New CAAD 12= The return of Aluminun bikes to the real world?
#76
Quoted: 20810 Post(s)
Liked 9,456 Times
Really? I haven't listened to DS in surround, but 95% of the music that I've heard in surround sucks; usually too heavy-handed with the side/rear mixing, but on the rare occasion that they get the ambients right, I don't think that it adds much to a decent two channel system that's been properly set up.
#77
Bikes: are better than yours.
Most recorded music, especially in rock, pop, dance, rap, electronica etc, creates utterly artificial environments and instrumental balances impossible in any real acoustic space so the question of how ambients are handled is usually moot. (DSOTM and Steven Wilson's work are good examples of surround in that context.) Live acoustic recordings originally recorded with a coincident pair or an artificial head binaural setup aren't really amenable to surround and aren't usually translated to the medium. So that leaves things like multi-microphone recordings of acoustic music that attempt to maintain a natural balance. Of the few of those that I've heard, I'd say that the Buena Vista Social Club's DVD-A and Telarc's 1812 Overture in 4 channel are both quite effective in creating good environments. YMMV.
Telemachus has, indeed, sneezed.
#78
Bikes: 2014 Specialized Secteur Sport
Quoted: 21 Post(s)
Just a FYI, Carbon has lots of extra cost items.
Carbon frames require polished molds. You do not just pull a mold from a CNC machine and use it. It needs finishing. A mold can only have so many 'pulls' or parts made from it after which time it will need work to correct imperfections or be replaced.
Having worked with carbon and kevlar for R/c plane building, it requires a skilled hand and is partly an art. It is rather challenging to hit a target weight reliably.
If they are using prepreg, the epoxy is already in the fabric. They could be using infusion where they inject the resin after putting the dry fabric into a mold. Both methods will produce a rather repeatable weight. If they are hand applying to dry fabric, it takes skill to recognize when enough has been applied and when it is too wet. A part that is too dry will fail and cannot be sold. a too wet part will weigh too much and the extra epoxy will do nothing to improve strength.
Then you need ovens to heat cure the epoxy. Most production parts in carbon use a heat sensitive epoxy to keep it workable at room temp and to result in a stronger bond by using a post curing temps. It also can take hours in the oven to fully cure and until that i done, nothing else can be put in. The cost to operate and the time limits the number that can be made in a single day.
Also for each part being made, you need a mold for. Those molds are not cheap to have made and this too needs to be amortized across all parts made.
Epoxy is one of those chemicals that everyone eventually becomes allergic to. I am sure they are using chemical masks and /or respirators but exposure will eventually turn to allergy and I wonder if this will limit their lifespan in the job.
With metal, I wonder if the welding frames need replacement as often or if at all. I have no experience with metal.
I would think metalworking can be done more assembly line and only the time to cut weld and treat, etc needs to be worked out and each step , I would think, takes less time so more parts can be made per day.
Another issue is that the carbon tow that is used to make the woven fabric is only manufactured in a rather limited number of locations. Some sizes of tow are hard to come by. In any case, carbon cloth has jumped in price over the last 10 years due to the demand by aerospace ( Boeing and Airbus ) and many other markets.
IMHO
IMHO
#79
Or maybe those of us who have sampled the various offerings, just come to the realization that steel/AL/Ti > CF. No comp[anies I know of are sponsoring pro riders to ride steel bikes, and yet there is a growing demand for them. By contrast, they have to sponsor pros with their CF bikes to generate a demand for them.
If you didn't catch it in other posys of mine: I'm selling my CF Venge....gonna replace it with steel. Currently riding a CF and Al bike. both of equal quality, I like the AL bike better; and remembering my years on steel- even cheap steel- I just miss it. I tried carbon- I had to at least give it a shot and see. Verdict: Meh....
To be honest, yes, there is a nostalgic return (albeit small) to steel. Not unlike vinyl, etc. But carbon most definitely has its place. I recently did a horribly paved ride that was almost intolerable except that the amazing absorption of the EVO frame was doing its job quite well. (Not to mention keeping the bike quite silent) Even aluminum can do its thing quite well, when geometry is created to make it so.
In fact, dare I say these material debates have a whole lot less to do with material now than geometry. I've said before, I don't even know why Cannondale & Spesh make the Synapse & Roubaix. The EVO & Tarmac are so shock absorbing that the only thing left for those other 2 frames to do is put a ride in a more upright position. And, heck, you could do that with a stem anyway.
I'd bet if you tested enough aero bikes in CF, you'd find one you like a lot. If the Venge didn't work for you, I don't know that steel is the answer in so much as a "different" bike. (geometry being key)
Still, I admire steel and am glad we have several materials to choose from. That's why we don't all drive Fords.
#81
Old Fart
Bikes: '97 Klein Quantum '16 Gravity Knockout
Quoted: 163 Post(s)
It's only because you haven't bought a SuperSix EVO yet.
And it's not that I don't like the Venge. It's a fine bike, and very comfy- and offers the stiffness that I desire- but it's just "missing something" compared to even my AL bike. Bith bikes have good road feel, which I like- but the Klein has something more; it's like the Klein isn't just on the road...it's more like it's planted on the road; whereas the Venge is just on the road. The Klein only weighs 2 lbs. more...but yet has a feeling of substance that the venge lacks. (Hmmm....just ocurred to me: I wonder if the carbon Aerofly bars on the Venge are soaking up what I'm missing?)
