US-Based Teflon PTFE Powder for Mixing with Paraffin - Runway Stands Alone as of Now
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Occam's Rotor
Liked 2,331 Times
I just use paraffin without any magic ingredients, and it has greatly extended the life of my drive-train. I think this is simply because sand isn't sticking to it, rather than any extraordinary property.
My guess is chain lube primarily protects the chain from the environment, and the actual metal-on-metal low friction surfaces are those bonded on during manufacturing. It may help protect those bonded low-friction surfaces from premature erosion.
Likes For Cyclist0108:
Quoted: 4560 Post(s)
Liked 2,804 Times
If you're curious about PTFE as a chain lube, an easy way to try it is Rock 'n' Roll Absolute Dry. It appears to be nothing but PTFE powder in naphtha as a solvent/carrier that evaporates, leaving only the PTFE. I've used it and R'n'R Gold (same, with a bit of oil for some wet resistance and a bit longer between applicatons). Not bad, cleaner than most conventional wet lubes I've used.
No need to strip the chain of its original lube (unlike the recommended prep for waxing chains, with or without PTFE, moly, etc). Just wipe it clean with a rag or paper towel with some mineral spirits, alcohol, acetone, whatever you have available. If you're really picky, get some cheap cotton swabs (a buck a box of 200-500 at the dollar store) and swab between each link. That will cut back on the grime that invariably accumulates on the chainrings and cogs.
Rock 'n' Roll suggests practically flooding the chain, but I found that to be unnecessary and expensive. I use a needle dropper with R'n'R Gold, and place a drop on roughly every fifth or sixth link. I do that once or twice a week depending on how often I ride. Seems to stay clean and when I've removed the chain (via quick link) to check how each link feels, they all seem to be adequately lubricated.
After Rock 'n' Roll Gold or Absolute Dry carriers evaporate, the chain feels slightly tacky like a Post-It Note but slick.
I got some dry PTFE powder in January, supposedly smaller than 1.7 microns, per the seller (who was probably anticipating customers via the Oz cycling dude's videos). Haven't used it yet in wax. In February I had to empty my apartment for reflooring, misplaced my Little Dipper crock pot for chain waxing, and haven't bothered to dig through every box in the closet to find it. So I've been using Rock 'n' Roll Gold and Absolute Dry all year on my road bikes.
I still use Park CL-1 on my hybrids/errand bike, because it's very resistant to rain and lasts for months between applications. I wipe the chain externally once in awhile with a paper towel and mineral spirits, but that's all. It's also PTFE in a medium weight oil that dries a bit tacky and sticky like motorcycle chain lube. CL-1 ranks so-so on the Friction Facts tests, but it's good enough for my hybrids and I've had the same bottle for five years and it's still half full. I'll consider something "better" after I run out.
Likes For canklecat:
Bikes: Shmikes
Quoted: 10210 Post(s)
Liked 5,916 Times
I just use a Park Cyclone chain cleaning gizmo and some Pedro's biodegradable degreaser. It takes a few minutes and is super easy. I'm hoping the bio degreaser is, in fact, not toxic. Somebody please tell me if I should stop using it. I doubt my regimen prolongs chain life, but a clean/lubed drivetrain works better.
I have heard that the biodegradable degreasers are pretty noxious, especially when contaminated with lube, but I live in my own glass house.
Quoted: 1814 Post(s)
Liked 923 Times
I had not considered the environmental impact.
What is the amount of waste put into the environment by a bicycle compared to a home furnace, air conditioner, automobile for home computer? We have a lot of substances in our bodies from the environment. Teflon is inert unless it is heated to over 500 degrees.
What lubrication is better for the environment? How big is the impact?
I am going to evaluate this seriously. Thank you for bringing it up.
Plain old petroleum oils, or paraffin wax does 99% of the job. I use motor oil thinned a bit, which tests very well and is cheap.
It's true that there are lots of sources of toxic and harmful stuff, and it's near impossible to avoid much of it, but I think we need to try to reduce the amount of mess that we're making.
Here's a link to some info.. I've met the woman who started and runs this organization- she is impressive.
https://greensciencepolicy.org/highl...ted-chemicals/
Quoted: 7674 Post(s)
Liked 3,548 Times
Liked 3,548 Times
Get off your computers, too .... not only are we very destructively mining and manufacturing with rare-earth metals, we are using electricity, both at home and to cool massive server farms.
