BQ "Myth 18: Wide Tires Need Wide Rims"
Pedalin' Erry Day
As others in this thread have said, I think Jan's conclusion is mostly correct, but the argument he's making to reach that conclusion here is just rubbish. The central problem with his argument is that he claims that people are choosing wider rims because it makes sidewalls stronger, but this is simply not true and that makes his points about sidewall flexibility and tire compression irrelevant. And his comments about the advantages of the "O" shape of tubulars is actually one that should encourage people to use wider rims, since a wider rim increases the outer circumference of a "Ω" shape tire. But perhaps the most ridiculous thing about this article is that in it he describes experiencing (but misattributes the cause to stiff sidewalls) the very problem that people in this thread have already mentioned and the reason why we need to be careful not to match tires with rims that are too narrow: if you don't have enough tire pressure, the sidewall can buckle and the tire can roll, which produces squirrelly handling, flats, blowouts, and crashes - and note that this need for higher pressure in turn limits the advantages of wide, supple tires.
Quoted: 1627 Post(s)
Liked 630 Times
If it's a wider tire on a narrower rim, I suppose proper inflation pressure is a legitimate concern. I wouldn't run my 35mm Paselas under 50psi on my 17mm Alex rims, but you probably wouldn't, either. As long as the bead seats solidly and the tire is quite firm for your weight, I can't see how there is any any problem.
If the tire is so soft that cornering hard pops the bead out; then you have a problem.
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
I think the idea with mountain bikes, in having the tire much wider than the rim, is to protect the rim in rocky terrain - The rim being tucked in behind the bulge of the tire, out of harms way - No concern with high speed road handling here.
Likes For mixteup:
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
From the man himself... but you should find the limit for yourself (within reason)
Somewhere, a village is missing its idiot.
Quoted: 1324 Post(s)
Liked 927 Times
I don't often start threads to be "provocative", but I didn't see a thread for this one yet, and was curious of the C&V Brain Trust's take: https://janheine.wordpress.com/2019/06/26/myth-18-wide-tires-need-wide-rims
It never would have occurred to me to think of narrow rims pinching tire beads close together as making it more tubular-like, and I'm still working through that concept.
It also seems to me that Keith Bontrager's intent when rolling MA2/MA40's into 26" rims wasn't necessarily to make narrow MTB rims, just to make lightweight ones. I'd welcome correction on that one.
I feel like the truth is somewhere in the middle on the rim width thing. Probably would have titled it "Do wide tires really need wide rims?"
I recommend that if you insist on riding a wide tire on a narrow rim that you take the bike and your pump to a school yard or a quiet parking lot and let most of the air out of the tire and see if you can maintain control on it. I know with the CX Pro tire on the narrow rims I had them on there was immediate loss of control if the front tire flatted or went very soft.
Cheers.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I had some Schwalbe Pro CX Pro cyclo-cross tires mounted on narrow rims. All was well until I punctured the FRONT tire. Down I went. the entire tire stayed on the rim. This happened on two different occasions and I went down both times. Fortunately I was riding quite slowly each time. I figured that the risk of a crash in heavy traffic was too great to continue using that combination of 30mm tires on those narrow rims. I replaced those tires with 25mm tires and will put the Schwalbe CX Pro 30mm tires onto wider rims. I will NOT risk a front tire flat throwing me into heavy traffic. YMMV but it's definitely something to consider. What happens if a front tire flats and causes you to spill as you're sprinting through a left turn with oncoming traffic or you spill in some other traffic gap because your front tire flatted and then the front wheel immediately went out from under you? When my CX Pro front tire flatted I went down IMMEDIATELY with no warning at all.
Cheers.
Cheers.
I've run inches-wide tires on i13mm 700c rims and all was fine since I kept a reasonable pressure of 25psi in them for my 180lbs of bike+rider weight.
I've had 2.6" tires on i51mm rims fold over in turn when the pressure was just a couple of psi lower than what that combination required, so it's not just the narrow rims that allow this. A given tire's needed pressure for use with wider vs. narrower rims isn't that much different, and much of any psi difference is simply the result of the tire achieving a smaller cross-sectional width on the narrower rim (which results in a proportionally-lower tension in the casing).