I remember when I was a kid, I once rode another klid's Big Wheel- Man! That thing seemed so cheesy compared to banana-seat Ross boat anchor I had at home... CF bikes remind me of that Big Wheel. And while you may well be correct, that there may be a CF bike that can reproduce the characteristics of a steel bike,; the thing is, there are lots of steel bikes which all posess the desired characteristics; and for a lot less money- so why look for a CF which will replicate metal...when I can just get metal?
The only thing I'll have to watch for, is not to get one that is noodly- I don't need a bike flexing under me as I'm Hulk-smashing up these hills! (It'll be interesting to see how good steel compares to my Klein in that respect- the Klein may have spoiled me. Been a long time since I've ridden steel, and when I did, it was gas-pipe steel... Who knows, I may find that nothing beats the Klein, eh? Which wouldn't be a bad thing....but I have a feeling that an old DeRosa or similar will be pretty sweet.)
#82
Vain, But Lacking Talent
All that said, I love me some steel. My Bianchi is a plush ride, but I think part of that it the light tubing combined with my "formidable" frame.
But from all of your previous posts, I would recommend you stick with steel. Mostly because I don't want to hear you *****ing about the next carbon bike you buy.
I have to ask: WHY did you buy a Venge in the first place?
#83
Old Fart
Quoted: 163 Post(s)
If the only CF bike you've owned is a Venge, I would argue that you have NOT really gotten the carbon experience. It's been stated here recently (you were there for it) that the Venge is a notoriously stiff ride. I would recommend you ride a Tarmac, Emonda, or SuperSix to get a feel of what carbon truly has to offer.
One of the reasons I want to go with C&V steel, too, is that I want to return to downtube shifters.
I'm really just selling the Venge to finance my steel endeavor- and because i don't ride enough to justify having 3 bikes. Otherwise i'd keep it. It's a fine bike, and I've done my longest rides on it, in great comfort and no complaints....like I said, I just feel that something is missing compared to real metal. Not that big of a deal really- it's just that my Klein has that "something".
I've always thought that the Supersix Evos were NICE-looking bikes.
Hey, if i still ***** after getting a steel bike, then you give me 40 lashes with a soggy brake cable (Just the cable; not the housing!), and then I'll stick with Kleins! (Maybe that's what I should just do from the git-go...just get an older Klein with DT shifters to complement my '97).
But yeah, my ultimate take-away is, there's nothing wrong with CF, and it won't assplode if you look at it wrong.....but I just see no real advantage to it. I can't complain about the Venge....but i can't rave about it either. I want to be able to rave. (Just being a lunatic isn't good enough! I need to be a raving one! )
#84
Redefining Lazy
Bikes: 2013 Cannondale Synapse 5 105, 2013 Giant Escape 3
Quoted: 13 Post(s)
Maybe, Trek could help them with the name. DAAC, DACA, CADA, etc.
S
#85
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
I think we'll see the CAAAD1 (Cannondale Advanced Aluminum Aero Design) in the 2017 range. "How do you pronounce it differently from CAAD?" "Well, one's a CAAD, and the other's a CAA-AD." "Ummm..."
#86
Redefining Lazy
Quoted: 13 Post(s)
I only just realized that Canyon missed out big by not naming their aero bike the Canyon Aero.
https://youtu.be/7ZeFDe44Ddo
#89
Quoted: 344 Post(s)
Liked 297 Times
#90
Climbing: Ropes or Wheels
Bikes: 2012 Scott Foil 30, Homebrew Windsor Fens Build, 2015 Fuji Touring, 1980 Univega
See? People can believe dumb things in large numbers. Especially when the internet is involved.
#91
#92
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#93
Bikes: 1975 Motobecane Le Champion lilac, 2015 Specialized Secteur Elite
Quoted: 97 Post(s)
50 years ago and are desirable because they were around and all over the road when today's buyers were young. It's pure nostalgia.
This discussion pertains to brand new bikes being better built with what is simply an older material.
For what it's worth I would bet any amount of money that the MAJORITY of the carbon fiber obsessed non professional crowd wouldn't know the ride difference between it and aluminum if they were riding the bike blindfolded.
Call me crazy but marketing is a very powerful tool that can delude the best of us. Most people want to spend their money and need to feel justified for doing so regardless of how wealthy they are.
#94
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Terrible analogy that makes no sense at all. Those cars are classics there were built
#96
#97
Quoted: 97 Post(s)
My point quite clearly referenced the OP who quite clearly referenced the NEW 2016 CAAD12. People are
not shelling out all that cash for a 2016 bike for nostalgiac purposes. Makes no sense at all. If they were truly nostalgiac they would buy a bike that was actually built and around when they were young. Hence the terrible classic car analogy
#100
Yup.
Some folks are happy shelling out a couple of hundred and riding steel for years. Other folks are stoked to shell out Thousands and then paying a couple of hundred for Carbon for years. Or until the new Upgraded Frame comes out that shaves 10 minutes off 200 km, disregarding previous thousand dollar frame.
