Cinelli Super Corsa
Quoted: 3464 Post(s)
Liked 2,831 Times
The original condition images do tell quite a bit. My guess it left Cinelli as a frame set. Got built in Spain. Going back, Spain was an outlier and not part of the Common Market for quite a while. Imported stuff was expensive. The frame may well have not had any chrome. Not without precedent, but uncommon.
I like it very much, now I really think it should be repined in a more original way. Seller probably values his work, too bad on that.While this is not the valuation forum, $1,200 I think is below market.The comments about the metalwork features are worth noting, but with paint gone a better story might be told.The head lugs look nicer than a typical Model B walk the shorelines carefully around the tubes and compare to a known Model B, this bike got more attention. Def. not a Riv'That steel crank is interesting, note the attachment point for the chainring at the backside of the arm. I would use those, get some alloy rings for them. (reasonable avail.)Keep the Universal brakes, go Campagnolo elsewhere. Maybe Sheffield pedals. Fiame rims.
So do you think it´s a good buy? I collect bikes from 80´s so i´m not an expert on this. My main objective is to confirm that it´s a true supercorsa.
The difference with a B model is only the fork?
Liked 2,831 Times
https://cinellionly.blogspot.com
Model B 's evolved too.
Note that Cinelli was not a large producer, yes of decent volume, but decisions on the shop floor from my view that caused consternation decades later did get made.
In this case i know that it´s a supercorsa for his fork, if someone put him a B model fork i´ll think that it´s a B model.
Liked 2,831 Times
You will find that the head lugs of your frame are similar but in my view nicer. Look at the reduction of the lug heights at the front of the head tube, the Model B's got less effort.
In my view it is a top tier model. The head lugs got more much attention all over. Note the side views too.
A 3ttt saddle on a Cinelli? how gauche.
I wouldn't hesitate for a second. You will most likely be upset with yourself if you don't get it, and as long as the price is decent you can always sell it without losing any money.
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
The bet way I have yet found to date a Cinelli frame is to use Velo-Retro's Cinelli timeline, found here. Velo-Retro: Cinelli Timeline It is my go-to source for trying to figure out how old a pre-Colombo frame is.
Referring to the time line, you will see my confusion over the combination of "wolf's ear" head tube lugs (discontinued around 1960) and no oil port on the left side of the bottom bracket (still used until the mid-1960s.) According to this, the wolf's ear/no oil port combination should not exist. Cinelli did do custom work and would do stuff for individual customers that he did not do for frames going to dealers, so nothing is impossible. It is, however, very unusual.
Seeing the "before" photos boosts my confidence level that it is indeed a Speciale Corsa and probably a late 1950s one. I'm still not 100% sure, but over 90% sure.
You definitely want to find out whether it has a 70mm or 74mm wide bottom bracket shell. If it is a 74mm shell, that pretty much narrows the possible date range to 1957-1964, but pray it is a 70mm, because that means any standard Italian-threaded bottom bracket from sometime in the 1950s to now will work and all you have to worry about is spindle dimensions (which can be enough of a challenge). The 74mm shells also have the standard Italian threading, but good luck finding a 74mm bottom bracket that will work with the crankset you have. I have been down that road with an old (1961) Bianchi and I finally gave up and installed a Phil Wood BB (not meant for a 74mm shell, but the Phil Wood design is such that you can make it work).
In any event, it is an intriguing frame and I hope it works out for you.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
You may have better luck dating the Spanish components to get close to the year your frame was built, assuming they were the original build. Contact a vintage Spanish cycling forum?
Quoted: 378 Post(s)
Liked 1,410 Times
Given the original condition, it's a hell of a restoration/rescue. Bravo to whomever did it, and took the time and trouble to bring that thing back from the brink.
Quoted: 7350 Post(s)
Liked 2,475 Times
I just looked at my photos, and they are awful. I have pretty bikes, I promise, but I'm such a bad photographer.
Are the quick-release levers installed properly on the brakes? I am not familiar with those brakes and can't see the photos that well, however, they seem to be upside-down and backwards.
norskagent
6
05-29-11 05:54 AM
maym036
9
05-11-11 04:54 PM