Tires that flop more may also better keep the tread cap facing the road surface as opposed to contacting the road near the edges of the tread (which also can become slippery from their infrequent scuffing against the road).
Also it seems like it will be the case that some tires are designed (tread cap width, etc.) to be used on narrower or wider rims than others, so one more consideration when choosing tires.
Just as how some tires are designed with a flatter tread contact area better suited to maximizing traction on lower-traction surfaces, while other tires feature more tread wrap to exploit sharper cornering angles on higher-traction surfaces.
Liked 927 Times
I'm just wondering here what caused your flat tires(?).
I shudder to think what would have happened had either of those two flats happened in heavy traffic especially on a very busy overpass that has entrance and exit lanes to the 401 highway (Ontario, Canada) which I would have be riding quite fast to get past.
Why those tires lead to instant loss of control I don't know or care. The fact that they do is enough for me to no longer use them on a narrow rim.
Cheers
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
As long as you stay within certain limits, a lot of this stuff just doesn't matter much. For me, the difficulty is knowing when I get close to those limits. With that in mind, wide tires are simply much more forgiving.
Case in point: fat tires run at significantly lower pressure than thin ones. Therefore when punctured the air leaks out of a fat tire at a slower rate than out of a thin one. Furthermore, there's a lot more air in a fat tire than in a thin one. So when a fat tire is punctured, more time and distance goes by before you notice anything wrong. All that's very nice. But even so, there comes a time when so much air had been lost that handling deteriorates, and at that point the shin hits the fan.
Until that point, the relative widths of tire and rim aren't really critical to anything. Even so, I'm sure there's a point where a wide rim supports a squishy tire better than a narrow one. I hope I never find out the hard way!
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
Note the date that was posted.
I find no virtue in clinging to one's original beliefs until death. It takes humility and courage to keep looking at an issue and asking oneself "What if I was wrong? What is the actual truth?" That's the basis of Jan's whole "journey of discovery" blog posts. "What if our assumptions were wrong? What would be better?" It's debatable whether he always lands in the right place , but this stuff tickles my brain to no end.
Liked 2,571 Times
Cheers.
Cheers.
Liked 927 Times
Cheers
Quoted: 4816 Post(s)
Liked 3,945 Times
Threads like this remind me why I want to go back to tubulars. $$ vs skin. And now my all-time favorite tread is back. I can get tubulars with the super-sweet ride and synthetic casings that laugh at getting wet. (That tread - ribbed. Fine longitudinal ribs. The best tread for climbing out of ruts, cracks and back onto the pavement. Very good corning, Quite decent in the rain. A great all-around tread that is extremely good at keeping you upright. Why it disappeared for 20 years is completely beyond me.)
I've been riding the Vittoria G+ tires in 28c on skinny ribs. Love 'em. Ribbed tread. Grippy tread. Fast. They do flat from picking up objects. (Around Portland, OR, tire wire and small thorns. I suspect their tubulars do the same. I'll try sealant and a spare under the seat. If that works, I get: the supple casings, fast, grippy tread and the ribs I love plus a tire that can flat at any speed without issues. Tires to keep this old body with far too many crashes on it off the tarmac. And yes, I will have $200 glued and strapped on the bike. Perspective - that bike has a ti stem post and frame. $200 is play money. And every time I go to bed and have to arrange the foam pads around my old injuries - well $200 so I don't have to cut out a new foam pad for the latest?) I'll have to go back to the ritual of gluing tires. Tubasti! And I get to ride the magic carpets again. (It will be the first time I will have been able to do an A-B comparison of clincher and tubular since Vittoria's G tires share the same tread and casing. Also get to see if the old bump at the valve that nearly all tubulars had is still there. Tubulars at least used to be made like real magic carpets, by hand by artisans in Italy as opposed to artisans in Persia.)
Saturday I had the chance to pull the trigger on a $150 Campagnolo Veloce wheelset (with skewers, tires, wheel bag but no cassette) for $150. He'd probably take $125. Have his phone number. Do I? Getting tempted.
Ben
Ben
Liked 2,571 Times
Aha, good important data there.
Liked 2,571 Times
Ben
Ben
RUSA #7498
Originally Posted by noglider