And you know what's the best part? If every citizen cut his/her chemical/carbon/energy footprint in half, industrial pollution would continue to be 90+ percent of the pollution created.
I spent enough years as an environmental activist, doing whatever I could to minimize my impact. I found that everything just kept getting worse.
I do what I can, but I won't hurt myself or constrict my life options to have an infinitesimal difference or none at all.
Have you ever considered the sourcing of the coffee you drink? The enormous environmental damage caused by the factory farms which produce the bacon you love? Yet, Americans have roundly rejected paying more for safe sources, and reject vegetarianism outright.
Pretty sure I am not killing a significantly greater number of fish, birds, or animals based on my choice of chain lubes.
Likes For Maelochs:
Occam's Rotor
Liked 2,331 Times
Occam's Rotor
Liked 2,331 Times
Is there any evidence that wax + PTFE is better than wax alone?
Did you read the first post, or watch the Oz cycling video? That's where the claim of major chain wear comes from.
One problem is that few people understand and measure the three types of wear. Most only measure the change in length, which is a change in chain pitch. Even that is often done incorrectly, using some device that adds roller wear to the actual elongation. The second thing to measure is the roller wear. The rollers wear on the OD and ID. I made a gage to slip in between the rollers. It measures about .240 inch and it ever slips between the rollers, the wear is quite large. An autopsy will reveal that most of the wear is on the ID of the roller. The third thing to measure is side clearance. When a chain in new, a feeler gage in the range of .004-.008 inch can be slipped between the inner and outer plates. I've deliberately used a Campy 10 chain for 6,000 miles and found very little elongation, but lots of roller wear and side clearance that was twice that of a new chain. When that chain was replaced with a new one, I got chain skip on the two most worn sprockets. Using a single chain for too long can have expensive consequences. Oz seems to only check elongation, which is a mistake.
I use my own paraffin based liquid lube with about 30% high quality lubricating oil, added to the wax, before it's dissolved in 4-5 parts naphtha (camp stove fuel). Liquid lube takes far less effort and can be reapplied quickly and more frequently, without removing the chain. I relube about every 150 miles and take the chain off for cleaning about every 600 miles. I could easily add PTFE to my lube, but what I use now seems to work quite well and it leaves only minor wax build-up on the sprockets and jockey pulleys. I also use 4 chains in a rotation for each of my two cassettes. Each chain can be used longer and the cassette will last the life of all four chains, since a new chain is never used on a well worn cassette. New-chain skip will never occur.
Occam's Rotor
Liked 2,331 Times
From what I understood in the OP, the claim was that paraffin plus PTFE extends the life of the chain. I personally have had very good luck with just paraffin, so could easily imagine that is where most if not all of the drivetrain life extension comes from.
Bikes: Shmikes
Liked 5,916 Times
A long time ago when I learned about the roller wear confound with the chain gauge, I checked a series of chains which my Park gauge said were fatootzed, against a ruler. They all made length criterion for the recycle bin too and I went back to just using the gauge. At worst, I figure what I waste in chains, I recoup on cassettes.
Occam's Rotor
Liked 2,331 Times
I decided it would ultimately be less expensive to wax and rotate through 3 or 4 chains repeatedly until everything is very obviously totally worn out, and then replace the whole of the drive train (or at least the set of chains and cassette). If the new chain skips on the front ring, you will know you have over-done it, and can replace that. So far, it has only cost me an inner-chainring ($10) once, and I am replacing cassettes far less frequently.
I did read the post, but I did not watch the video.
I'm a mechanical engineer, not a chemist, but I did prove that naphtha will dissolve paraffin at room temperature and remain a liquid, but if too little naphtha is used, it turns into a mush instead of a water-like fluid at temperatures under about 75 degrees. My lube needs to warmed by placing the applicator bottle in hot water for awhile, unless the room temp is high. In a cool room, the chain may also need to be warmed or the lube may solidify before penetrating adequately.
