Proper spacing when hanging bikes in garage by one wheel?
Quoted: 590 Post(s)
Liked 445 Times
+1 for 16" apart (rubber coated hooks in studs, with some vertical staggering.
Edumacator
Quoted: 2441 Post(s)
Liked 3,136 Times
The objective is to pack them as closely together as possible. Some people are in the unenviable position of being limited in their bike purchases by storage space. For those people I recommend making friends with those that have more storage room than bikes (I know, how can this be?) and bone up on the Zero Bike concept.
...plus, no one I know has unlimited space for my bikes unfortunately...it is a sad truth.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
I'm impressed by how many of you can access your garage walls. I can barely see mine.
Quoted: 767 Post(s)
Liked 1,898 Times
The one I have is branded Monkey Bars. Amazon sells it. Maybe others, too. It's ok, but honestly some coated hooks from the hardware store and some wood would be cheaper and perfectly fine. I had some hung on hooks that were mounted on studs spaced 16" and liked the spacing better.
Quoted: 590 Post(s)
Liked 445 Times
When I moved into my new home last year, my highest priority on Day 1 was mounting the bike hooks in the garage in the most convenient locations possible, before the rest of my stuff was moved in and took up that wall space. I'm glad I did, since now I can't see any of the walls.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
Edumacator
Liked 3,136 Times
Quoted: 1609 Post(s)
Liked 2,216 Times
If you think hanging a grocery getter is hard try a tandem! It barely fit in this one car garage where the car is parked every day.
WP_20140302_004 on Flickr
Even hanging from a pulley system challenges the arms to lift. The frame alone is 13 lbs. This picture was before mounting the pulley system and was a real challenge to lift the entire bike up and over a hook.
MVIMG_20180222_201811 on Flickr
I was hoping the ceiling was a bit taller so I could mount over the garage door. Ended up using that space for the wheel barrel.
Quoted: 835 Post(s)
Liked 2,136 Times
I also hang bikes on 16" studs and then squeeze more bikes in between hung from the wall a bit lower. It helps that I ride fairly narrow bars (mostly 40cm). I agree that it's not a big deal to angle the adjacent bikes a little bit out of the way when taking down or putting up the bike. I could perhaps squeeze in one more hook in between the Colnago and Merlin. Another suggestion is to use foam pads ("pool noodles") on the top tubes or at other contact points.
Quoted: 787 Post(s)
Liked 521 Times
-John
Quoted: 21 Post(s)
Liked 185 Times
I store mine pretty tight, I can't remember the spacing between hooks but I think it's about 9"-10". Bikes are staggered, one up one down etc.
I'll admit, it is tricky to bring them down and put them back.
Klaatu..Verata..Necktie?
Quoted: 10440 Post(s)
Liked 11,914 Times
Wall storage is easy, especially if you have significant saddle-to-bar drop, then you can put the hooks at the same height and there's no interference. You can space the hooks about 2" wider than you handlebars.
It's storage on the floor that's the problem. I have to pass each successive bike's top tube under the drops of the last one. BUT, this way I can keep 9 bikes in the corner.
Then I got a 10th bike. Now I have to leave one on the trainer....
This is 10 bikes hung from hooks in the garage spaced at 12" ....................... 10 bikes in a 10' space!
Likes For ramzilla:
Likes For panzerwagon:
