracking in the side walls. The rear rim was not very rusty except what was under the rim tape. I used navel jelly and a wire brush to remove almost all the corrosion. The front wheel is much worse . the exterior still feels like a cheese grater even after hitting with a wire brush . The inside under the rim tape is also corroded. I am not sure it is going to clean up very well.
So now what should I do ?
Totally stock ,
Frame as is , spray over the rust and bad paint with semi gloss clear? lube and oil , cables, brake pads . later maybe, new front wheel .
Beautify and lighten
Sand blast and repaint frame, fenders .(I can do both myself)
Aluminum handle bars ( I have a north road style bar with the ends going straight back )
Brooks seat, B17
new wheels
replace cranks and spindle with square taper , with forged alum arms and aluminum pedals.
new decals
Any other interesting possibilities?
I will definitely replace the stock drive sprocket with a bigger one to give me a low gear.
For now while I am building it I will keep the Brooks mattress seat and be on the lookout for a B17 or maybe a Springer seat.
Are the Weinman side pulls any good? Are they forged?
Jonny
Totally stock ,
Brooks seat, B17
new wheels
new decals
Jonny
Quoted: 1299 Post(s)
Liked 104 Times
Totally stock ,
Brooks seat, B17
new wheels
new decals
Jonny
Totally stock ,
Brooks seat, B17
new wheels
new decals
Jonny
Overdoing projects
Quoted: 790 Post(s)
Liked 1,304 Times
*Double post*
Overdoing projects
Quoted: 790 Post(s)
Liked 1,304 Times
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Quoted: 248 Post(s)
Liked 27 Times
This is awesome, I must know more
Overdoing projects
Quoted: 790 Post(s)
Liked 1,304 Times
With the exception of a 16T cog (the 28T will arrive next week) all of this was with stuff that had laying around.
Going to take it for a testdrive first to see how this feels but it feels fast.
Moved around some of the cables and stripped them where the original braze-ons would make more sense. Looks really good to just have cables running around.
Took some fiddling around to make sure the rear derailleur didn't commit suicide. It had a tendency to dive into the spokes.
EDIT: Felt really good. Quite smooth most of the time and it is fun having a bit more top speed. Only thing that needs some work is the chain. I didn't shorten it yet so when I hit a bump it fell off and the bike tried to eat it.
I'll be sure to shorten it when the 28T cog arrives.
That and perhaps I need a taller stem. This one is a bit aggressive.
Quoted: 6038 Post(s)
Liked 969 Times
Maybe you could just flip the handlebars?
I owned one myself, probably a slightly younger model, a 5 speed derailleur with upright handlebars. 20 years before my dad used to have one simular to that, also a model a couple of years younger and probably called a 'trimfiets' back then, and I did the maintenance and repairs. Not much, because Gazelle were so well made back then, especially considering the low weight they are extremely durable. And fast, very low internal drag, good geometry for a high cruising speed, handlebars were a bit low for my personal preference and head tubes can't be too slack for me, but that's personal and this design had me doubting that preference.
Quoted: 232 Post(s)
Liked 10 Times
headset washer?
Can some one tell me if there is supposed to be a big 1 inch washer/spacer on the headset?
the top race on my superbe has none.......just the bird light bracket and then the top nut.
IF i recall correctly the fork wasnt keyed for a washer of that type.
It just seems odd that it would together........top race........bird bracket.....top nut. The bird bracket is a bit rounded and doesnt seem to sit flush with the top rack which makes me think there is supposed to be a spacer in between there.
It is making it really tricky to get the play out of the headset and get it adjusted properly. I am wondering if the previous owner had it apart and missed a piece putting it back together.
Quoted: 7410 Post(s)
Liked 2,609 Times
@Utech22, why did you add more pawls?
Liked 104 Times
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,452 Times
See anything familiar in this photo? Did not know their expertise extended to motorcycles.
elcraft
Overdoing projects
Quoted: 790 Post(s)
Liked 1,304 Times
As far as I can tell that is the sister model. Same color and everything, just different front fork and gearing.
I replaced the original seatpost with a taller one so I have been playing with the right angle. Kind of like the look of the flipped bars but I just need it to be a bit higher and a bit more forward.
Apparently the simple version is putting two dished sprockets side-to-side with a hanger derailleur, but apparently you can also do it using the older threaded drivers (up to 5 additional sprockets) or a Dacon hub-derailleur converter.
- Sheldon Brown - Hybrid gears
- Lovely Bicycle - Hybrid gearing in the wild, 6-speed
- Classiclightweights - Hybrid HD
Bikes: Owned 5, not at once. 3 at most at once.
Quoted: 7 Post(s)
I will create a video and upload it for a better idea;
Quoted: 7 Post(s)
Hope that you understand.
Quoted: 7 Post(s)
Overdoing projects
Quoted: 790 Post(s)
Liked 1,304 Times
Quoted: 248 Post(s)
Liked 27 Times
So the only difference is in the sound? It doesn't give you any more points of engagement or any kind of performance improvement?
Quoted: 248 Post(s)
Liked 27 Times
I decided I liked the machined shifter cable pulley so much, that I'd like to see what it looks like in brass.
I included a shot of the stainless one I presented last week.
I'm tending to go with the brass one, because it makes the gold pinstriping pop.
Brass one is mounted on my '73 Raleigh superbe, the stainless one on my '71 Raleigh Superbe
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
My new Hercules:
J
J
Quoted: 7 Post(s)
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1030 Post(s)
Liked 445 Times
1960 Superbe Update
I decided not to paint this bike for the time being. I was anxious to get it back together and take advantage of the warm fall weather. Costs to date:
Bike purchase @ $50.00
New Tires @ $32.00
New Cables @ $18.00
New Brake Pads @ $6.00
Brake lever ferrule @ .40 cents (Outrageous!)
The chain ring crank needs to be straightened and I'll repaint later.
Saddle is OK for now but will look for a vintage leather one.
I've also replaced both calipers with "newer" versions to do away with the proprietary earlier ones.
Took it for a shakedown ride today and have a few adjustments to make.
New Tires @ $32.00
New Cables @ $18.00