Occam's Rotor
Liked 2,331 Times
I'm a chemist, but I don't have any deep insight into this. Using paraffin alone seems to work well, at least for me.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1128 Post(s)
Liked 257 Times
I use to use Paraffin wax (without the Slick 50 I spoke of earlier) and I don't think it works as good as the first bike lube that came out called Tri-Flow, some lubes I've tried after that was worse like liquid wax lube made by any manufacture all sucked. The test I always used was chain life, and using paraffin or liquid wax in a bottle the chains only lasted an average of 5,000 miles, with Tri-Flow my chain life went up to about 12,000 miles as it did with other no wax lubes. The best lube in a bottle I've used after 40 some odd years is Rock N Roll Ultimate Dry; I did have to apply it a lot initially, about every 100 miles, but after 6 or 7 applications I now find it doesn't need to be reapplied but every 400 miles maybe, it also stands up to rain which no dry lube I'ver used ever did that! I use Rock N Roll on my road bike but I just started experimenting with Dumonde Tech Lite lube on my touring bike this summer, not sure what to think of it yet, I need more time using it.
The secret to Rock N Roll is to FOLLOW the directions, using the stream method as the company mentions allows the lube to clean the chain, then you run the chain half a dozen time, then wipe the chain like crazy constantly moving the rag to clean area, once the black streaks stop showing you're good to go, then after every ride you wipe it again till the rag is virtually clean, if you don't wipe the chain it will become gummy, but wiping the chain a lot will remove the gummy feeling. Applying the lube a drop on every fifth roller will not clean the chain, it seems wasteful to stream it on, but after a while, you don't have to apply it as often. I started using Rock N Roll when I bought the bike, the chain is the original chain, it has about 8,000 miles on it and is only half worn.
I'm following the directions on the Dumonde lube too, but like I said not sure yet of the long term lasting ability, nor chain life yet since the chain only has about 1,000 miles.
Liked 2,804 Times
If I'm recalling correctly, Friction Facts or Ceramic Speed updated their tests to include paraffin with PTFE and it tested very highly.
The Oz cyclist dude doesn't actually provide any data in his rather lengthy videos. He's mostly doing fanboy demos of the actual testing work done by Friction Facts/Ceramic Speed. For some reason his videos garnered more attention than the much briefer articles and charts that told me all I needed to know in less than 5 minutes.
But I've never cared for the video or podcast format for "learning." Entertainment, sure. But I've always preferred reading a concise article and maybe a couple of good illustrations for learning something new.
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
Liked 257 Times
Except for Squirt lube, like all other wax lubes, does not hold up in the rain. If all you ever ride in is dry conditions then it would be great, but where I live in NE Indiana I encounter rain, especially when bike camping; but I'm not going to call it a day because it might rain. The same is true for high humidity, it won't last as long in those conditions.
https://singletrackworld.com/forum/t...er-conditions/
I guess if you're racing and it's going to be dry, or you live in the western states where rain is rare then Squirt would be just fine.
Quoted: 406 Post(s)
Liked 389 Times
Jedi Master
Bikes: SL8 Pro, TCR beater
Quoted: 1012 Post(s)
Liked 591 Times
Guy must be pushing 2000watt all the time. Would love to see his FTP.
LBS could be using it to tow cars off their driveway.
At least 5000? My previous one had 2000miles on it when I sold the bike and it wasn't close to .5 wear. For your info, I am a pretty big buy that can pull heavy watts on climbs; my drivetrain has a rough life. IMO, the key to extend your drivetrain's lifespan is not the lube, it's the preventive maintenance done throughout its life. I lube my chain every week (80-100kms) and completely degrease it every month (400-500kms) by soaking in fuel overnight, then in wd-40 and finally in isopropyl alcohol. Then, I degrease my drivetrain while the chain is out. When I sold the bike, it looked like it was new.
To answer OP's initial post, I have full confidence in Oz's research on my end. He's well informed and well experienced.
Regarding the PTFE particle size, he does specify in one of the video that they should be very fine (less than 1.6mU if my memory is good).
How many miles do you get out of chains?
When I got 2,000 miles out of a chain, I was oiling that chain all the time. I guess it needed more frequent cleaning, but the cleaning seems like no match for the amount of black crud that gets into the chain immediately. I was using sythetic motor oil (10%) mixed with mineral spirits (90%). Before that, I used dry lube, but it still got nasty black on any use whatsoever. Was I doing something wrong?
How can you inhale PTFE that is mixed with wax? As you know, we are not dusting the chain with PTFE, we mix it to wax and expect the wax/PTFE mixture will reach the inner parts of the links.
The youtuber who promotes this mixture claims to have used many different mixtures including pure paraffin wax and this one turned out to be the best. he claims that PTFE sticks to the eroded sections/scratches. Idk if it is true.
If there is another comparison between pure paraffin vs paraffin with ptfe I would love to see it. If they are close of course I'd love to use paraffin only.
